Reply
Thread Tools View Mode
Old 28th Oct 2008, 20:18   #41
slipperyskip
Seemingly Disinterested
slipperyskip's Avatar
slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.slipperyskip is a hoopy frood who really knows where their towel is.
Originally Posted by Boddaker View Post
It takes a mighty fine (and ballsy) craftsman to stealth that line right out in front in plain sight!
Thanks Brian! We'll see if I can pull it off.
Larger Version
I finished up the glue blocks and sanded everything down to the curve. I also countersunk and re-attached the screws in my sidepanels.
It's TOOLTIME! (Everyone make Tim Taylor grunting noises.)
This photo shows a few of my favorites. In the foreground is a Nicholson 4-In-Hand hand rasp. It has four different surfaces to really tear out chunks of wood with great precision. I have used this tool in all of my projects and consider it an old friend.
Two drill bits, the right one is what I use to countersink screw holes. The left one is a brad point drill bit. Any woodworker MUST have a set of brad points. They feature a very sharp point that makes it impossible for the tip to travel. Both drill bits have masking tape wrapped around the shaft because I often drill holes by hand. Wrapping masking tape creates a "grippy" surface when twirling the bit between my thumb and forefinger. Smaller drill bits need the extra width from the tape to ease the drilling motion. (Cue pron music..boom chicka wah wah)
Clamps. Can't have too many is the rule of thumb. Different kinds and sizes is also a must. Here are two popular Irwin models.
slipperyskip is offline   Reply With Quote
Old 29th Oct 2008, 04:03   #42
ModMinded
Are you throwing that away?
ModMinded's Avatar
ModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the Dremel
Nice update! I really like how it's coming together.
Great guide to how you mod/think about modding!
__________________
My First Mod Log (Nzxt Lexa) (Ongoing) - What was that about idle hands?
ModMinded is offline   Reply With Quote
Old 30th Oct 2008, 18:30   #43
slipperyskip
Thanks ModMinded! It is been fun without any huge mistakes....so far.
Larger Version
I have glued everything up using professional carpenters wood glue and allowed to dry for 24 hours. All the pieces that I intentionally cut too long are sanded into submission.
Larger Version
The screw holes are all filled with wood filler, dryed and sanded down. The lone screw shown toward the bottom will be one of the actual case screws. Later, much fussing will ensue in order to stealth these in.
Larger Version
The front panel wood filling work in process. Goop it on and sand it down. I'm not actually sure if all this is necessary in order to veneer over the screws but I have done it before with success and it makes me look like I know what I'm doing.
Larger Version
I call this the louver floor. It is 1/8" thick and was fairly sturdy before I cut the large slot in the side. The slot is to clear the mini-ITX motherboard. The slot cutting weakened the plank slightly and produced a fragile tab in the corner.
Larger Version
The solution was to flip it over and glue support pieces to the underside.
Larger Version
The floor is fitted up. This photo includes a size comparator. The case is still fairly small even though I've added so much fluff.
I'm dragging my feet on the next step in this project. It involves using contact cement to install the roof. You cannot make ANY mistakes using contact cement because it bonds instantly. The only solution to a mistake is to throw it away and start from scratch. If there are no more updates to this worklog it is because I have flung myself off a roof.
Old 31st Oct 2008, 05:06   #44
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
WOW, the structure looks great. Are you going to paint it or stain it (sorry if you already posted this, I must have missed it).
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 31st Oct 2008, 05:17   #45
slipperyskip
Thanks mate! I'll be applying veneer. You might like to cruise thru my Skyscraper worklog here at bit-tech. It contains a mini-tutorial on how I veneer so you get an idea of what's coming.
Old 31st Oct 2008, 06:50   #46
The boy 4rm oz
Project: Elegant-Li
Oh veneer, I've used that before in design and tech at school. You can get great results, huge variety also.
__________________
Old 31st Oct 2008, 09:12   #47
slipperyskip
Veneer is much more "green" and easier on my conscience. I won't use exotics unless they are veneers from managed growth sources. No rainforests are harmed during the making of my projects.
Plywood and MDF are easier to work with and make a much more stable structure than using raw exotics that can be difficult to mill and prone to warpage.
Old 31st Oct 2008, 18:45   #48
slipperyskip
Larger Version
It is a beautiful day here in Florida. Good thing because I need to move the toxic fumes outside. Coffee...black.
Larger Version
The contact cement needs to dry for 15 minutes. Meanwhile, I stuff some foam into the pockets to hopefully help with sound deadening. Seemed like the thing to do. It will probably get ripped apart thinking I'm smuggling drugs or something.
Larger Version
Instant bonding, no clamps required. The stainless Thermos cap is used to apply pressure to the surface. You are suppose to do that with a fancy roller. You have to put down some fairly serious pressure in order to get a tight bond.
