Reply
Thread Tools View Mode
Old 15th Dec 2008, 22:32   #61
OilPC
Minimodder
OilPC's Avatar
OilPC has yet to learn the way of the Dremel
Originally Posted by ModMinded View Post
Just saw the final pics/writeup and I am not disappointed... more importantly, I hope you're YOU'RE not disappointed! Really cool and I'm not just talking about the temps. I'd be interested in seeing updates later on, to see how things are going and if you find any areas you'd redo.
That parallel power cable is hidden well as is against the wall. Overall nice look!
What are you thinking regarding your next one? What did you learn from this one that you'd change for the other? Aesthetically, I'd like to see the metal in the frame/tray a different color, black or chromed rather than just the standard bare metal, and maybe closer to the width of the top and bottom piece. I really do like the way you'd set up the base with the removable panels!
Also what are those tubing connections sold for? I think you mentioned it earlier, but I'm feeling lazy.
Thank you for your great comments. I already know you are a great writer from your project log, and that is why all the comments you leave make me feel good.
I will post updates after 6 months and 12 months to let people know how the system is going. I wonder how many people want to see them though.
I am also thinking about posting a video since I recorded some videos clips. The problem is I'm pretty lazy person...I even don't remember which hard drives I backed up all the clips to.
The printer cable connector is quiet bulky so I had to make a room against the wall. That's why I told you that your idea is great. "Hiding the connector" Anyway, for better air circulation, the system needed a little more room since the radiators are in the bottom part(box) facing the wall too...just like a refrigerator.
Next mineral oil system will be different from the one I just finished. I will use decent MINI-ITX motherboard, but no fans and radiators at all. Therefore, it will be totally different experience ,and I'm thinking about using SSD to save some space rather than regular HDD with breathing tubes if I can find really cheap(bargain) ones. Money is always the biggest problem.
I never thought about painting the hardware tray (motherboard tray) because only a little bit of the aluminum tray can be seen. However, it will definitely give a touch to the system. Thanks for your suggestion.
I tried to make the acrylic tank as small as possible to reduce the amount of oil used. That is why I even directly soldered the power cables to the power supply.
The tubing connections I used called 'ONE TOUCH FITIING' ,and they are what I used for my water cooling systems as well. You can find more information at below links.
http://images.google.com/images?hl=k...-8&sa=N&tab=wi
http://www.conekfit.com/en-p1-1.htm?...FRlRagodv1MwSg
http://www.automation4less.com/onetouch.htm
http://www.smcusa.com/sections/produ...gs_tubings.asp
OilPC is offline   Reply With Quote
Old 15th Dec 2008, 22:55   #62
OilPC
Minimodder
OilPC's Avatar
Originally Posted by Xtrafresh View Post
No, really!
Looking at your report for the temps, i think what you need is more coling capacity on those radiators. 6 or 7 degrees temp diference is not really impressive to be honoust. Still, your temps seem to be ok, so no wories huh?
I really enjoyed reading this, and i'm loking forward to the next. Thanks for sharing!
Yes, I think you are right. Even though I put two 120 mm fans to each radiator I am only able to get 6-7 degrees cooler. However, it is the lowest rpm setting. I think that when room temperature gets lower, or rpm is set higher, I might get better results. My concern however is with having a low noise and zero dust system, so keeping the system under 50 degrees is quite a satisfactory result for me.
I am happy to hear that you enjoyed my log, and I also really appreciate your interest.
Originally Posted by tominated View Post
looks great. awesome worklog. congrats on finishing
Thanks for reading my worklog and the congratulations. What a relief it was when I finished the project.
Originally Posted by The boy 4rm oz View Post
It looks fantastic, very nice work. Personally I thought the temps would be slightly better but it is still quite cool. Very extreme cooling and a very extreme result, beautiful.
Kinda reminds me of the guy who hooked his water cooling loop to a pump in his swimming pool lol.
I'm thinking about replacing the pump with a more powerful one with higher lpm (liter per minute) rate and the fans with ones that have a better air flow rate to get better cooling results, if I have free time in the future and a chance to buy extra parts. Thank you for leaving me a kind comment.
Originally Posted by Spyrious View Post
Extraordinary work have you accomplished!!!Something out of the ordinary.What thikness does the oil have?Do the fans spin easily?
Thanks...
