Thread Tools | View Mode |
#1 |
Resident frenchie
Suggestions needed for my Netfinity 5000
Hi all !
I just got hold of a monolithic Netfinity 5000 for free (yay!) I stripped it myself of its innards (was p2 350, 160 Ram and 2* 9.1GB cheetahs uSCSI and a 20GB tape drive) and now I wish to adapt it so that it can house my soon to be gaming rig.. It's a great case : removable Mobo tray HDD bay with 2 trays (3 are just empty) 2* whooshy fans, mounted on rubber grommets solid and heavy. As you've seen, I wil have a couple things to do. Questions : Some extra screwholes on the mobo tray might be problematic and will need to be cut/insulated) I need to buy and mount a SATA backplane on it. I have to adapt the fan and LEDS/PWR connectors. (Will the fan fry the mobo : they are 12V 3.2 W ??) I've made pics so that you can suggest ideas/ways of doing what I want. I'm not looking for watercooling or the likes, although the case it beig enough for it. ^^ ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Will I have to make the PSU hole larger for better airflow with a modern meshed PSU ? ![]() A couple more pics at http://g3n3tix.free.fr/files/Pics/IBM
__________________
I also have a MTBF. Last edited by g3n3tiX; 25th Oct 2008 at 14:59. |
#2 |
Multimodder
This looks like it's going to be cool. I just got an old Dell P3 server at my store that's about 60 lbs and is probably 2 ft x 4 ft, I'm sure it would make a great project.
| nitrous9200 |
| View Public Profile |
| Find More Posts by nitrous9200 |
#3 |
Resident frenchie
It will surely be nice, but will need work. I also have to find a decent backplane to use the hdd rack properly. Any tips ? ebay only sells self contained ones, I need the bare circuit.
__________________
I also have a MTBF. |
#4 |
sudo rm -Rf /
Replace the one that's there with one of the complete ones from ebay. Finding just the parts you need is going to be a pain in the ass to get every thing lined up properly.
__________________
I always wanted to have that ideal father son relationship. You know, where I get to see him for like eight hours every other weekend, and send checks to some woman I hate. -- Tucker, Red vs. Blue |
#5 |
Resident frenchie
Thanks for the tip. I might buy individial back planes (I found some on ebay) and put one for each disk. With careful cable management it won't impede airflow that much. Or I could just plug the drives direcly to the cables, with the risk of somone wanting to remove one from the front.
Like that : Or that for example. What about the fans : 12V/3.5W : okay for connection to a mobo or is it best if on PSU rail ? And the PSU hole at the back ? does it need enlarging ? (I think so) : what tools ?
__________________
#6 | |
sudo rm -Rf /
__________________
#7 |
Resident frenchie
Well I just ordered 2 individual backplanes, I'll see how they work.
The cool thing is that they have headers for LED (pwr/activity) so it can show on the rails, for individual disks. Neat. Now I hope they'll be of correct spacing/depth. (*fingers crossed*) I'll just have to borrow a dremel and start cutting some stuff. What do you suggest to cut steel (I'm assuming it is steel as the case is magnetized)
__________________
#8 |
The Right man in the Wrong place
Diamond blade. They eat through reinforced disks easily, even though its possible.
I'm talking about dremels here. If your doing something large, a grinder/jigsaw/other would be better |
| Thread Tools | |
| View Mode | |
