RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Nov 2008, 08:31   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
DFI LANParty JR P45 T2RS
http://www.bit-tech.net/hardware/200...-jr-p45-t2rs/1
In a step away from the norm for P45, DFI has made a cute little micro-ATX motherboard that it dubs its "Junior". Except, this JR model still supports CrossFire and has a DFI belly - do good P45 motherboards come in small packages? Let's find out.
Tim S is offline   Reply With Quote
Old 24th Nov 2008, 09:52   #2
bubsterboo
Hypermodder
bubsterboo's Avatar
bubsterboo is on a distinguished road
My friend bought one of these and he's pretty pleased with it. Cheap for a DFI board. Solid little performer. No complaints.
__________________
DFI LANPARTY UT P35-T2R - Q6600 @ 3.4ghz - 8GB OCZ Platinum - evga 9800gx2 - 2x500gb seagate, 1x250gb hitachi, 1x320gb seagate, 1x1tb samsung - Benq FP241W
bubsterboo is offline   Reply With Quote
Old 24th Nov 2008, 10:25   #3
phuzz
Hypermodder
phuzz's Avatar
phuzz is on a distinguished road
Pliers. They'll get that screw out. I've even disassembled a harddrive using a pair of pliers to turn the screws when I didn't have the right bit for my screwdriver.
I've been kind of thinking about an mATX based gaming rig recently, after all, why do you need a full ATX board?
phuzz is offline   Reply With Quote
Old 24th Nov 2008, 14:20   #4
mclintox
Get the jigsaw out!
mclintox's Avatar
mclintox is on a distinguished road
The rear I/O seems a bit sparse of features for a board of this price,esp the lack of esata and a few extra usb ports,or am i being a bit picky?
mclintox is offline   Reply With Quote
Old 24th Nov 2008, 15:59   #5
Andreoid
Minimodder
Andreoid is on a distinguished road
i love this board
and anfi-tec allready have waterblocks for this
Andreoid is offline   Reply With Quote
Old 24th Nov 2008, 16:19   #6
EnglishLion
working for the good of mankind...
EnglishLion's Avatar
EnglishLion is on a distinguished road
great as a uATX portable LAN box motherboard. That reset CMOS on the back IO panel shouldn't be too difficult to deal with after all it's not like you'll be reaching round the back of a huge coolermaster or Lian li case in this instance. Reaching round the back is pretty easy with a SFF but what can be more difficult is reaching an internal motherboard jumper as SFF cases often have little wriggly room inside!
EnglishLion is offline   Reply With Quote
Old 24th Nov 2008, 16:26   #7
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
But for the cost, why not just have a teeny tiny switch ala Abit used to do??
Bindibadgi is online now   Reply With Quote
Old 24th Nov 2008, 16:47   #8
mascotzel
What's a Dremel?
mascotzel is on a distinguished road
"where the JR P45 doesn't have quite the level of thoughtfulness other DFI products have been given...no Firewire, no eSATA (yet there could easily be)"
I doesn't seem that you know DFI to well
I have yet to see eSATA on any DFI board...as for firewire,they have it only on UT ( the most expensive ones) series
and the CMOS jumper is quite on a lot of their boards
mascotzel is offline   Reply With Quote
Old 24th Nov 2008, 17:01   #9
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Fair enough. Perhaps I should have said compared to the competition then. I've only ever infrequently looked at high end boards to date.
eSATA especially - they use a JMicron chipset already for IDE, so one for IDE+2 SATA is little more for a useful extra.
As I said above, the CMOS jumper should be a very small momentary switch or two position one.
Old 24th Nov 2008, 17:04   #10
SPQQKY
Evil Modder
SPQQKY's Avatar
SPQQKY is an unknown quantity at this point
Way too much money for a mATX board, especially with very little features. No point in this board, really. Crossfire on an mATX board is silly and defeats the purpose of small form factor. Why have mATX if you are going to shove two gfx cards on it. Can get better boards for a lot less. This board seems completely useless to me. Just my two cents. Can anyone really tell me the benefit of this board?
__________________
I could be bounded in a nutshell and count myself a king of infinite space, were it not that I have bad dreams.
