#1 |
Richard Swinburne
bit-tech Staff
Antec Skeleton
http://www.bit-tech.net/hardware/200...tec-skeleton/1
Is it a case? Is it a test bench? No, it's the Antec Skeleton! With a unique open air approach to keeping your hardware cool. We take a look to see if Antec's minimalist new chassis has what it takes to shake up the PC case market.
#2 |
ITS OVER 8000!
£130...WAAH?
I can buy a couple sheets of MDF, some screws and a few 120mm fans for about £20... I'll have my £110 back please. EDIT - http://www.chilledpc.co.uk/shop/prod...roducts_id=673 Thats the test bench to get for £130... |
#3 |
Multimodder
What idiot didn't see it as being necessary to be able to fit a huge heatsink on a testing bench. This case has so many floors i wouldn't even consider it for £10, never mind £130.
#4 |
my supersonic radar will help me!
that is pretty crap
__________________
People who optimise code are wimps. My code knows it's awesome, so it'll take all the time it needs. You can wait in awe |
#5 |
regular bit-tech reader
Add few batteries, some wheels, dog-trappings and voila! You've got a mobile PC...
but even then it would be cheaper to mod your old grass-mower. |
#6 | |
whatever
It's overpriced, doesnt fit big heatsinks, drives are mounted with screws, the mobo tray slides out to the back, the horizontal bar that holds cards in place doesnt slide out together with the mobo tray...
on top of that it is ugly. Sorry, but Antec failed this time. Nice review though.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S Quote:
#7 |
Multimodder
Ummm ... dunno where to ask this, but as the Skeleton looks like a failure anyway: Did you ever review, or consider to review the Antec Three Hundred? That's a nifty little case offering a very good price/performance ratio, and it's surprisingly cheap. I like it very much.
#8 |
working for the good of mankind...
I can't believe you couldn't find a Zalman 7000 series HSF around. This was a classic before the 9000 series and there's even the newer 8700 series with heatpipes. These would have cooled that CPU down much better and they aren't anywhere near as tall as the others. They didn't even get a mention in the review.
__________________
Check out my site - Mods n Clocks - Latest update 23rd November 09 Latest: Review – Galaxy Black Mid Tower Case with Blue Bubble Light LED Strip Also: Review: 1GB XFX 4870 Graphics Card (HD-487A-ZDFC) Most Popular: Review: Intel Core 2 Quad Q9550 CPU – E0 stepping |
#9 |
Whooolapoook
Not supporting taller after market heatsinks is an utterly unfogivable oversight.
__________________
0ptimizm :PC under review
#10 | |
Benchmarketeer
bit-tech Staff
I think the real problem here is that the Skeleton is closing just too many doors on the hardware you can install. No heatsinks over X height or width, no 8800 Ultras, no GTX 2xx series cards if your PSU doesn't have flexible power connectors. If you're buying a case/enclosure you want to be able to fit whatever hardware configuration you want into it, not just the limited set approved. Imagine an operating system from Microsoft in which you can only install games requiring less than 1gb of hard drive space - There would be outcry, although some would doubtless still point out that the original Half Life would fit. But what if you don't want to play Half Life, and want to play Far Cry 2 instead? |
#11 |
Multimodder
It looks like it was thought of as a test rig by a tech then handed over to a committee to design - there's no way one individual could have screwed the design up in so many different ways.
I'd bet that having the top section higher was nixed because it would have interfered with the curve of the side rails. Having the tray slide out of the front was obviously too easy and making the motherboard headers longer would have left unsightly cables free don't you know? Nice idea, shame the implementation appears to be so poor and how they justify the price is something I simply can't figure out. If it was £30 I'd have two and build a decent test bed out of the bits but at £130? Thank you but no, I think I'll stick with my heath robinson variety. |
#12 |
Lethargic
Bit-tech basically came to the same conclusion that ExtremeTech did when they reviewed it - with the difference you were (rightly) even harder on the 'case' than they were. Seriously, if someone wants an open-air testbench... it can't be that hard to make one. But no TRUE or higher-end GPU fitting in is unforgivable.
#13 |
know-it-all b*stard...
You could pick up some public works PVC cutoffs and skip the mdf Mankz.
__________________
#14 |
Supermodder
Note, the hard drives and optical drives ARE quick release, but the instructions with the skeleton suck so bad it's hard to tell how to install it. You need to use the cylinder head screws in the little bags. One per drive. On the right side of the optical and left side of the HDD viewed from teh front of the case. If you do this and select the right hole in the drive, you can slide the drives in and out and they will click into place. No need to use the outboard permanent screw holes at all.
I like my skeleton. I'm running a Phantom 500 PSU in it and my older P4 system with a passive radiator on the CPU. Only downside is my crappy Nvidia 7800 board sounds like a jet aircraft taking off when I spool up a game, and the Nvidia drivers turn the fan off or on, but don't regulate it in between the extremes. |
#15 |
hardware freak
dumb sauce
#16 | |
Benchmarketeer
bit-tech Staff
But surely the £130 you spent on the Skeleton could have been better spent on a core hardware upgrade? |
#17 |
Modder
it sucks that they pared it down to a lackluster device.
the skeleton is something different, and they should have made it Uber expsensive and perfect, rather than pretty expensive, and lacking. it would have been easier to downgrade a great product for cash-strapped people, then to try to make a better version at a later date. the PR loop is backwards to start with "meh", and then work up to "oh-my!" i was looking forward to this being awesome for my next build...now i gotta make a GOOD skeleton case, to show antec how it is done. |
#18 |
Why not? I own a domain to match.
Fail.
Looks like it showed a lot of potential too, were it not for the massive design oversights.
__________________
hire me @ eric-stern.com - web developer and php ninja
pics @ my smugmug :: Twitter @firehed :: blog @ firehed.net 40D|580EXII|285HV|AB800|70-200f/4LIS|17-50f/2.8|150f/2.8Macro|50f/1.8 MacPro @ 8x2.8GHz, 10GB FBDDR2, 3TB HD :: MBP @ 2x2.2GHz, 4GB DDR2, 320GB HD |
#19 |
DUHHHH
I saw one where I work and thought 'WTF IS THAT?'
__________________
Phenom X3 720 Black Edition @ 3.4Ghz - Asus M3N72-D SLI - 4GB PC6400 - MSI GTX260 216 - RAID0 37gb Raptors - 2x 500GB - Corsair TX850 - Samsung 2233RZ 120hz cheesecake - Windows 7 Ultimate 64Bits Kids ! The Samsung 2233RZ is the solution to all your problems in life ! That is, of course, if your biggest concern is not sucking at FPS games |
#20 |
Supermodder
This may be a silly question.. but do you really think it will build up more dust than a normal case.. or will it just be more obvious? I mean especially with that big fan, you would think that dust is blown away...
btw £130 for that is just an insult
__________________
If it isn’t broken, fix it. If it is broken, mod it till it looks like it's meant to be broken. |
| Dr. Strangelove |
| View Public Profile |
| Find More Posts by Dr. Strangelove |
| Tags |
antec, bench, case, skeleton, test ![]() |
| Thread Tools | |
