Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 25th Nov 2008, 01:28   #1
morris8809
Supermodder
morris8809's Avatar
morris8809 has yet to learn the way of the Dremelmorris8809 has yet to learn the way of the Dremel
Best way to remove old paint (Acetone works great!)
hey all bit-techers, on my current pc case im in the process of modding im trying to figure out how im going to clean off all of this old paint that i dont want on it. I have been in search locally to find someone who has a sandblaster but i have not had any luck as of yet. So my next best option would be chemical strippers so what would you all recommend? thanks in advance.
__________________
|Lian-li A70F (Case)|Gigabyte EP45-UD3P (Motherboard)|Intel® C2Q 9400 @ 3.7Ghz (Processor)|
|G-Skill 4GB DDR2 1066mhz (Memory)|EVGA GTX260-216 (Graphics)|
|Corsair 650HX (Power Supply Unit)|Creative Fatality Progamer PCI (Sound Card)|
|2x 1TB WD Black, 750GB Seagate (Storage)|
morris8809 is offline   Reply With Quote
Old 25th Nov 2008, 03:46   #2
Rocket733
Austerity - It's the only way
Rocket733's Avatar
Rocket733 has yet to learn the way of the Dremel
Chemical strippers work well as long as it isn't powder coated. Another option is to use a heat gun to get it off, of course this only works on metal components.
Rocket733 is offline   Reply With Quote
Old 25th Nov 2008, 04:58   #3
daveppeters
Minimodder
daveppeters has yet to learn the way of the Dremel
There's always the tried and true method - Sandpaper!!
__________________
MSI 945P Neo3 / 1GB DDR2 PC2-6400 (Dual-Channel) / Intel Pentium D 935 (3.2GHz) / NVidia GeForce 7600 GT / SB Live! X-Gamer 5.1 / Samsung SpinPoint 160GB SATA-II HD / Seagate Barracuda 80GB SATA-II HD / Toshiba 8X DVD / Samsung SATA DVD Burner / Win XP Home/Vista Dual-boot
daveppeters is offline   Reply With Quote
Old 25th Nov 2008, 05:19   #4
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
Paint is often soluble with elbow grease.
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 25th Nov 2008, 12:04   #5
morris8809
Supermodder
morris8809's Avatar
i have been sanding on the parts that are easily sandable but some of the parts like the rear i/o plate area and pci bracket are giving me a headache with all of the tight areas.
__________________
Old 25th Nov 2008, 12:08   #6
marcus000
Watercooling Mad
marcus000's Avatar
marcus000 has yet to learn the way of the Dremel
Nitromorse is the easiest option, paint it on and peel off the old paint.
You need a decent area to do it though because it's strong stuff.
Alternatively, some paints like Halfords spray cans can be removed with some decent paint thinners providing it hasn't been clear coated.
marcus000 is offline   Reply With Quote
Old 26th Nov 2008, 02:44   #7
morris8809
Supermodder
morris8809's Avatar
well i figured out probably the easiest way to remove paint. Use acetone. You just pour it on the paint you want to remove, wait about 10-30 seconds and wipe away with paper towel. no more paint. It worked on the old paint thats on the case and even took the primer off. Now i need to try it on the factory grey chassis paint to see if it will remove that.
__________________
Reply
Tags
modding, paint, paint removal, painting
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
