Reply
Thread Tools View Mode
Old 23rd Oct 2008, 11:57   #1
Bouly
Multimodder
Bouly's Avatar
Bouly has yet to learn the way of the Dremel
(¯`._MyMacCube_.´¯) That left
Hello all,,
I present my new project: _MyMacCube_.
The aim is to install a PC motherboard (mini ITX) in a box Mac G4 Cube, all in fanless.
This small config serve as internet and reading for my MP3.
The box:
• Parts of origin MAC
Hardware:
• VIA EPIA SP 8000 Motherboard Mini ITX
• 512MB Kingston DDR400 RAM
• 60GB SATA 2.5DD
• Slim burner DVD 8x
• 120W DC Converter 120W
(¯`·._¸,.»¬=椺²°Part. 1 _MyMacCube°²º¤æ=¬«.,¸_.·´¯)
Before everything and start of the project, unpacking and testing the hardware:
First start:
Successful installation of Windows XP Pro
(¯`·._¸,.»¬=椺²°Part. 2 _MyMacCube°²º¤æ=¬«.,¸_.·´¯)
The case 174mmx174mmx179mm internal measure, I should store all my gear. So I decided to all 3D modeling to verify:
The PC motherboard:
The cage with the hardware:
The project finished:
(¯`·._¸,.»¬=椺²°Part. 3 _MyMacCube°²º¤æ=¬«.,¸_.·´¯)
Realization of the cage hardware 173mmx173mmx178mm:
Realization of motherboard cache:
Dismantling of the grid and support Cover:
New 3D modeling:
(¯`·._¸,.»¬=椺²°Part. 4 _MyMacCube°²º¤æ=¬«.,¸_.·´¯)
Collage of angles for fixing the basket on the box inside, not to mention the cutting of the plate higher:
(¯`·._¸,.»¬=椺²°Part. 5 _MyMacCube_°²º¤æ=¬«.,¸_.·´¯)
I started to support my motherboard (plexi white 3mm).
Cutting elements:
Trimming logo:
Test in the basket hardware:
- 3D rendering and workpiece -
(¯`·._¸,.»¬=椺²°Part. 6 _MyMacCube_°²º¤æ=¬«.,¸_.·´¯)
I finished my motherboard support:
I also finished cutting logos and all my parts:
(¯`·._¸,.»¬=椺²°Part. 7 _MyMacCube_°²º¤æ=¬«.,¸_.·´¯)
My PSU support, my support hard drive and support DVD Slim almost done:
(¯`·._¸,.»¬=椺²°Part. 8 _MyMacCube_°²º¤æ=¬«.,¸_.·´¯)
The basket hardware is almost finished.
Following the next issue soon and sorry for my English approximate.....
Bouly is offline   Reply With Quote
Old 23rd Oct 2008, 14:11   #2
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
awesome, i had the very same idea just the other week!
__________________
Project log Mocha70
Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2
Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Old 23rd Oct 2008, 19:09   #3
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Awesome. If you are keeping the metal skin layer, you MUST sand and polish it.
-And I could stare at that tablecloth all day. It's trippy.
Cheapskate is offline   Reply With Quote
Old 23rd Oct 2008, 22:10   #4
Nolimited
Supermodder
Nolimited's Avatar
Nolimited has yet to learn the way of the Dremel
really nice work and clean
__________________
Blue Flames - Case Finish Nominated for MoM - March 2009
Nolimited is offline   Reply With Quote
Old 24th Oct 2008, 15:37   #5
jegerjon
Supermodder
jegerjon's Avatar
jegerjon has yet to learn the way of the Dremel
Seems like a pretty nice start! Keep it up, by the way your 3D work is awesome.
__________________
Project: Alu-case - FIN: [06/02-2007]
Project: NLM - FIN: [02/11-2007]
jegerjon is offline   Reply With Quote
Old 24th Oct 2008, 16:04   #6
Bouly
Multimodder
Bouly's Avatar
Thank you all for your nice messages.
