RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Nov 2008, 08:25   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Gainward Radeon HD 4870 1GB Golden Sample
http://www.bit-tech.net/hardware/200...olden-sample/1
Gainward has completley redesigned the Radeon HD 4870 1GB from the PCB up. It has built an overclocked dual slot, dual fan, dual BIOS card which even packs in a fantastically old school turbo switch! Read on to find out how it fares in the ever competitive world of high performance graphics...
Tim S is offline   Reply With Quote
Old 18th Nov 2008, 09:06   #2
Xtrafresh
Blame it on the Boogie
Xtrafresh's Avatar
Xtrafresh is a jewel in the roughXtrafresh is a jewel in the roughXtrafresh is a jewel in the rough
Originally Posted by last page, 1st paragraph
...pleasant 33°C at load and then just 59°C at idle...
Shurely you mean the other way around?
Also, while i think your conclusion is pretty solid (not worth the 30 extra pounds), i do think you should have mentioned two of it's merits in the round-up: power consumption and the shorter PCB. It may not be much, but both are potential buying decisions. Also, if the rest of your system is struggling to cool, it will certainly be worth sticking a card in there that's 35 degrees cooler in all scenarios . In other words, you conclusion is too much FPS, and too little other stuff
Xtrafresh is offline   Reply With Quote
Old 18th Nov 2008, 10:49   #3
Baz
Benchmarketeer
bit-tech Staff
Baz's Avatar
Baz is on a distinguished road
While the PCB is shorter, it is only one centimetre shorter - such a small difference in board length is unlikely to have an enormous impact on whether the card will fit in your case or not. In regards to power consumption, while the 30W saving at load is certainly a nice bonus, it doesn't justify the price difference - Even if your electricity is cheap (say 22p per KW/H), you'd need to run the card at continuous peak load for a full 187.5 days to recoup the extra £30 investment.
And while the card does run cooler, the dual slot nature of the stock 4870 cooler means that it really doesn't cook the inside of your PC like the 4850 can. Add in the fact that you can't use that extra cooling headroom to overclock thanks to the BIOS compatibility problems, and they all become issues that just aren't worth mentioning in a full review
Baz is online now   Reply With Quote
Old 18th Nov 2008, 11:02   #4
rpsgc
Multimodder
rpsgc's Avatar
rpsgc is on a distinguished road
I'm sorry but I can't agree with the conclusion. I know a whole lot of people who'd gladly pay that £30 price premium, even tough there is pretty much NO price premium for it in the rest of Europe (must suck living in the UK eh?), for a card with this kind of performance whilst consuming little power over a HD 4850!
__________________
Death to consolification !!!
rpsgc is offline   Reply With Quote
Old 18th Nov 2008, 11:03   #5
psychoti
Multimodder
psychoti is on a distinguished road
what about the noise of the card?
__________________
i5 750@3.6GHz//Noctua NH-U12P//MSI P55-GD80//4GB DDR3 Corsair XMS3@1600MHz//SB Platinum 2//Asus 8600GT//Corsair HX850W//Lian-Li V2000B
Lian-Li pc-0070
Lian-Li V2000B
psychoti is offline   Reply With Quote
Old 18th Nov 2008, 11:25   #6
Baz
Benchmarketeer
bit-tech Staff
Baz's Avatar
Originally Posted by Review
What’s even better is that the Gainward 4870’s cooler accomplished these excellent thermal results while also being extremely quiet into the bargain, although the 4870’s stock cooler was admittedly very quiet throughout testing too.
Also, I've only just noticed some errors on the power consumption page (I'd accidentally compared the card to a 4870 512 rather than a 4870 1GB). Power consumption at idle is roughly the same at idle, but is 19W lower at full load - apologies!
Old 18th Nov 2008, 12:10   #7
Xtrafresh
Xtrafresh's Avatar
sorry if the message came across wwrong. It's a great review as always! I also said the conclusion is fine, i just think the benefits should have been included
Old 18th Nov 2008, 13:05   #8
Bladestorm
Hypermodder
Bladestorm is on a distinguished road
After an incident with a golden sample 6800GT card that artifacted heavily at stock and flat out crashed at the factory overclocked speeds, which went off for RMA, dissapeared for 6 months, then came back with a fan changed but still artifacting/crashing, I won't go anywhere near gainward.
__________________
Athlon 64 X2 3800+ @ 250x10 (1.475v) | EVGA GTX 260 55nm SSC | A8N-SLI Premium | 2x(4GB) Corsair Twinx2048-PC3200C2 | Asus Xonar DX | Antec truepower 550w | Akasa Eclipse-62 DDC12VPlus1, DD TDX, 3/8 tygon r3603 tubing, PA120.2, DD double floppy bay res
Bladestorm is offline   Reply With Quote
Old 18th Nov 2008, 13:22   #9
xaser04
Multimodder
xaser04's Avatar
xaser04 is on a distinguished road
The following card is £45 cheaper than this gainward card yet as far as I can see its the same:
http://www.tekheads.co.uk/s/product?product=609657
This despite its marketed name is a Palit sonic (read overclocked) model which features the same PCB and the same cooler (I would go as far as to say its the same card merely rebadged) as this Gainward card.
Why on earth would you spend an extra £45 for the same (or near enough identical) card?!