Larger Version
2 hours later, trim with saw and finish up wth sandpaper.
Larger Version
Larger Version
I guess I can put my ladder away.
Old 31st Oct 2008, 23:35   #49
The boy 4rm oz
Project: Elegant-Li
WOW, top looks fantastic. You have done a very nice job with this. Can't wait for more.
__________________
Old 1st Nov 2008, 03:12   #50
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
Don't forget to design the metal grounding thong.
Anyways, your work is absolutely amazing. So much attention to detail goes into to everything.
Keep up the great work.
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 1st Nov 2008, 16:16   #51
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
I hate that stuff. The first thing it glues is the lid.
Nice top. It has the added feature of keeping some jerk from putting a drink on it.
So... Where do you buy your materials?
Cheapskate is offline   Reply With Quote
Old 4th Nov 2008, 18:46   #52
slipperyskip
Thanks guys!
Veneering. My favorite task these days. It hasn't gotten old yet. I do things different...of course. I use regular carpenter's glue instead of contact cement. One big difference is drying time. I spend a lot of time watching glue dry.
Larger Version
Creative clamping is both a skill and an art. A lot of these "sculptures" being displayed for 6 - 12 hours each.
Larger Version
One of many pieces in the collection. I usually run out of clamps and have to re-learn the skill of patience.
Larger Version
Barbie's Malibu Pillbox Bunker (now with reinforced blast roof and walnut bar top.)
Larger Version
Many, many twisted contortions of clamping forced materials.
Larger Version
Larger Version
Walnut faceplate before trimming.
Larger Version
Faceplate trimmed and rough sanded before being fitted for a photo.
Old 4th Nov 2008, 23:11   #53
The boy 4rm oz
Project: Elegant-Li
A very nice choice for the veneer, looks really up market, for a pillbox bunker that is lol .
__________________
Old 6th Nov 2008, 10:49   #54
skunkmunkey
Supermodder
skunkmunkey's Avatar
skunkmunkey has yet to learn the way of the Dremelskunkmunkey has yet to learn the way of the Dremel
Really nice work as usual there mate. I have just finshed veneering a burr wanut front panel for my own media pc, I used No More Nails express wood glue and it did the job for me. How will you be finishing the panel? with wax or varnish? I cant seem to fins a decent guide for finishing veneers. Thanks for your in depth logs, im just starting out using wood as a medium and have picked up some really uesfull tips
btw... I know what you mean with the clamps, i ended up using bulldog clips and all sorts with mine.
__________________
Current Project: Blackwing crypt
New years resolution - Finish my project
skunkmunkey is offline   Reply With Quote
Old 6th Nov 2008, 19:02   #55
slipperyskip
Thanks. I have had this veneer for a couple of years and have been waiting for a project to use it on.
I like to finish my projects with hand-rubbed lacquer. I am a novice at that art form and still learning.
Larger Version
The steel motherboard tray screws into the bottom at four spots and to the back at two spots.
Larger Version
Without the support of the steel tray there isn't much left. There can't be more than a Foster's can worth of aluminum here. It is very light and fragile.
Larger Version
The bottom of the tray showing where the 3.5" hard drive is bolted on. Yes...you can mount two drives with a little modding.
Larger Version
The top of the tray showing the four standard mini-ITX motherboard mounting points. The tray is pressed steel with serious sharp edges. I'll be knocking down these edges and repainting after a minor modification.
This simple steel bracket is a fine piece of engineering. I wish SilverStone sold them separately. You could build an entire system around this bracket.
Larger Version
Measured up some 3/16" x 3/8" stock. Cut and milled the edges.
Larger Version
Fit the new pieces into the "grill".
Larger Version
When you run out of clamps then it's time to go old school. For you young folks these are called books. They are pdf prototypes.
Old 6th Nov 2008, 20:37   #56
ModMinded
ModMinded's Avatar
pdf prototypes... lol!
Nice work, it looks great. What's that molex hanging off the back corner in the mobo tray pic?
__________________
Old 7th Nov 2008, 00:11   #57
bradders2125
Supermodder
bradders2125's Avatar
bradders2125 has yet to learn the way of the Dremel
What he said ^^
bradders2125 is offline   Reply With Quote
Old 7th Nov 2008, 01:49   #58
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
I gave you some stars. This is cool. OK, What is the molex - external power or somebody stole everything else that wasn't bolted down!
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 7th Nov 2008, 02:24   #59
slipperyskip
That's a quick-disconnect between the power supply and the case-mounted DC power jack. The power supply is mounted on its side against the wall near the quick disconnect.
Watching glue dry....
Old 7th Nov 2008, 02:52   #60
ModMinded
ModMinded's Avatar
Ahhhh... nice! You gonna sleeve it or leave it naked and vulnerable in the corner?
PS, that front grill is looking good! Can't wait to see more pics!
__________________
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
