#1 |
Hypermodder
Emulator detected! Please deactivate virtual drive and emulation software.
I can't play games!
As yo can read from the title, everytime i put in a game disc that i actually own its says this and the only way i've figured out how to play my games is by using a no-cd crack .It's happened with C&C:TW now its happening with EE:3! I did installed Football manager which has securom on it do you think thats borked my system.
__________________
[Intel Core i5-2500k | Gigabyte P67A-UD4 | Corsair XMS3 4GB | 1GB Sapphire HD 6850 | 3TB HDD | Hiper 540W PSU]
[Ubuntu Home File Server] [CompTIA A+ Certified][Cisco CCNA Certified] |
#2 |
The cheesecake is a lie
So you don't have any virtual disc software installed? Like Daemon Tools, Alcohol 120%, MagicDisc etc...
Do you possibly have any SCSI devices? Some borky copy protection might think they are virtual discs. Other than that, you can only blame SecuROM then. |
#3 |
Hypermodder
I dont have any emulation software! This is down to securom those a-hole's.
__________________
#4 |
будет глотать вашу душу.
try getting the 64bit securerom files from securerom. it may be failing because the securerom included on the games loaded the 32bit securerom drivers only, which fail on a x64 system. without the drivers loading it will fail because it can't do a media check.
#5 |
Hypermodder
i had this once, i did have demon tools running but even after i uninstalled it, it didnt work.
Contacted EA who recommended a format (Nothing to harsh) to fix it |
#6 |
WHAT?! So you'll have to format your computer to run SecuROM protected games?
Haha, not for me! Even less reasons to buy games anymore! |
#7 |
Hypermodder
nah only happened with that 1 game, probably a bad lot of securom.
I didnt format it at the time, just played the game when i got round to formatting it next |
#8 |
Its great how this would never happen if you had pirated the game.
![]() Your best bet is just to use a no-cd and enjoy not having to bother with putting the disk in every time.
__________________
#9 |
Hypermodder
to use a no-cd you would of have to pirated the game, something i wont do.
#10 |
Formerly Titanium Angel
Ive done it with a few of my games GTR, dreamfall and another. I dont see it as piracy at all seeing as i bought a proper version from a proper shop, Its not my fault that the publishers couldnt release a game that a paying customer can play.
#11 |
regular bit-tech reader
Check here what copy protection your game is using:
http://www.daemon-tools.cc/dtcc/gamedb.php Securom7 and safedisc4 can prevent you from running game when you have a virtual drive manager installed on your PC. But I also noticed that certain versions of securom doesn't prevent you from running game as long as you keep original disc in DVD drive. If you have Daemon tools or Alcohol 120% installed on your PC then download program called YASU(Yet Another Securom Utility, but watch out from where you download it, check daemon tools forum) - it hides these programs and it might help you(but it won't work if you're using pirated disc image to run the game - you need original disc). Running Sysinternal tools(ie registry monitor) will cause Securom7 to always prevent game exe from running. Reboot should help... I'm not sure about Securom DRM crap. I never bought game which is infected by it. Last edited by Kúsař; 22nd Dec 2008 at 14:26. |
#12 |
Downwind from the bloodhounds
Ah the joys of modern PC gaming /sarcasm.
If they want people to pirate games out of convenience even if they are willing to pay for them they are going the right way about it.
__________________
Wolfticket: Ambitious but rubbish ![]() "A facility for quotation covers the absence of original thought." Dorothy L. Sayers (1893 - 1957) |
#13 | |
I use no-cds because I don't want to keep getting the disk out of the box. This is due to laziness and because I don't want my disks to get scratched.
__________________
#14 |
Hypermodder
sorry i put it across wrong, i use no-cds as in demon tools i load a cd image but with the securom problem that didnt work, modifying the exe works but then blocks internet play
#15 |
Hypermodder
But the thing that annoys me is that i unistalled the game that installed securom on my machine and it still keeps on doing it. I still don't know how to remove the securom files atm.
__________________
#16 | |
Only Starforce is resident evil. It's running as "service". For example if you try to run Alcohol software to create image of disc it'll mess with your drive... |
#17 | |
SF just installs ring 0 drivers, that's nothing unusual, even virus scanners and Daemon Tools do that). SecuROM and SafeDisc add services and DLL files. Actually I think even the newest SecuROM and SafeDisc versions add drivers to your system. You can check all drivers by going to device manager and then Show > Show hidden devices. Now when we're talking about bad experiences with copy protections... Once when I installed TrackMania (Original), which has StarForce, I got a BSOD on reboot. Once we installed Worms 4: Mayhem, which also has StarForce, on my friend's computer, it asked for a reboot and on startup we got an error about incompatible drivers. Well the game still didn't run, and in the end we ended up using a no-cd. And this was on 32-bit Vista. |
#18 |
i hate the person above me
this pisses me off so much back in the days of doom3 they had this where you couldnt play if deamon tools was installed, the fact that i used it to mount legit images doesnt matter i had to remove it i get around this nowadays by using network shares of a mount contained on a server allowing the image to be used on all my home pcs but it is still just plain wrong
#19 | |
I actually like Doom 3.
![]() I'd remove secuROM for every title just out of good practise if I could - it's such a godawful piece of crap, I've never had it let me play a game without a hitch. It just hates my DVD drive. Apparently there's no Safedisc Unwrapper equivalent for SecuROM and it's essentially tied to the game (source), so I'd just use a fix of some description. The developers already have your money for the game, don't feel guilty about wanting to play it for Christ's sake!
__________________
Build: Lian Li Tu-200B Forum Pet Projects: Bang-for-Buck Graphics Cards Analysis || Split-Screen Co-op Gaming List || Emerging Genres: The Sims & Heavy Rain (there are too many quotes to fit into my sig now so I threw them all over here instead) |
| Thread Tools | |