__________________
Scientology - A Religion for those who think Star Trek is a documentary
xaser04 is offline   Reply With Quote
Old 18th Nov 2008, 13:24   #10
xaser04
Multimodder
xaser04's Avatar
EDIT to my above post: It looks as though the backing plate is slightly different (Palit is lacking the vents and the displayport?!)
Other than that its the same thing.
__________________
Old 18th Nov 2008, 14:59   #11
SubtleOne
Minimodder
SubtleOne is on a distinguished road
Sadly, our overclocking adventures ended here, as none of the overclocking tools available to us were able to effectively adjust the card’s clock speeds – an issue related to an incompatibility between the card’s custom switchable dual BIOS and the various popular overclocking utilities.
Actually, Rivatuner is incompatible with ATI drivers version 8.55.1 (AKA Hotfix#2) and the latest WHQL 8.11. It isn't a BIOS problem. Try 8.10 and you'll see your OC limitations disappear.
SubtleOne is offline   Reply With Quote
Old 18th Nov 2008, 18:41   #12
gebbly
What's a Dremel?
gebbly is on a distinguished road
If you want an identical card but badged as Palit rather than Gainward then as far as I can tell try http://www.ginger6.co.uk/palit-radeo...l-p-31515.html which is the same right down to the vent and rear connectors
gebbly is offline   Reply With Quote
Old 18th Nov 2008, 21:20   #13
WildThing
Multimodder
WildThing's Avatar
WildThing will become famous soon enough
Well, I've had this card for barely a week, and I'm happy with it so far. I must agree with the review though, I think a 7 is pretty fair. I was appauled at the bundle or lack of should I say lol! I was thinking about getting a stock 4870 1GB, but I guess I'm just a sucker for having things running cool AND quiet, which so far is exactly what I've got.
__________________
Asus M2N-SLI DELUXE ¦ AMD Athlon64 6000 ¦ Gainward GS 4870 1GB ¦ 2x2GB OCZ DDR2-800 Reaper ¦ Seagate Barracuda 7200.11 500GB ¦ Auzentech XFI-Prelude + Creative T7700 7.1¦ Enermax Liberty 500W ¦ CM690 case ¦ Samsung 22" 226CW ¦ Vista x64 SP1
WildThing is offline   Reply With Quote
Old 18th Nov 2008, 21:24   #14
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
VGA really??? come on.. seriously... just drop it already ~_~ I think I like this arrangement a bit more then their x2 version which is three bays granted it does have a nice cooler on it but just the same companies should aim for no more then two bays being occupied.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 19th Nov 2008, 09:56   #15
[USRF]Obiwan
Ultramodder
[USRF]Obiwan is on a distinguished road
So basically you get a GPU cooler upgrade with lesser hardware components with no overclock possibility.
I rather buy a very good third party cooling solution and overclock the hell out of it if possible.
__________________
Mascleta: "The most accurate simulation of thunder, humans can simulate..."
The answer is 42, so... whats the question again?
If you know what 'Peek' and 'Poke' represents, then you are probably as old as me.
[USRF]Obiwan is offline   Reply With Quote
Old 19th Nov 2008, 13:47   #16
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Indeed, parent company.
Bindibadgi is online now   Reply With Quote
Old 21st Nov 2008, 01:30   #17
cyrilthefish
Hypermodder
cyrilthefish's Avatar
cyrilthefish will become famous soon enoughcyrilthefish will become famous soon enough
A native displayport and hdmi port on the card?
*SOLD*
First non-mediacentre-ish video card i've seen with either of those ports native on them!
Got the 512MB version on order with scan now
__________________
AMD Phenom x3 720 @ 3.4Ghz | Gigabyte GA-MA785GMT-UD2H | 4GB DDR3 | ATI 4890 1GB| 1TB Samsung F1 | 64GB Corsair P64 SSD
cyrilthefish is offline   Reply With Quote
Old 22nd Nov 2008, 19:23   #18
karsh
What's a Dremel?
karsh is on a distinguished road
got this card myself, sure the oc is a bit low still works great and is very quiet and cool
i wouldnt buy the 512mb version unless they "fixed" it, the 512mb has only one temperature controlled fan if i remember right the port layout is diffrent too and some other "little" bugs
karsh is offline   Reply With Quote
Old 30th Apr 2009, 03:12   #19
atilla101uk
What's a Dremel?
atilla101uk is on a distinguished road
*SOLD*
Palit have been doing them for a little while now i.e. 9600gt sonic and also the 9800gx2's had hdmi ports on them
I'd just like to say that as a user of a thermaltake dh101 it does matter about the length of the board not just for fitment reasons but also for airflow reasons.
atilla101uk is offline   Reply With Quote
Old 30th Apr 2009, 03:44   #20
thehippoz
sea grogin
thehippoz's Avatar
thehippoz is a glorious beacon of lightthehippoz is a glorious beacon of lightthehippoz is a glorious beacon of lightthehippoz is a glorious beacon of lightthehippoz is a glorious beacon of light
dunno if you guys used gainwards expertool before.. pretty neat little oc utility http://www.gainward.com/main/support.php?lang=en
thehippoz is offline   Reply With Quote
Reply
Tags
gainward, golden sample, radeon hd 4870 1gb
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