Old 24th Oct 2008, 18:43   #7
renba
hooch is crazy
renba's Avatar
renba has yet to learn the way of the Dremel
Very nice project
renba is offline   Reply With Quote
Old 24th Oct 2008, 18:49   #8
cyberspyder
Canuck
cyberspyder has yet to learn the way of the Dremel
Just as a reference, here's another G4 mod: http://www.gordyhand.co.uk/maccube.htm
cyberspyder is offline   Reply With Quote
Old 24th Oct 2008, 20:16   #9
Bouly
Multimodder
Bouly's Avatar
thank you for the link but I already knew
Old 24th Oct 2008, 21:18   #10
crazybob
Voice of Reason
crazybob's Avatar
crazybob has yet to learn the way of the Dremelcrazybob has yet to learn the way of the Dremel
The idea is excellent and the craftsmanship is beautiful. Unfortunately, I see two problems with it. The first is that passive cooling is very difficult, even of such low-power components; this is actually one of the reasons the Cube was originally discontinued. Your board may have worked just fine sitting out on the table, but the airflow is a bit more restricted inside the case. If there's a decent ventilation space at the bottom to match up with the nice grills you have cut into the top, you might be OK if you can keep a clean airflow path. This brings me neatly only my next problem, which is that it's more likely to work if the fins on the heatsink run vertically, rather than horizontally as you have them drawn. The horizontal fins will tend to trap warm air, whereas vertical fins will keep a small amount of gentle airflow going.
If you end up having thermal issues, you could place a single Nexus 80mm or 92mm fan somewhere running at very low voltage to help keep the vertical airflow going. A Nexus running at 5-7 volts is so quiet that the noise of your hard drive would completely drown it out.
Sorry if I sound like I'm trying to discourage you from your original plan. I love the idea, and as I said, your work is excellent. Keep it up, because I look forward to seeing the result!
crazybob is offline   Reply With Quote
Old 24th Oct 2008, 21:49   #11
Bouly
Multimodder
Bouly's Avatar
I planned to install a fan to remove hot air, just for safety.
Old 24th Oct 2008, 22:07   #12
Bouly
Multimodder
Bouly's Avatar
My latest creation: "Cosmos Ohm"
Cooler Master Cosmos 1000 + 2 x Noctua NF-S12 + 1 X Noctua NF-R8 + 1 X Thermaltake TT-1225
Corsair CMPSU-620HX
ASUSTeK Striker Extreme 680iSLI + Asus Supreme FX 7.1
Core 2 Quad Q6600
Thermalright Ultra-120 eXtreme Edition + Noctua NF-S12
Crucial Ballistix Tracer 4 Go (2 Kits 2x 1 Go) DDR2-SDRAM PC6400
SLI NX8800GTS-T2D320E-HD-OC MSI
Barracuda 7200.10, 320 G, buffer 16mo (x2)
DVD Samsung SH-S203B/BEBN
Old 26th Oct 2008, 12:35   #13
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Never seen a MACCube modded before, looking great so far.
I love yous Cosmos, very clean and original. Fantastic work.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 26th Oct 2008, 12:43   #14
Bouly
Multimodder
Bouly's Avatar
Thank you very much for your remarks
Old 26th Oct 2008, 16:39   #15
don_Martin
Multimodder
don_Martin has yet to learn the way of the Dremel
This project reminded me of this guy who managed to fit a mac mini into the cube.
http://www.123macmini.com/macminicube/
Should provide you with some inspiration.
don_Martin is online now   Reply With Quote
Old 26th Oct 2008, 19:33   #16
Bouly
Multimodder
Bouly's Avatar
I know the project, great job of integration, painstaking work.
Without bragging, I think I saw almost all workblog on Mac G4 Cube.
To keep the spirit Mac G4 Cube, tomorrow I'll try to do my touch-Sensitive Button.
1 x QT110 de Quantum
1 x 4N25 optocoupler
1 x 470 ohm resistor
1 x 10nF capacitor
Old 27th Oct 2008, 11:31   #17
Bouly
Multimodder
Bouly's Avatar
(¯`·._¸,.»¬=椺²°Part. 9 _MyMacCube_°²º¤æ=¬«.,¸_.·´¯)
Hello,
I finished the structure of mod ,tomorrow preparation and painting.
Old 27th Oct 2008, 12:55   #18
The boy 4rm oz
Project: Elegant-Li
Awesome, what colour will it be painted? White, black, silver?
__________________
Old 27th Oct 2008, 13:10   #19
Bouly
Multimodder
Bouly's Avatar
I'll paint everything white. The columns will be chrome. Then I'll make a carbon effect on the bottom.
Old 28th Oct 2008, 09:13   #20
The boy 4rm oz
Project: Elegant-Li
Sounds fantastic.
__________________
Reply
Tags
case mod
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
