Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 23rd Oct 2008, 12:58   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Hardcore Computer launches immersion cooled PCs
http://www.bit-tech.net/news/2008/10...n-cooled-pcs/1
Hardcore Computer, a USA based system builder, has launched the first total immersion coolant based systems.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 23rd Oct 2008, 13:12   #2
WildThing
Hypermodder
WildThing's Avatar
WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.WildThing is the Cheesecake. Relix smiles down upon them.
Wow that's pretty cool, although I'm guessing it will be a while before/if it becomes mainstream.
__________________
Asus P8P67 PRO ¶ Intel i5 2500K @ 4.4GHz ¶ Titan Fenrir ¶ XFX 6950 @ 6970 ¶ 2x4GB Corsair DDR3 1600MHz ¶ 2x Crucial C300 128GB (OS + Games) ¶ Samsung Spinpoint F3 1TB ¶ Auzentech XFI-Prelude + Creative T7700 7.1¶ Enermax Liberty 500W ¶ Corsair 650D case ¶ HP 24" LP2475W ¶ Win7 x64
WildThing is offline   Reply With Quote
Old 23rd Oct 2008, 13:44   #3
badders
Neuken in de Keuken
badders's Avatar
badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.
When are you getting one in for review?
Also - the radiator is cooled by fans, although it is very quiet.
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Old 23rd Oct 2008, 14:42   #4
DaMightyMouse
Minimodder
DaMightyMouse has yet to learn the way of the Dremel
Cool beans, want one ... although replacing a part will be quiet tricky
DaMightyMouse is offline   Reply With Quote
Old 23rd Oct 2008, 15:30   #5
Dr. Strangelove
Supermodder
Dr. Strangelove's Avatar
Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.Dr. Strangelove is the Cheesecake. Relix smiles down upon them.
Maybe I'm missing something but why are there tubes going to what looks like "old-style"water cooling heat blocks, surely the idea would be that the components that got hot would have air style heatsinks and the heat would be transferred to the liquid all around the system. Otherwise this would just be a "water" cooled system with "water" around it (guess makes it less of an issue if there is a leak )
have a look here http://www.hardcorecomputer.com/Prod...oryDetail.aspx (under the quality tab)
__________________
If it isnít broken, fix it.
If it is broken, mod it till it looks like it's meant to be broken.
Dr. Strangelove is offline   Reply With Quote
Old 23rd Oct 2008, 15:51   #6
Nikumba
Hypermodder
Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.Nikumba is definitely a rep cheat.
I see what you mean, I think this is probally needed to move the fluid over the CPU, as shifting all that fluid at a rate to move heat away I would imagine would need a hefty pump, this way they can keep a sustained flow over the hotter parts
Kimbie
Nikumba is offline   Reply With Quote
Old 23rd Oct 2008, 15:55   #7
Dr. Strangelove
Supermodder
Kimbie
Sure but with all the engineering that has gone into making this.. you would think they could come up with a cooler (pardon the pun) solution. Maybe use the pumps to just shift the coolant around the case?
__________________
Old 23rd Oct 2008, 15:56   #8
steveo_mcg
I Mod, Therefore I Own
steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.
I think we decided in the other thread that it was for performance since the pre cooled oil is dumped directly on to the hottest parts of the unit.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 23rd Oct 2008, 16:18   #9
Dr. Strangelove
Supermodder
To me that just ruins the whole thing.. I would even take a performance hit to make it work without waterblocks...
__________________
Old 23rd Oct 2008, 16:55   #10
Xenith
Minimodder
Xenith has yet to learn the way of the Dremel
i would love to see someone here at bit-tech do a project with the pc components completely immersed in a coolant >.>
really i just want to see how its done and what kind of precautions and such need to be taken when doing something like that ^.^
__________________
lGigabyte GA-965P-DS3l lE6420 2.20ghzl l4gb Patriot Extreme Performancel lGeforce 8800 GT 512mbl
Xenith is offline   Reply With Quote
Old 23rd Oct 2008, 17:12   #11
_DTM2000_
Multimodder
_DTM2000_ has yet to learn the way of the Dremel
Droool, I really want one of those. I'd have to see some benchmark scores etc first though.
Seen as they even custom make the motherboard, it would be interesting to see how it compairs against similar spec systems.
I bet the shipping to the UK is a killer though, seen as they weigh over 50KG.
Not to mention the hefty import tax bill you'll get raped for by Mr Darling.
_DTM2000_ is offline   Reply With Quote
Old 23rd Oct 2008, 17:14   #12
proxess
Ultramodder
proxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for presidentproxess should be considered for president
How is the PSU hooked up and working in these conditions? Can someone explain? I know the liquid is non conductive but still wouldn't it normally do something terrible to the PSU?
__________________
Laptop: i7 4930MX @4.0GHz; 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 23rd Oct 2008, 17:41   #13
Nikumba
Hypermodder
Not really, the PSU i imagine will either be in the fluid or sit out of it, either way if the fluid is non conductive, there will be no problems. If you saw the danger men program on C5 last week, you would have seen them washing 500,000 volt powerlines in a helo with pure water with no issues, so i dont see how a small 240v psu will casue problems
Old 23rd Oct 2008, 18:16   #14
Thacrudd
Where's the any key?!?