All the fans in the oil works ok, but spin very slowly. I can also see the heat wave from the fan...I mean temperatures difference in oil makes some kind of convective wave. It is kind pleasant and relaxing visual looking. Especially, for the fan in the graphic card's heat sink, because I set the fan's speed at 'AUTO FAN CONTROL', I can actually see the fan spins differently based on the temp of the oil.
The mineral oil I used is PETRO-CANADA FOOD GRADE "Purity FG WO 15". It has flash point of 180 degrees Celsius and viscosity of 15. I'm thinking about posting an extra log about mineral oil if I have a chance.
Old 15th Dec 2008, 23:07   #63
OilPC
Minimodder
OilPC's Avatar
Originally Posted by Loom View Post
Good luck in MotM and thanks again for posting such a detailed work log!
I have never thought about MtoM, and winning is not important to me, and I don't think that my mod deserves one anyway. All other mods are much greater in every aspect, but nomination itself means a lot to me. Thank you for reading my log.
Originally Posted by talladega View Post
Outstanding work! There are that many oil submerged mods out there and I don't think I've seen one built even close to as good as yours. Truly amazing!
There must be one, two or even more unexposed oil pcs out there. I was just lucky to have chance to expose my work and meet great modders(readers) here at bit-tech.net to get excited comments like yours. Thanks.
Originally Posted by Matticus View Post
Simply amazing work.
The temps seem fine to me, maybe the cpu is a little hot but the gpus are looking excellent.
Maybe if you do another oil cooled PC you could get a small car radiator to circulate the oil around, I am sure you wouldn't need any fans to cool it then.
Again, amazing work you should be very pleased with the results.
I just wonder what it would look like with UV LEDs and some UV additive? If there is an UV additive that is 100% non conductive and non-pcb-staining.
I am really happy with the temps of the GPUS. They are comparatively cool I think. Using a bigger radiator probably works better, and I'm thinking about doing some extra work on the system when I have some free time. For the 2nd system...actually it will be my 3rd mineral oil system since I built a test system 2 years ago back in 2006....The test system also works just fine until now. The picture of the test system is here...
Anyway, my next system will be totally different from what I have done. No fans and no radiators.
I saw some comments about 'COLORING MINERAL OIL' somewhere, and none of dyes worked. Please let me know if you can find any kind of coloring solution or colored non conductive liquid with non-pcb-staining. Thanks.
Originally Posted by Mankz. View Post
When Amari were building their mineral oil PC, they replace the stock coolers on the GPU/CPU with medium sized ones, and then removed then fans becuase the mineral oil is denser and harder tio push than air, so the motor bearings will wear out quicker.
That aside, what a brilliantly executed design!
Thank you for your comment.
It is good to hear that the words 'brilliantly executed design" even though I don't think it is such.
I would say that the fans are not necessary for the mineral oil cooling, and they are mainly there for decorative look (visual effect). However, the heatsinks must be on the CPU/GPU as a heat buffer. Without them, based on my attempts, the temps increase dramatically.
Therefore, Amari's choice, having a bigger heatsink without fans, is a great choice I think.
Originally Posted by Nexxo View Post
This is one of those mods where all I can say is: NO WAI!!!
Thanks...it is really good to hear that. : )
Originally Posted by FLIPC View Post
well done
It's a fantastic job!
Love It
Thank you. Please check out my next mineral oil system in the near future.
Old 16th Dec 2008, 02:16   #64
crazybob
Voice of Reason
crazybob's Avatar
crazybob has yet to learn the way of the Dremelcrazybob has yet to learn the way of the Dremel
Originally Posted by OilPC View Post
You probably wonder if the CPU or GPU works OK without thermal grease. I'm not an expert, but I think the gap between the heatsink and the CPU or GPU filled with mineral oil is not different from being filled with thermal grease anyway since the thermal grease is a foreign material made of silicone with all kinds of chemicals to fill the tiny scratches on the CPU or heatsink for improving heat transference. If thermal grease's heat transference is better than air, so is the mineral oil.
Actually, thermal compound offers worse heat transfer than even something as boring as plain water; the only advantage is that it doesn't dry out like water would (in fact, I've seen tests showing that toothpaste works better than thermal compound until it dries out). I'm willing to bet that mineral oil is considerably more effective than even the best thermal compounds. You couldn't do it in a normal computer because the oil would quickly run out or evaporate, but in your case it's almost certainly the best approach.
Have you taken any readings on those fans? I'm curious how much extra current they draw under that much load, and if you've noticed any longevity issues as a result. I apologize if you've already answered this question in one of your posts, but I didn't see it when I skimmed through the thread.
