RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 18th Dec 2008, 13:09   #1
CardJoe
Player Character
bit-tech Staff
CardJoe's Avatar
CardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to beholdCardJoe is a splendid one to behold
Spore de-authorisation tool released
http://www.bit-tech.net/news/2008/12...ool-released/1
EA has released an official de-authorisation tool for Spore, while a Ubisoft patch corrects widescreen issues in Far Cry 2.
__________________
CardJoe is offline   Reply With Quote
Old 18th Dec 2008, 13:21   #2
WildThing
Multimodder
WildThing's Avatar
WildThing will become famous soon enough
So all this time people playing Far Cry 2 with widescreen monitors have had this bug??!! Can't believe they have only just released a fix!
__________________
Asus M2N-SLI DELUXE ¦ AMD Athlon64 6000 ¦ Gainward GS 4870 1GB ¦ 2x2GB OCZ DDR2-800 Reaper ¦ Seagate Barracuda 7200.11 500GB ¦ Auzentech XFI-Prelude + Creative T7700 7.1¦ Enermax Liberty 500W ¦ CM690 case ¦ Samsung 22" 226CW ¦ Vista x64 SP1
WildThing is offline   Reply With Quote
Old 18th Dec 2008, 13:23   #3
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul has a spectacular aura aboutBauul has a spectacular aura about
And was there any point in including the DRM in Spore in the first place?
*checks piracy figures*
No.
It's the same thing that happened in Bioshock, the widescreen view is a vertically reduced version of the 4:3 view. It's not a bug per say, just a developer's choice, but unfortunatly one that a lot of people don't agree with. I happen to agree. You have normal monitors and widescreens, not tall screens and normal ones. Widescreens should have wide viewing angles.
__________________
Pentium 4 CPU 3.4 Ghz | 1Gb + 2x512Mb Corsair DDR2 667 Mhz
Sapphire Radeon HD 4770 512Mb| WD Raptor 36Gb, Seagate 300Gb | Asus P5LD2 SE
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 18th Dec 2008, 13:42   #4
faugusztin
Minimodder
faugusztin is on a distinguished road
But bad day for European Steam customers (except UK).
faugusztin is offline   Reply With Quote
Old 18th Dec 2008, 14:53   #5
karx11erx
Multimodder
karx11erx is on a distinguished road
And you still can't user proper wide screen in FC2 multiplayer! Now why is that? In order not to put 4:3 screen users at a disadvantage? So they happily put the widescreen owners at a disadvantage. In my book the people responsible for FC2 are the most incapable, dumbest, moronic failures I have ever seen.
"Designer's choice"? I have a bigger screen and get to see less? Designer my ass!
If you follow this logic you'd need to add code to hamper mouse control from hires mouses, etc. etc. etc.
__________________
Descent Site, Fine Arts.
karx11erx is offline   Reply With Quote
Old 18th Dec 2008, 18:12   #6
scarrmrcc
Modder
scarrmrcc is on a distinguished road
what makes you say you have a bigger screen?
widescreen is NOT a regular screen with screen added to the sides
it is a different format (and square inches to diagonal, it is actually smaller)
scarrmrcc is offline   Reply With Quote
Old 18th Dec 2008, 20:27   #7
Drexial
Supermodder
Drexial is on a distinguished road
My 21" has a resolution of 1680x1050 a standard 17or19" has 1280x1024. Games don't care about size they care about resolution. which means on my monitor i can see more when scaled like a normal game. vs FC2/Bioshock, where I wouldn't be able to see the top and bottom fragments of the screen.
Drexial is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
