Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
4GB DDR3 Memory Roundup - Part 1
http://www.bit-tech.net/hardware/200...mory-roundup/1
For those of your wanting to jump onto the DDR3 bandwagon and ensure they have enough memory for gaming, in this first part we take a look a three reasonably priced 4GB DDR3 kits ranging from 1,600MHz to 1,800MHz and see what's hot, what's fast and if it's good value.
__________________
#2 | |
Multimodder
other than that nice article |
#3 |
2n-1
Greetings!
I have the same question as I did last year: http://forums.bit-tech.net/showthrea...63#post1590463 What does one gain going from a DDR2 system to a DDR3 system?
__________________
The recruitment of Militia is illegal. Militia-recruiters will be prosecuted to the fullest extent of the applicable laws. |
#4 | |
Multimodder
You might want to consider revising the sentence
Intel have just announced that any DDR3 running at greater than 1.65V will fry the processor, so it looks like none of these current generation of DDR3 modules, or indeed any performance/overclocked DDR3 RAM will be suitable for a core i7-based system. So in fact if you are looking for a core i7 soon, you'd better wait for compatible DDR3 to come out... It looks like any of these modules would prove wasted when core i7 does get released. Last edited by Tyrmot; 8th Oct 2008 at 12:03. |
#5 | |
Richard Swinburne
bit-tech Staff
#6 |
Multimodder
the review was nice and all but i personally think 220 quid is still a lot of money for ram modules (plus the motherboard). I'm sure you can buy 8 gigs of ddr2 (800hmz) cheaper than 4 gigs of ddr3 or you can buy another gpu and sli/crossfire with your current one if you really want that gaming performance increase (but that might push it too far since you'll need a new psu most likely). my point is that i don't think you guys should recommend these since the price is so high and the performance seems incremental. perhaps in 1 year i'll see it as more viable.
__________________
mobo: gigabyte GA-M57-SLIS4 Cpu: AMD Athlon 64 X2 6000+ @ 3.00ghz Gpu: zotac AMP! edition 8800GTS 512mb RAM: DDR-800 4GB storage: maxtor 500gb external + hitachi deskstar 320Gb 7200rpm 32Mb cache Case: NZXT Apollo black OS: windows xp professional sp3 keyboard: crappy dell keyboard mouse: logitech mx 518 mousemat: zboard fragmat headset: creative fatality headset speakers: crappy dell 2.0 speakers |
| spectre456 |
| View Public Profile |
| Find More Posts by spectre456 |
#7 |
2n-1
Greetings!Sorry, but briefly is not satisfactory.
Last year, a DDR2 speed of 800 might had been ok, today the norm is 1066.
__________________
#8 | |
Richard Swinburne
bit-tech Staff
What's the point of 8GBs of memory? There's virtually no difference over 4GB unless you've a million programs open or you're running workstation class hardware and software. 4 DIMMs will also hinder your overclocking potential too. GPUs won't offer performance increases in general productivity either, even if it does obviously benefit gaming. Performance increases are always incremental, and not everyone just wants to buy 4GB of the cheapest DDR2. You can say the same for GPUs - is a HD4870 worth it over 4850 if it's just ~5FPS in some games? Can you really tell 5FPS from a 5 seconds lower encode time? |
#9 |
Ultramodder
i dont really understand the ram orbs.. all performance ram comes with heatspreaders, if you then cant take these off because it'll remove the little memory modules, your left with only being able to fit the ram orbs to generic crap ram. and whats the point in that.. like you say i guess they make more sense to oem's
#10 |
Whooolapoook
Alright Jimmy...keep your pants on!
__________________
0ptimizm :PC under review
#11 | |
Multimodder
Given the uncertanty that has recently been made public (wrt memory voltages vs cpu lifetime...), don't you guys think a ringing endorsment of this sort of DDR3 as an upgrade path for future X58 motherboards is a little, well, I want to say misleading but maybe hopefull would be better?
__________________
#12 | |
I'm not a modder.
Were you deliberately linking to a 404 in the G.Skill page? I presume you were but you never know... Their Pi heatsink/spreader things do look awesome but its a shame that you have to leave the fan on off for the GT1s, it looks a bit silly imo though the cooling performance is rather good. It is interesting how little performance difference these modules make, with less that 2 Intersting to see more Samsung chips as opposed to the Micron chips that a lot of DDR2 was based on.
__________________
i7 920, 8800GTS 512, 6GB Corsair all in an Intel DX58SO; 3*320GB RAID5; CM Stacker ![]() Samsung Q45. |
#13 | |
Richard Swinburne
bit-tech Staff
Try this for a typical style of response: http://www.gskill.us/forum/showthread.php?t=97 Then go to either OCZ or Corsair forum and compare the difference in reply. I accept the tech's are probably Taiwanese but surely they can find some US/Europeans to help out? |
| Thread Tools | |