Again, this is by far the best oil-submerged computer I've ever seen. Brilliant work.
crazybob is offline   Reply With Quote
Old 16th Dec 2008, 04:10   #65
ModMinded
Are you throwing that away?
ModMinded's Avatar
ModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the Dremel
Aw shucks, you made me blush. Thanks for the nice comments as well as the links and info!
I'd imagine the next system will be even easier. The SSD drives probably don't have breathing holes I imagine (haven't been lucky enough to get my grubby paws on one.
I'm wondering if the fans are generating more heat actually, since they have to spin harder through the oil... might be an interesting experiment to go fanless (and throw an aquarium bubbler in there for effect!
__________________
My First Mod Log (Nzxt Lexa) (Ongoing) - What was that about idle hands?
ModMinded is offline   Reply With Quote
Old 16th Dec 2008, 04:38   #66
ROB 636
Ski-Ba-Bop-Ba-Dop-Bop
ROB 636's Avatar
ROB 636 has yet to learn the way of the Dremel
This was a interesting build that turned out great.
__________________
Nothing to see here
I'm not going to say where I got it from, lets just say that it was not the best buy I ever made.
ROB 636 is offline   Reply With Quote
Old 17th Dec 2008, 10:13   #67
Dreaming
Supermodder
Dreaming's Avatar
Dreaming has yet to learn the way of the Dremel
Hey I've just read through the worklog and how amazing! You do yourself a credit, and you're so modest as well! I would like something like this... although going to LAN parties and back and forth from University I might need to build up some more muscle .
You were saying you wanted to build a mini itx system but money might be an issue - might I suggest approaching some hardware suppliers and ask if they might sponsor you? The quality of your work is so high (really top level stuff) that I am sure companies would like to be associated with it.
I think there is an article on bit-tech.net about securing sponsorship with regards to mods somewhere. Best of luck with the future build though, I can't wait to see it.
__________________
Dreaming
C2D E6300 @ 2.8 | | Abit IP35 Pro | | 4GB Corsair XMS2 800 | | BFG 9800GT OC 1GB | | Antec NeoHE 550 | | Lian Li PC A05B (with top blowhole mod) | | LG 32LH4000 + Samsung 226BW 22"
Dreaming is offline   Reply With Quote
Old 17th Dec 2008, 20:23   #68
OilPC
Minimodder
OilPC's Avatar
I totally agree with you. Thanks for supporting my theory. Getting rid of thermal compound must be done if hardwares get submerged in mineral oil ,and mineral oil works ok (or better) as a thermal compound. I also don't need to worry about running out or drying out because there is plenty of oil in the system (28 liters).
Toothpaste as a thermal compound...that is interesting test ,and the result is pretty awesome too.
Fan's rpm is around 140 rpm ,and comparing with 2400 or higher rpm in the air, You can imagine how slow they spin in the oil. Since liquid is heavier and denser than air, the question is how long the fans will stand up to the stress of circulating oil. However, hotter the oil gets, easier for fans to spin. In my case, for over 2years, fans in my test system still spin fine.
Being in the oil probably helps the fans last longer since there is plenty of lubricant.
You're very welcome. Yes...the SSDs don't have any moving parts and breathing holes ,and it will be easy to play with oil...no worry...just dipping. I also haven't had a chance to use one yet though.
Emm...that's interesting question. I have never thought about that. The fans under stress like circulating liquid probably generate heat since they don't have ‘liquid’ rating. As I already told, I'm not an expert....I hope the heat is minimal ,and probably it is. Does any one have any thoughts? Anybody got a link to this issue?
For the 2nd system, I promise you will see more than bubbles.
Thank you for looking. The time I spend on my Oil PC has become more pleasant because now the system is almost noise free (since I have four 120mm fans on the radiators, It can't be 100% noise-free) and dust-free. Simply...I hate dust.
You must be a very talented patient reader. Thank you for your kind words.
Yes...28 liters of oil...it is heavy for sure. That is why...If I build another one like what I just finished, I will install Caster Wheels on the bottom of the case. Seriously...
Thanks for your suggestion. However, I think securing sponsorship wouldn't be that easy. In normal life, doing something on someone else's penny is almost impossible isn't it?
There must be so many people who want something for free. I will try though even though I am not sure how long I will be in the lineup.
Who knows...If my project or name keep being recognized by wonderful readers(members) like you, there might be a chance for me.
I wish you all the best before the year ends.
