Thread Tools |
#1 |
Richard Swinburne
bit-tech Staff
Kanguru announces eSATA pendrive
http://www.bit-tech.net/news/2008/11...ata-pendrive/1
Kanguru has announced the availability of a rather novel pendrive featuring both USB 2.0 and eSATA 3Gb/s connectivity, with a surprising difference in performance between the two.
#2 |
Hypermodder
What happens if you connect both ends at once?
#3 |
WIIGII!
It creates a vortex in the space/time continuum, which will eventually swallow all matter and destroy the universe.
Alternatively, it simply chooses whichever connection initialised first - which is likely to be the eSATA port. |
#4 |
BSc... finally
It explodes.
Nice gadget but pretty expensive. Although... is it bootable? It's not, right?
__________________
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far." Blame it on Cheaps! [now a social group]
#5 |
WIIGII!
Can't think why it wouldn't be - BIOS support depending, of course. Heck, my no-name 32MB USB1.1 pendrive boots just fine - and an eSATA device appears to the system as a standard SATA drive (heck, if you use the included bracket adapter it /is/ a standard SATA drive, as that connects to a normal internal SATA port on the motherboard.)
#6 |
Just some guy; you know
Unlike USB eSata does not provide power right? So for use with eSata you would need the usb cable plugged in aswell I would assume.
__________________
| taliban_raider |
| View Public Profile |
| Find More Posts by taliban_raider |
#7 |
Officious Bystander
How come it can read through eSATA at 75 MB/s but only 30 MB/s through USB? I guess what I mean is, I know there are bus overheads etc., but why does USB 2.0 (which is rated at 480 Mbps = 60 MB/s) seem to limit a flash drive which is demonstrably capable of reading at 75 MB/s to just half the rated bandwidth of the USB connection?
__________________
Demand Naked DSL in the UK! |
#8 | |
mother into a board?!
__________________
AMD Athlon 64 X2 4400+ S939 | 3GB of Corsair/Kingston (mix) RAM @ 400Mhz 3-3-3-8-2T | ASUS A8N32-SLI *Deluxe* | Geforce 260 GTX | X-Fi XtreamMusic | Western Digital 250GB SATA-II 16MB of Buffer | Corsair HX620W | Antec SOLO case | Monitor: 24inch Dell U2410 | Win 7 64-bit Go for Pro! |
#9 |
Supermodder
It's using a proprietary esata connection that provides power, you actually must use the included bracket as it adds the power to the esata connector.
__________________
My gun kata is greater than your kung fu.
| Lazarus Dark |
| Find More Posts by Lazarus Dark |
#10 |
a.k.a KazeModz
huh well this is certainly interesting, so they are using the new eSata standard that combines both power and data unlike the current eSata standard which is just data. I wish we would make the move to that standard sooner so it would makes sooo much easier and require less cables....
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#11 |
I pickle they
sweet.. I wish this was cheaper though
| Thread Tools | |