Thacrudd's Avatar
Thacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run CrysisThacrudd can run Crysis
The PSU is immersed as well. If you read the interview, there's actually 2 PSUs in there! This is way cool, I'd love to have one. These guys did it right.
__________________
Just as you touch the lives of every life form you meet, so, too, will their energy strengthen you. Fail to live up to your potential, and you will never win... - Gaspar, The Guru of Time
Project: Andromeda
CurseMyStuff.com
Thacrudd is offline   Reply With Quote
Old 23rd Oct 2008, 19:26   #15
themax
Ultramodder
themax's Avatar
themax has yet to learn the way of the Dremel
Maybe it's because I'm not a huge computer buff in the sense of overclocking and such, but what is the point of a $5000 Immersion cooled computer?
It definately looks cool, and sounds nice to have, but it's priced way, way out of what I could afford. For $5000 I would rather pay closing costs on a house or make a downpayment on a car. I don't think things like this really help the PC market when so many manufacturers price optimized gaming hardware/setups out of the mainstream reach. Sorry, just had to say that. Again, that whole setup is definately cool, but way too expensive.
__________________
PSN: Nyne07
Xbox Live: Nine07 (RIP XBOX 360 5/8/2010)
Wii Codes: Too damn many to remember
CoD4 Class "Ghost" - MP5 Silenced/ UAV Jammer/ Silent Step
Shhh be very very qwuiet....I'm hunting snipers....
themax is offline   Reply With Quote
Old 23rd Oct 2008, 20:04   #16
Dr. Strangelove
Supermodder
btw I remember being part of the group discussing the original immersion computers (on overclockers.com and one problem was the caps which "pop'ed" after some time ... is this solved??
__________________
Old 23rd Oct 2008, 20:31   #17
Redbeaver
The Other Red Meat
Redbeaver's Avatar
Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!
http://www.maximumpc.com/article/fea...corepc_reactor
lotsa very pretty pictures...
__________________
Ophelia
ASUS P5Q Pro Turbo - Q6600 - 4GB DDR2 - NVIDIA 8800GTS 640 - WD Black 2x320Gb RAID-0 - Silverstone TJ-06 [Modded]
Perseus
ASUS Z97i-Plus - i5 4670K - Corsair H110i GTX - 8GB DDR3 - Zotac GTX 970 - RAID-0 Crucial MX100 2x256GB - Phanteks Enthoo ITX Red
Redbeaver is offline   Reply With Quote
Old 23rd Oct 2008, 20:57   #18
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysismetarinka can run Crysis
octools has done this before... crica 2000 http://www.octools.com/index.cgi?cal...ubmersion.html
for the record you can put every solid state piece of equipment under the coolant including the power supply. In fact many transformers for power lines are oil submerged.
The problem with say submersion cooling over directed cooling is that you're adding a lot of waste heat to the system. For example you can buy a perfectly reasonable air cooled powersupply that is silent and has no need for further cooling. By submersion cooling this part all you are doing is adding more heat that needs to be extracted. Same goes for south bridges, and other smaller controller chips that don't need additional cooling.
That being said it is a nice looking case. I've always wanted to build a partial submersion rig using transformer oil
metarinka is offline   Reply With Quote
Old 24th Oct 2008, 00:19   #19
Lazarus Dark
Supermodder
Lazarus Dark's Avatar
Lazarus Dark has yet to learn the way of the Dremel
Somebody has to say it...
But can it...
Bitstream HD audio?
Seriously, in my professional opinion... This is pretty fricking cool. (no pun intended)
I don't mean submersion. It's been done. I've got some drafts around here I did for one a couple years ago, though I never got around to building it. It's just very difficult to do and be practical.
But this. This, I am impressed with. It is sleek, well designed, fully thought out (the handles for removing the mobo are genius). I have not even considered buying a prebuilt in five years, I wouldn't even get one of the fancy ones if I won a million dollars... until this one. Starting at five grand? So, they are selling this at cost? My guess is, these guys just wanted one for themselves and throw out the R&D time and cost as just fun time (wouldn't you enjoy such work?). The case is gorgeous and the exclusivity would be an egotrip. I love the whole design, from the board to the way the vid cards mount, to the cord management. This is some fine looking case.
I would though really love to see some benchmarks comparisons, especially if this is really a custom mobo.
__________________
My gun kata is greater than your kung fu.
Lazarus Dark is offline   Reply With Quote
Old 24th Oct 2008, 00:33   #20
LordPyrinc
Legomaniac
LordPyrinc's Avatar
LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.LordPyrinc is the Cheesecake. Relix smiles down upon them.
Looks cool. Only time will tell if it truly creates a niche in the market. Regardless, advances on already existing ideas are always a positive push forward in our discovery of the next great invention.
__________________
Intel i7-920 @ 2.66GHz - Corsair Vengeance 16GB DDR3 @ 1600MHz - Windows7 64bit
2 x 150GB WD VelociRaptor HDs (RAID 0) - 1TB WD 7200 rpm HD - 60GB OCZ SSD - 1TB WD External USB HD
2 x EVGA GeForce GTX 660Ti 2GB Superclocked (Dual SLI) - Razer BlackWidow Ultimate KB
Cooler Master HAF 922 - Thermaltake Smart M 850W - 27" Samsung S27B550 LED Display
LordPyrinc is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
