Thread Tools |
#1 |
Pewlius Caesar
bit-tech Staff
Belkin Powerline AV Network Adapters
http://www.bit-tech.net/hardware/200...pters-review/1
Building the perfect home network can be tricky, especially if you've got thick walls which interfere with Wi-Fi signals or don't want Cat5e trailed everywhere. We check out Belkin's Powerline AV starter kit which uses the existing electricity wiring in your home to carry a network signal and see if it's a decent alternative.
__________________
#2 |
Made in Canada
Neat. I'll wait for the prices to come down though, still a bit too steep imo. But if a kit like this hovered in the $50 range I'd happily pick one up.
__________________
[[Asus P6T | Intel Core i7 920 @ 2.67Ghz cooled by Noctua UH-P12 Push-Pull Config | 6GB DDR3-1600 Patriot Viper Xtreme XMP C8 | nVidia GeForce 280 GTX 1GB | Corsair HX620 620 Watt PSU | Antec P182 Case]] |
#3 |
69 Dude!!
I had my Xbox attempting to run a media center extension via 802.11g and it couldn't even cope with SD signals, plugged this kit in (which just works btw - refreshing that there is no fiddling around to get it functional) and was instantly able to play hd media across the connection, no trouble at all, not only that but I am now also able to host 8 player games of Forza with friends and they have very stable connectivity to me. Sure it doesn't beat my cat5 to my main PC's (2 gaming rigs and a HTPC), but it makes anything other than the new 'n' standard wireless networking look absolutely appalling, my only small issue with them is that the first batch that arrived developed a fault within a couple of days.
#4 |
Hypermodder
at 30quid i'd pick up a pair
#5 |
Multimodder
We have been using this setup(not Belkin) in our house for almost a year because one computer is out of wifi range. They are a generic provided by the ISP for 30 USD a piece. The box claims 85 MB/s, and that's probably a complete lie, but it has been plenty fast for browsing, and 100 percent reliable to the other end of the house. It's a great technology for this sort of thing. It would be nice if the price would come down a bit more though.
#6 |
Multimodder
anyone have a good link to how this stuff works?
#7 |
/dev/null
Does this also extend your network to the outside world over the power cables?
__________________
There Are 10 Types Of People, Those Who Know Binary and Those Who Don't |
#8 | |
What's a Dremel?
Wikipedia knows all.
__________________
| Q6600 | 4GB OCZ Gold | 3650 512MB |
#9 |
/dev/null
The maximum range could be closer then you imagine, think about apartments... I don't like the feeling of giving physical access to my network to my neighbours...
__________________
#10 |
Ultramodder
simple router mac address filtering would take care of that though.
I do like this idea, even if it's to allow the optimum positioning of a wireless router. I see this tech being very useful in a few years once it has matured and improved a little more. Have most pc's connecting through the power lines, then have a wireless router for laptops, iphones etc. Good review BT, nice to see the tech has improved
__________________
Main - e5200 @ 3.5GHz (akasa 965) || GA-EP31-DS3L || 2X2GB Crucial Ballistix || xfx GTX 260 || 500GB Seagate 7200.10 sata + 250GB Samsung sata + 160GB Samsung ide || NEC DVDRW || Enermax Liberty 400W || Antec P180 || 22" Fujitsu Siemems TFT Media - X2 4400 @ 2.4GHz || Epox 9NDA3+ || 2GB RAM || 6800gs || 80GB Maxtor Diamond Plus 9 || LG DVD RAM || Iiyama Vision Master Pro 454 |
| tank_rider |
| View Public Profile |
| Find More Posts by tank_rider |
#11 |
What's a Dremel?
'm/s' is a unit of speed (metres per second), but I seriously doubt that the power-line transmission was that slow (24 metres per second).
'ms' is the prefix I believe you were looking for - milliseconds. |
#12 |
What's a Dremel?
I use a kit similar like this from Devolo. It's got a config utility which let's you set a password, so no one lese will be able to connect to it, and they also have a model which will give you wireless access.
Great stuff |
#13 | ||
Ecky thump
Moderator
But as it's you, the Linux fan, Quote:
__________________
Nobody's perfect. But being a Yorkshireman is as close as you can get. Last edited by cpemma; 27th Dec 2008 at 15:50. |
#14 | |
Design Warrior
#15 |
Multimodder
You can't use these things if there's a dimmer on the same power group...
#16 |
a.k.a KazeModz
so I wasnt sure if it was mentioned as I skimmed the "review" but how does this effect your power, wont it dirty your power even further?
__________________
Current Rig: RubyRED
• Lian-Li A05B • (2) Swiftech 220 Radiators • (2) D5 Variable Pumps • (2) Res • and a whole lot of modding • Retired Rig: Project F.E.A.R. • TT Lanbox Lite • Swiftech H2O-120 • Q6600 G0 OC@3.6ghz • 2900XT • 4gb SuperTalent Memory • |
#18 |
Hypermodder
Been using the 200Mbps ones from Netgear with similar results, been running for over 2 years no problems whatsoever, so much better than wireless for me, as a warning they don't work in all houses which makes the outlay a little risky if you have problems returning it
__________________
Into Gaming and around Bristol, UK, Click Here |
#19 |
Multimodder
I only had chance to skim read the artical, but wont the ethernet ports on these have to be GbE to be able to meet there maximum 200Mb/s?
Or are they 100Mb ports and the powerlines can do a 200Mb network, eg to allow more than three computers hogging the bandwidth. |
#20 |
What's a Dremel?
I've been running 3x200Mbps Netgear Powerline plugs as part of my network for about a year, as my WiFi was drowned out by the 12 or so other users in the neighbourhood. I love the Netgears as they give a consistent 85Mbps+ & the data dropouts I had with WiFi are no more. They work with dimmers but do need to be plugged into the wall socket, not an extension. The only thing that stops them is the electric meter, so the neighbours can't snoop, which is another bonus. Setting up secure encrypted WiFi was a royal pain which I don't need to do with the Powerline's, they are quite literally 'plug & go'.
| Thread Tools | |
