Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 9th Dec 2008, 13:05   #1
CardJoe
Freelance Journalist
CardJoe's Avatar
CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.CardJoe is the Cheesecake. Relix smiles down upon them.
Six critical updates for Patch Tuesday
http://www.bit-tech.net/news/2008/12...atch-tuesday/1
Microsoft has released its monthly Patch Tuesday updates, and there are six fixes for security holes rated as 'Critical' covering Windows, Internet Explorer, and Office.
__________________
I was Bit-tech's Games Editor. Now I'm freelance. Find me at:
www.joemartinwords.com
@joethreepwood on Twitter
CardJoe is offline   Reply With Quote
Old 9th Dec 2008, 17:38   #2
outlawaol
Geeked since 1982
outlawaol's Avatar
outlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysisoutlawaol can run Crysis
Hoorah for updates! Boo for restarts!
__________________
40D| 350D | 24-105 f/4L | 24-70 f/2.8 Sigma | 50mm f/1.8 | 75-300 f/4-5.6 Sigma | 420ex Speedlight
365 Daily Photograph | Smugmug
outlawaol is offline   Reply With Quote
Old 9th Dec 2008, 17:41   #3
teamtd11
*Custom User Title*
teamtd11's Avatar
teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.teamtd11 is definitely a rep cheat.
I can not see them on windows update yet, guess they will appear later.
I never bother restarting. just tell it to go away till i shut down at night
__________________
i7 6700k @ 4.6Ghz - Asus Sabertooth Z170 S / EK Z170 S Monoblock - 16GB DDR4 3Ghz Corsair White LED RAM - GTX1080 Founders @ 2,126 MHz / EK Full Block
teamtd11 is offline   Reply With Quote
Old 9th Dec 2008, 18:18   #4
TomH
Bwahahahahaha
TomH's Avatar
TomH has yet to learn the way of the Dremel
You can just disable the automatic updates service once the updates are complete. It won't bug you then, and you can quite happily continue working until you would like to shut down.
__________________
Blog: full of inspirational geekism. Maybe.
TomH is offline   Reply With Quote
Old 10th Dec 2008, 12:07   #5
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
Ignoring the Itanium versions, our WSUS server is downloading 1.5Gb of patches today, admittedly that's the full fat versions of each patch for each different OS (and another for the x64 version of each), but it still feels a bit over the top.
phuzz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