Old 17th Dec 2008, 21:03   #69
flare
Multimodder
flare has yet to learn the way of the Dremel
man gratz that is one cool mod, I feel for your arms , it must kill them to move it around
__________________
Click here to go to my mod in progress. Sponsored by Specialtech, Crucial, Thermaltake and Bitspower
flare is offline   Reply With Quote
Old 19th Dec 2008, 22:47   #70
OilPC
Minimodder
OilPC's Avatar
I never dare to lift it up. To move it around, I push it on the carpet.
Old 21st Dec 2008, 06:10   #71
Oreon_237
CHEA BRO!
Oreon_237 has yet to learn the way of the Dremel
simply amazing work
this is the first log i have seen of a fully submerged PC, and it is an excellent example of one.
the dark wood stain against the clean aluminium (yeah i spell aluminium with an i) angles running up the side, i think is a great contrast
looking forward to your next project log with the use of SSDs
__________________
Rigless.
Oreon_237 is offline   Reply With Quote
Old 21st Dec 2008, 07:43   #72
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
Truely superb work there! I've seen a number of oil-submerged-PCs, but none has been even nearly as well made as this one... It really seems like this beast can be used for years w/o any troubles if the components don't blow themselves up.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 1st Feb 2009, 04:52   #73
Skibo1219
Brains...the other white meat.
Skibo1219 has yet to learn the way of the Dremel
Wow! Just..WOW!
I was wondering about the submerged fan rpm, have you tried to reduce their drag by reducing the surface area? A few ways I thought of, shorten blade circumference, cut the width in half, or even removing full blades. Even the pitch of the blades would have an impact on its current draw and speed. I don't know how this would affect flow but the thought of creating a whirlpool inside that might have some bizarre lighting effects.
Skibo1219 is offline   Reply With Quote
Old 16th Feb 2009, 22:53   #74
Cheddarlump
What's a Dremel?
Cheddarlump has yet to learn the way of the Dremel
Interesting idea to vent HD's
I went a different route, and wish that I'd taken the same path you did..
I taped off the sata connectors, and dipped the HD's in epoxy to completely seal them. It worked, for quite a while, until the heat buildup in the drive forced the air to crack the epoxy.. I didn't reenforce the epoxy with anything.
Anyway, feel free to see another take: Cheddarlump's Submerged Machine
Also keep in mind, I did this in 2005..
Cheddarlump is offline   Reply With Quote
Old 7th Jun 2009, 12:09   #75
noobieocer
Minimodder
noobieocer has yet to learn the way of the Dremel
wow that is really cool, just wondering thou, dont the oil dry out through the space in between the expansion slots?
noobieocer is offline   Reply With Quote
Old 24th Jun 2009, 02:24   #76
longwing
69 Dude!!
longwing's Avatar
longwing has yet to learn the way of the Dremel
The bit with the hard drives is particularly brilliant. I myself am not that clever, I'm just planning to house them outside of the oil.
Of course, really, the whole thing is brilliant. I salute you sir.
longwing is offline   Reply With Quote
Old 24th Jun 2009, 10:10   #77
Daedelus
Multimodder
Daedelus has yet to learn the way of the Dremel
I have never seen an oil cooled system before like this. It is truly breathtaking! That takes skill, patience and bravery to build something like that
Daedelus is offline   Reply With Quote
Old 13th Aug 2009, 06:16   #78
|NoobixCube|
What's a Dremel?
|NoobixCube| has yet to learn the way of the Dremel
One Quick thing. Are you EVER able to replace or add components? As the mineral oil would jut move into the contact area's and wreck contact with components? Or can you somehow 'Wash' it off if you decided to remove the components from the oil?
|NoobixCube| is offline   Reply With Quote
Old 13th Aug 2009, 07:51   #79
youeffsee
Modder
youeffsee's Avatar
youeffsee has yet to learn the way of the Dremel
You make me proud to be Canadian. This is amazing in every way.
Would love to hear about the 6 month update you promised about. And it must be about time for another oil build from ya.
youeffsee is offline   Reply With Quote
Old 29th Aug 2010, 09:25   #80
Tvorman89
What's a Dremel?
Tvorman89 has yet to learn the way of the Dremel
Contemplating Oil Cooling System!
Hi there OilPC I was just wondering if your system is still running smoothly as I am strongly considering doing a similar setup.
Regards,
Trevor
P.S. I love your case and all the hard work you have done obviously paid off. Good job man!
Tvorman89 is offline   Reply With Quote
Reply
Tags
cooling, mineral, oil, submerged, system
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