Core2Duo E8400 @ 4GHz - Gigabyte GA-EP45-UD3P - 4 x 2 GB G.Skill Pi Black-6400C4 - eVGA GeForce GTX 260 - Auzentech X-Plosion
1 x 250GB and 2 x 300GB Barracuda - LaCie 1TB BD - Corsair CMPSU 620HX - etc., etc.
SPQQKY is offline   Reply With Quote
Old 24th Nov 2008, 17:15   #11
naokaji
whatever
naokaji's Avatar
naokaji will become famous soon enough
Well, if you dont run any other cards than Graphicscards then a Matx board is big enough, besides, it saves a lot of space in a regular size case which can be used for WC Gear or you can go for a small and great looking case like Silverstone Crown Series.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S
Opportunity is like delivery by DHL, it does not come to you, you have to track it down and chase it
naokaji is offline   Reply With Quote
Old 24th Nov 2008, 17:44   #12
IanW
I *am* a Dremel
IanW's Avatar
IanW is a jewel in the roughIanW is a jewel in the roughIanW is a jewel in the rough
If anyone really wants eSATA with this board, go hunting for the PCI converter dongley thing that Gigabyte supply with their boards.
Much more useful than a fixed eSATA on the rear which you'll never use because you can't see back there to fit the cable
__________________
Q6600@3GHz / AC Freezer 7 Pro / Gigabyte EP35-DS3R / 8GB OCZ Platinum PC6400 / EVGA GTX260 SSC / LG DVDR / 9TB HDD /
OCZ Modstream 780W / CoolerMaster 590 case / Dell E248WFP / Saitek Eclipse II / Logitech G9 / Ubuntu 9.10-64
IanW is online now   Reply With Quote
Old 24th Nov 2008, 19:33   #13
Ending Credits
Hoot if you're a revowlutionary.
Ending Credits's Avatar
Ending Credits is a glorious beacon of lightEnding Credits is a glorious beacon of lightEnding Credits is a glorious beacon of lightEnding Credits is a glorious beacon of lightEnding Credits is a glorious beacon of light
Someone on BT will make a mod for this soon enough.
Also, have you checked the box, my board came with some elongated jumpers IIRC, certainly usefull if your case is a pain to open like mine.
__________________
A Little Game I made in Leadwerks
AMD Phenom 9850 Black Edition || DFI 790FXB-M2RSH || Powercolour ATI 4870 1GB || 4GB 1066Mhz GEIL Black Dragon || Aplus Black Pearl WCR || Yurak 24" PVA || 19" Hanns-G || Vista 64-bit
AMD Phenom 9500 || GIGABYTE GA-M720-US3 || MSI 7600GT || 2GB DDR2 1066Mhz || bequiet 350W
Ending Credits is offline   Reply With Quote
Old 24th Nov 2008, 20:03   #14
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
I was considering getting this for my SFF gaming rig that I take with lans but I think a single x16 lane with a 4870x2 would probably do me better then two x8 lanes.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 24th Nov 2008, 21:42   #15
metarinka
I *am* a Dremel
metarinka's Avatar
metarinka is on a distinguished road
I thinking about this board the only features missing are the ones I don't use (esata, firewire) and I don't care about onboard sound quality I got a $500 soundcard I've been using
metarinka is offline   Reply With Quote
Old 24th Nov 2008, 23:39   #16
icutebluezone
The meaning of life is to MOD
icutebluezone's Avatar
icutebluezone is on a distinguished road
Very nice board. about time another dual grahics M-atx came out was wanting one couple months ago. but not now. But its still bloody nice that photo of it is nuts.
http://images.bit-tech.net/content_i...5-t2rs/9-8.jpg
Just seen there is a full atx like it.
__________________
Hope no one see's me modding this
icutebluezone is offline   Reply With Quote
Old 7th Dec 2008, 14:19   #17
ParaHelix.org
Supermodder
ParaHelix.org is on a distinguished road
I have been looking for some time to build a media center for my front room, parhaps this is the right board?
ParaHelix.org is offline   Reply With Quote
Old 5th Jan 2009, 06:31   #18
icutebluezone
In your review you have: Four DDR2 memory sockets supporting up to 16GB of memory at 667-1,066MHz.
Its only surepose to be: 8gb total ram.
Unless you no sumthing dfi dont no. hehehe.
__________________
Reply
Tags
dfi, lanparty, matx, microatx, motherboard, p45, review, sff
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
