Thread Tools |
#1 |
Player Character
bit-tech Staff
Far Cry 2 has cropped widescreen
http://www.bit-tech.net/news/2008/10...d-widescreen/1
Uh-oh. We've seen this particular sequence of events before. It seems that, just like BioShock, Far Cry 2 has a problem with widescreen.
__________________
#2 |
Supermodder
they can do it right for consoles... why not pc???
| cjoyce1980 |
| View Public Profile |
| Find More Posts by cjoyce1980 |
#3 |
Supermodder
consoles work on TV that are 16:9
__________________
Current Rig: i7 D0 2.66GHz, 6GB 1066MHz Corsair "Dominator", 285 GTX. |
#4 |
bit-tech Staff
Oh not this again. Stop whining about nothing.
#5 |
CK is God!!!
its not really nothing
the point about having a widescreen is to see that extra inch either side not to have the top and bottom removed. The Dev team know this so there is no excuse however this will be fixed i bet in patch .1
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7 Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7 Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7 server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2 |
#6 |
Supermodder
In bioshock it was a concious design decision as they had set up the viewing angle for 16:9 and didn't want to spoil the cinematic effect or whatever by people being able to look further afield. It was just people didn't like that and wanted the full screen.
It's not really a big issue though.
__________________
Dreaming C2D E6300 @ 2.8 | | Abit IP35 Pro | | 4GB Corsair XMS2 800 | | BFG 8800GTS OC2 320MB | | 500GB Western Digital for OS + 1500GB Seagate for Storage | | Antec NeoHE 550 | | Lian Li PC A05B | | Samsung 226BW 22" |
#7 |
Lethargic
"Nothing" and "not really a big issue"... hm...
If you spent good money on a high-end widescreen or particularly a TripleHead setup, would you really want to be playing Far Cry 2 with a vertical FOV that makes the game look like you're viewing it through a very narrow horizontal slit? Yes? No? Because when using TripleHead that is exactly what happens. There is a reason why 'widescreen' is referred to as 'widescreen' rather than 'shortscreen' or referring to 4:3 monitors as 'tallscreens'. But those people who don't understand this, don't appear to want to understand this. So it's just another version of the ATi/nVidia or AMD/Intel or Piracy/Anti-piracy flam... um... debate. As for effecting me... nope, it won't. It would if I bought the game, but as much as I want it, I'm standing firm to my decision to not support DRM employed in this fashion. |
#8 |
>^_^<
Don't you mean vertical slit? And when buying a widescreen aren't you buying a narrow vertical slit compared with the horizontal view?
__________________
Welcoming the riff-raff since February 2009. |
#9 |
Hypermodder
That's a pretty big chunk of screen real-estate to lose going by the pictures, if I'm reading it right it also shrinks the text a few font sizes because it assumes you have a much bigger screen ? Given thats not something they can tell at all thats kind of annoying too.
(Edit add) It's a horizontal split because the top and bottom are chopped off and the rest stretched to fit however wide the screen is. Especially bad with triple-head-2-go where you have 3 standard monitors side-by-side and the same height you would have otherwise, you just have 3x the width - this daft sheme would chop off some of the top and bottom and stretch the middle bit of the screen up and down. If I'm understanding it right it won't even give you any extra width, just stretch the same ordinary width over three monitors with the reduced height 0_0 When I bought my widescreen I was really looking at a choice between sticking with 1280*1024 or going up to 1680*1050 since any bigger a standard monitor would have cost a lot more, so I gained a little tiny bit of height and a good chunk of width, using this scheme i end up with no extra width of view (just stretched over more space) and less height than the 1280*1024, thus feeling like looking through a letterbox.
__________________
Athlon 64 X2 3800+ @ 250x10 (1.475v) | EVGA GTX 260 55nm SSC | A8N-SLI Premium | 2x(4GB) Corsair Twinx2048-PC3200C2 | Asus Xonar DX | Antec truepower 550w | Akasa Eclipse-62 DDC12VPlus1, DD TDX, 3/8 tygon r3603 tubing, PA120.2, DD double floppy bay res Last edited by Bladestorm; 23rd Oct 2008 at 11:08. |
| Bladestorm |
| Find More Posts by Bladestorm |
#10 |
I Mod, Therefore I Own
theres a ForceWidescreen="0" option in the config file, dunno if that helps
#11 | |
Lethargic
Half-Life 2 could get widescreen aspect ratio support correct... why can't newer games?
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA |
#12 |
Player Character
bit-tech Staff
My understanding is that that only forces a 10 second test.
__________________
#13 |
Just got a great book on tape
I think I'll decide what I think of this when I play the game..
__________________
Gigabyte MA790FX, X4 9950 Black Edition, 8gb Geil Black Dragon, 2x4870 512mb, Antec TruePower Quattro 850w I game, Do you? |
#14 | |
Ultramodder
the article states that it'll crop the top and bottom off a 16:9 display, but what about 16:10 am i missing something? will it only affect those with 16:9 monitors?
__________________
| titanium angel |
| Find More Posts by titanium angel |
#15 |
Supermodder
This "chopping off" is useful only for multiplayer games, as every player has the same viewing angle regardless of monitor size. (left right, not up down)
Foir a single player game it's rubbish
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C |
#16 |
What's a Dremel?
"Chopping off" is not usefull, its useless. I'd rather have the battlefield solution of stretching the screen to the left & right. Or simply get black bars. Then you're even.
Either way, this solution of Ubisoft means one thing to me: deal breaker. Come on, it's not like not many people have widescreens these days... |
#17 |
What's a Dremel?
It's not whining over "nothing", its a serious screw up. Its also likely done wrongly on the console versions too.
There shouldn't even be a discussion about this. It's just not correct! Quite how Jamie and Dreaming can condone it is beyond me! Vert- has the nasty side effect of altering the relative position of your eyes in game, making everything appear zoomed in and nearer. It often makes gamers feel detatched from their in game character and can lead to motion sickness (because your point of view isnt based where your characters head is!). All widescreen games should be Hor+ And the BioShock "artistic" answer was complete BS. They screwed up and tried to gloss over the mistake with that answer. Then someone hacked in a fix on the PC, everyone saw how it should've looked and thought it looked much nicer and eventually the BioShock guys were forced to release a proper fix. |
#18 |
Multimodder
So to experience the game fully I must rather play it @ 1600x1200 on my 26" Samsung?
Luckily the Samsung monitor has a build in scaler that displays the image in the correct scaling ratio :-) |
#19 |
Web Developer
Shame.. I'll be holding out on this game until they have a patch.
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
#20 | |
Multimodder
__________________
I thoroughly disapprove of duels. I consider them unwise and I know they are dangerous. Also, sinful. If a man should challenge me, I would take him kindly and forgivingly by the hand and lead him to a quiet retired spot and kill him. - Autobiography of Mark Twain |
| Thread Tools | |
