RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 19th Dec 2008, 08:53   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Sapphire ATI Radeon HD 4870 X2 Atomic
http://www.bit-tech.net/hardware/200...tomic-review/1
The Sapphire ATI Radeon HD 4870 X2 Atomic is a heavily overclocked, pre-watercooled version of ATI's dual GPU monster and it's been tearing up the bit-tech test benches all week. We find out just how fast it is, and whether it justifies its monster price tag.
Tim S is offline   Reply With Quote
Old 19th Dec 2008, 09:14   #2
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn is on a distinguished road
great idea, concept, and appearance but just not worth it for the performance gained over its cost, oh well.
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding •
Retired Rig: Project F.E.A.R.
• TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory •
HourBeforeDawn is offline   Reply With Quote
Old 19th Dec 2008, 09:26   #3
Teq
69 Dude!!
Teq is on a distinguished road
It does seem a little odd putting the pump on the cpu block, especially as they tend to dump heat into the loop? I also currently run a single loop for GPU and CPU (although obviously custom) and would not recommend it, modern graphics processors dump so much heat it scares me sometimes to look at the CPU temps
Teq is offline   Reply With Quote
Old 19th Dec 2008, 09:30   #4
HourBeforeDawn
a.k.a KazeModz
^^^ well the whole pump/block combo type argument as been around for a while and honestly a pump makes next to no heat so really there isnt much of a change and this looks like its using the Siberian block/pump combo which is the only competition that I know of to the swiftech version but as far as I know isnt sold in the states. Either way it offers no better then low level entry water cooling comparable to that of high end air cooling.
__________________
Old 19th Dec 2008, 10:09   #5
The boy 4rm oz
Get On My Horse!!!
The boy 4rm oz's Avatar
The boy 4rm oz is just really niceThe boy 4rm oz is just really niceThe boy 4rm oz is just really niceThe boy 4rm oz is just really nice
There is no way the single "slim" 120mm radiator could cool a high mainstream gamers CPU (such as a Q6600 or Q6700) AND a HD 4870 X2 comfortably. As your tests show the CPU actually ran hotter than stock. Just a gimmick.
__________________
Project: LEXA FINISHED 30/11/08 (16 months 14 days) MOTM Nominee October 08
Originally Posted by unknowngamer View Post
Waaaay to much eye make up...be like humping a panda.
The boy 4rm oz is online now   Reply With Quote
Old 19th Dec 2008, 10:12   #6
HourBeforeDawn
a.k.a KazeModz
^^^ at stock no problem, again that setup has similar results as highend air cooling, OCed well if we are talking q6600 up to 3-3.2 ghz would be alright but anything higher well of course not.
__________________
Old 19th Dec 2008, 10:20   #7
crompers
Dremedial
crompers's Avatar
crompers has a spectacular aura aboutcrompers has a spectacular aura about
they should have just released the card with the waterblock on. i think they have narrowed their market by producing a entire loop
__________________
| Q6600 G0 @ 3.21ghz | ACF7P | GA-P31-DS3L | 4GB HyperX 857mhz | XFX GTX280 655/1210 | WD 160GB | Maxtor 250GB | Black Gigabyte Aurora | OCZ GameXStream 700W | HP LP2475w | AE Aego M 2.1 | Roccat Kone | Saitek Eclipse |
Steam: psycrompton PSN: crompers85
crompers is offline   Reply With Quote
Old 19th Dec 2008, 10:28   #8
The boy 4rm oz
Get On My Horse!!!
Would also be cheaper for the consumer to purchase (if they have a pre-existing loop).
__________________
Old 19th Dec 2008, 10:50   #9
Paradigm Shifter
Lethargic
Paradigm Shifter's Avatar
Paradigm Shifter will become famous soon enough
Would be interested in three things... temps with a Q6600 rather than the heatmonster Prescott, temps without a CPU in the loop and what sort of difference adding a second fan on the radiator in a push/pull arrangement will have. I realise that you probably aren't going to be testing those, though, as you've likely got better things to be doing.
Even so, this is a nice idea that fails because a single 120mm radiator really can't take two hot GPUs and a CPU all at the same time. A dual would have coped better, but even then wouldn't have been perfect... and case compatibility goes out the window with a dual radiator.
If it's going to be cutting close to £600, that really doesn't do well enough to be justifiable. A 4870X2 and a decent custom watercooling setup will cost the same, and give far superior temperatures. Of course, that introduces the whole complexity issue again...
__________________
Core i7 920 D0 @ 3.8GHz | 6GB Corsair 1600MHz | Gigabyte EX58-UD5 | XFX 4870X2 2GB | 4TB | WUXGA
Paradigm Shifter is offline   Reply With Quote
Old 19th Dec 2008, 11:00   #10
xaser04
Multimodder
xaser04's Avatar
xaser04 is on a distinguished road
Great review (I love how in depth Bit-tech go for these reviews and also the inclusion of min framerates are a god send compared to other reviews)I can't help but think thought tthat the choice of wording 'heavily overclocked' seems wrong for this card.
