Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 21st May 2009, 19:50   #101
ry@n
Ultramodder
ry@n's Avatar
ry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysisry@n can run Crysis
No problem mate, have fun. I racked up 143 hours according to xfire!
__________________
Stacker 830 Evo //Core i7-920 ~ 4Ghz (4.2 stable) //Gigabyte EX58-UD5 //Corsair Dominator 6GB 1600Mhz //BFG GTX 285 OCX //BeQuiet! 750w //Samsung F3 1TB
DDC Ultra 18w //Black Ice 360mm //EK Multioption 250mm //Heatkiller LT CPU Block //MIPS RAM block
DDC Ultra 18w //Black Ice 240mm //EK Multioption 150mm //No Blocks yet
- Dual Loop i7 Stacker Left Handed? CLICK HERE -
ry@n is offline   Reply With Quote
Old 13th Jul 2009, 04:25   #102
Hedimitrius
What's a Dremel?
Hedimitrius has yet to learn the way of the Dremel
GTA 4
I know I'm late but I just bought GTA 4 for pc. Got home, installed, before even playing I did some patch searching and installed a main title patch. Tried to play and as soon as it starts showing the ship, there is some sort of glitch where I actually can only see the ship on some screens, the mouse is lagging behind horribly, as well as gameplay, and I cant see anything a foot past the front of the car. I've spent a lot of time looking for a general fix, and found a "stability" patch, but it made no difference. Running 800x600 with all settings on low. My computer:
Intel duo core 3.0g
500g hd
2g memory
512m xforce vid card
If anyone knows of a possible cause, or even better a fix to these issues, please respond at your convenience. Thanks in advance,
Jeremy
Hedimitrius is offline   Reply With Quote
Old 13th Jul 2009, 10:34   #103
Paradigm Shifter
de nihilo nihil fit
Paradigm Shifter's Avatar
Paradigm Shifter has yet to learn the way of the DremelParadigm Shifter has yet to learn the way of the Dremel
'512MB xforce vid card' can cover a heck of a lot of possibilities from something like a low-end series 6 card to a GTS250. Some more detail is needed there. The nVidia driver panel should tell you exactly what model card you're using.
Other than that, try updating your graphics drivers... or if you're using the latest ones, try a slightly older set.
__________________
Core i7 920 D0 @ 3.8GHz | 24GB Corsair 1600MHz | Gigabyte G1.Killer Guerilla | GTX680 Surround | 3TB | 5760x1200+1920x1080
Paradigm Shifter is offline   Reply With Quote
Old 28th Apr 2012, 21:30   #104
Nenad96
What's a Dremel?
Nenad96 has yet to learn the way of the Dremel
Easy way to play gta 4 and eflc.on poor pc
Originally Posted by widmod View Post
I bought the game yesterday (relase day)
after installing it for over a hour i got a message i have to install a games for windows update to my relase day version!!
then my minimum systems reqirements laptop system produced a message like: heavy error:dd52d. a senseless message
i then installed the game on my broters quad core.
another insallation time later and varoius tweak i finnaly could start the game after the second try. now i have a playable version but it dead slow (on a quad core!!) perhaps its the problem is the GPU.
so don't even think off that the minum system reqirements mean that you can play the game with such a system.
So'll go back to plan A: Build a PC after knowing the maximum requirements of the GTA IV PC version
u just have to download commandline,and ectract to roct...gta 4,and u will play it on high.that is a good hack.and download gb3.for boost your pc.my name is nenad96
Nenad96 is offline   Reply With Quote
Reply
Tags
epic fail, grand theft auto iv, gta iv
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
