Go Back   bit-tech.net Forums > Technology > Tech Support
Reply
Thread Tools
Old 15th Dec 2008, 12:33   #1
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the DremelBlademrk has yet to learn the way of the Dremel
Solved - Sata HDD keeps running CHKDISK on bootup
I'm running XP MCE / Vista 64 Ultimate dual boot (although I'm also having problems with Vista - but that's down to a logitech keyboard driver problem that I'll need to work around).
On boot-up (before the windows log in) CHKDISK runs on my F: Drive everytime I switch the PC on. I think it's either about to fail or has some bad sectors on it (but I'm not 100% sure) as some of my mp3's have become corrupted and so I've moved (almost) everything off it.
The HDD is used as the 'My Documents' System Folder (for both XP and Vista).
I've tried running the scandisk option, the Defrag option and even the format disk option from the disk utilities context menu but no matter what I select it tells me that CHKDISK is scheduled to run at next boot-up and therefore will not run any of the utilities from within windows.
Any ideas as to what's going on?
Thanks,
Mark.
__________________
My X-Box Live, PSN & X-Fire GamerTag: BladeMRK
Blademrk is offline   Reply With Quote
Old 15th Dec 2008, 17:50   #2
mrb_no1
Pie Eater
mrb_no1's Avatar
mrb_no1 has yet to learn the way of the Dremel
i've had this happen on 2 occasions....
1) the hdd in my folks pc was connected to a sata card, and for some reason the card went faulty and would force windows to run chkdsk every other time as it would corrupt itself within windows. My solution there was an upgrade for them, so a new mobo we brought and the drive now functions 100% properly in windows. note: several formats, including zero level formats were completed before change.
2) and the more likely option... your drive is knackered, if its seagate, try seatools as they can sometimes repair bad sectors or atleast confirm that the drive is on the fritz and then you can rma it to them. if it isnt seagate, i'm sure your particular manufacturer has something similar to help. seen as you've moved your data off of it, rma'ing isnt a bad idea imo, they are pretty swift these days.
hope it helps,
peace
fatman
__________________
Core 2 Quad Q6600 @ 3600Mhz ¦ Asus Maximus II Formula ¦ ATI Radeon 4890 (1000Mhz Core + 1200Mhz Mem OC) ¦ 2x2G Corsair Dom. PC 8500 @ 1080Mhz ¦ Aquacomputer WC ¦ Creative X-Fi Fatal1ty ¦ 150G Raptor, 2x1500 + 1x750 + 2x500 Seagate (SATA2) ¦ Pioneer DVD burner ¦ Lian Li - PC 73SL Aluminium Silent Server Case ¦ Dell 2007WFP 20" Widescreen ¦ Logitech Z-5500 5.1 Speakers ¦ Sennheiser HD270
mrb_no1 is offline   Reply With Quote
Old 15th Dec 2008, 21:03   #3
ModMinded
Are you throwing that away?
ModMinded's Avatar
ModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the Dremel
You might try the suggestions in this link:
http://www.pcreview.co.uk/forums/thread-72388.php
good luck
__________________
My First Mod Log (Nzxt Lexa) (Ongoing) - What was that about idle hands?
ModMinded is offline   Reply With Quote
Old 16th Dec 2008, 09:41   #4
Blademrk
Why so serious?
Blademrk's Avatar
Cheers guys, I'll look into those.
__________________
Old 16th Dec 2008, 10:31   #5
Akava
Lurking...
Akava's Avatar
Akava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the DremelAkava has yet to learn the way of the Dremel
good luck
Thanks for this link, my mothers PC has been running check disk every time it started for a few weeks now, I ran the fsutil dirty check and the cleaning operation for it last night and it worked a treat.
__________________
The Mini Rig: Samsung NC10
The Main Rig: Intel Core 2 Quad Q6600 ~ 3.0 | Artic Cooling Freezer 7 Pro | Asus P5E | 8GB OCZ Gold DDR2 1066MHZ | ATI HIS HD4870 | 640GB WD : 1TB WD | Coolermaster CM690 | Dell 2407 24" | Razer Lycosa | Razer DeathAdder
Akava is offline   Reply With Quote
Old 16th Dec 2008, 22:08   #6
Blademrk
Why so serious?
Blademrk's Avatar
Cheers guys, worked a treat.
__________________
Old 16th Dec 2008, 23:50   #7
ModMinded
ModMinded's Avatar
Great! Glad to hear it!
__________________
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