In reality its a bump of 50mhz on the core and 100mhz on the memory (quad pumped for GDDR5) is simply just an overclock.
Maybe its because I am used to seeing card like the my old 8800GS (XFX alpha dog edition) clock from 550 - 750 on the core, 1500 - 1950 on the shaders and 1400 - 2100 on the memory. Not thats a heavy overclock!
__________________
Scientology - A Religion for those who think Star Trek is a documentary
xaser04 is offline   Reply With Quote
Old 19th Dec 2008, 11:42   #11
mclintox
Get the jigsaw out!
mclintox's Avatar
mclintox is on a distinguished road
Crompersitto,was thinking the same.Sort of along the lines that BFG took,i think,with some Nvidia cards.
mclintox is offline   Reply With Quote
Old 19th Dec 2008, 11:43   #12
Hustler
Multimodder
Hustler is on a distinguished road
So....in the new year its a choice between a £600 Gfx card or food and water...
I'll choose the latter, but want the former...
Hustler is offline   Reply With Quote
Old 19th Dec 2008, 12:36   #13
D B
Multimodder
D B's Avatar
D B is on a distinguished road
Looks like they should have done just the GPU and left the CPU cooling to whatever the consumer wanted/had to use.
I've always wondered about having separate, dedicated loops for CPU cooling and GPU cooling .. from the figures, it looks as if a single 120mm fan/rad would cool the 4870 x2 just fine, and without the GPU dumping all that heat into the CPU loop, I wonder if another 120mm/rad would cool it too?
__________________
You keep those pink gloves up & swinging, Kimber
Think Pink Scuba
D B is offline   Reply With Quote
Old 19th Dec 2008, 12:45   #14
docodine
I *am* a Dremel
docodine's Avatar
docodine will become famous soon enoughdocodine will become famous soon enough
The US price is supposed to be in dollars, ahem.
Will the 4870 X2s ever drop below $350, I would really like to get an X2 over the regular one, but the price is so much higher.
__________________
Armagetron Advanced!
[ Cooler Master Elite 310 | Intel E5200 | Zotac 9600GT | broken MSI G31 mobo | Corsair 2x2GB DDR2-667 ]
docodine is online now   Reply With Quote
Old 19th Dec 2008, 13:20   #15
zr_ox
Whooolapoook
zr_ox's Avatar
zr_ox is on a distinguished road
Eh no thanks!
So lets say you have the cash for this, then in a few months want to buy another card for crossfire? What are you going to do with the extra cpu block and pump?
__________________
0ptimizm
:PC under review
zr_ox is offline   Reply With Quote
Old 19th Dec 2008, 13:35   #16
Goty
Supermodder
Goty is on a distinguished road
I apologize for not reading the whole article, I just skimmed through it before heading off to class, but is it possible that you didn't get a good mount on the CPU waterblock? The only other review I've read about this card said the CPU waterblock did a very good job.
Goty is offline   Reply With Quote
Old 19th Dec 2008, 14:26   #17
Baz
Benchmarketeer
bit-tech Staff
Baz's Avatar
Baz is on a distinguished road
Double checked and fitted twice - it's not that the waterblock does a bad job, it's just that the loop struggles to deal with all the heat being dumped into the loop by the 4870 X2, the point where the CPU is actually being warmed by the loop rather than cooled!
Baz is offline   Reply With Quote
Old 19th Dec 2008, 14:37   #18
Denis_iii
Hypermodder
Denis_iii's Avatar
Denis_iii will become famous soon enoughDenis_iii will become famous soon enough
US Price (as reviewed): £700 (ex. Tax) - MSRP
Denis_iii is offline   Reply With Quote
Old 19th Dec 2008, 14:56   #19
DarkLord7854
Web Developer
DarkLord7854's Avatar
DarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to beholdDarkLord7854 is a splendid one to behold
Shame they chose 1/4" tubing.. 1/2" or 3/8" might have made some slight differences, but it's pretty obvious the radiator was just incapable of dumping off the heat.
I wonder if it's a dual-pass radiator, it's look a bit too thin to be dual-pass.
The concept is good though.
Wouldn't the fluid eventually need to be topped up though?
Interesting how it didn't have a reservoir either, so it would mean the system has the exact amount of fluid. I wonder if it makes any thermal difference to have reservoirs for liquid to sit for a while and dissipate heat before being pushed back through the loop..
__________________
Current Computer: eVGA 780i Motherboard | Q6600 Core2Quad | eVGA GTX260 896Mbs 216-core | 2x Seagate 500Gbs | 8Gbs OCZ Platinum DDR2 800 | Creative XtremeGamer X-Fi | Thermaltake Armor Case
Custom WordPress, ZenCart, Joomla, vBulletin, etc installs and skinning, PM/E-Mail for a quote
DarkLord7854 is offline   Reply With Quote
Old 19th Dec 2008, 16:03   #20
Jojii
hardware freak
Jojii's Avatar
Jojii is on a distinguished road
did you guys try to squeeze any more performance out of it? or didn't want to risk it?
Jojii is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
