Reply
Thread Tools View Mode
Old 31st Dec 2008, 18:13   #21
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
Originally Posted by Boddaker View Post
lol You probably would! (that, and I want to complete this in less than a month hehe.)
Lol! So, done in a month or so? Heck, is it too early to ask about the project after this?
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 31st Dec 2008, 18:49   #22
Boddaker
TRON CAT!
Boddaker's Avatar
Boddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run CrysisBoddaker can run Crysis
Not at all. I already have something brewing for Nvision '09.
__________________
www.bods-mods.com
Originally Posted by my brother
Is the name "Neptune's Trident" something you came up with? I can't see how a planet and chewing gum are related.
Boddaker is offline   Reply With Quote
Old 31st Dec 2008, 19:01   #23
craigbru
craigbru's Avatar
Just as I suspected... I'll plan on seeing you there!
__________________
Old 1st Jan 2009, 12:10   #24
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
A Bod mod is a great mod lol. I am loving the idea, very cool. Can't wait to see how it turns out for you.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 1st Jan 2009, 13:42   #25
Mankz
dat steak
Mankz's Avatar
Mankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on youMankz - may the hammer of Bindi be bestowed on you
Subsricbed
Mankz is offline   Reply With Quote
Old 1st Jan 2009, 21:59   #26
headala
Multimodder
headala has yet to learn the way of the Dremel
Sub'd
headala is offline   Reply With Quote
Old 2nd Jan 2009, 08:25   #27
Boddaker
TRON CAT!
Boddaker's Avatar
After gutting the case, I started in on the side panel window design and pass-through holes. If you remember the case came with a windowed
side panel that also had a fan hole in the upper right corner. Luckily, Moddersmart had a solid panel for the case lying around so I got that too.
I penciled out the lines for the cutouts. I didn't bother to protect the surface with tape, since I will be sanding and painting later.
Drilled some pilot holes for the jigsaw and started cutting.
Cuts complete, but I made a tiny boo-boo. See it?
How bout a closer look. I mistakingly drilled the pilot hole in the wrong spot. Doh!! :x
Here is the panel on the case.
To fix the whoops, I cut a round disc and plugged the hole, and will bondo over it later.
On to the other side panel!
__________________
www.bods-mods.com
Old 2nd Jan 2009, 12:43   #28
The boy 4rm oz
Project: Elegant-Li
Nice cuts made for the window.
__________________
Old 2nd Jan 2009, 13:28   #29
jhanlon303
The Keeper of History
jhanlon303's Avatar
jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.jhanlon303 is a hoopy frood who really knows where their towel is.
Very nice layout and cuts for the windows!
I'm also glad you showed the 'OOPS' shot. Makes me feel better knowing I'm not the only one who occasionally makes mistakes. I thought I was a dead loss at layout.
john
__________________
My deepest gratitude to this community.
jhanlon303 is offline   Reply With Quote
Old 2nd Jan 2009, 16:44   #30
renba
hooch is crazy
renba's Avatar
renba has yet to learn the way of the Dremel
You know how to use a jigsaw
Nice layout
renba is offline   Reply With Quote
Old 2nd Jan 2009, 18:13   #31
Mankz
dat steak
Mankz's Avatar
ooh! Nice window! Bob, if you want some inspiration, Franklin did an amazing V2000 Mod a few years back, called AlumaxX
Old 2nd Jan 2009, 19:41   #32
NysoO
Handcrafted
NysoO's Avatar
NysoO has yet to learn the way of the Dremel
Nice build. Great job on cutting those holes.
__________________
Aluchill
NysoO is offline   Reply With Quote
Old 3rd Jan 2009, 23:30   #33
TiTON
IRONMODS
TiTON has yet to learn the way of the Dremel
Hey Bod.. looking good. Mod On
- Ton
TiTON is offline   Reply With Quote
Old 4th Jan 2009, 00:01   #34
spenc259
in the build stage!!!
spenc259's Avatar
spenc259 has yet to learn the way of the Dremel
this should b gd...
looking forward to it...
spenc259 is offline   Reply With Quote
Old 4th Jan 2009, 01:22   #35
Boddaker
TRON CAT!
Boddaker's Avatar
@ TiTON: Thanks man!
Some progress today!
To cut the other side panel, I used the first one as a guide. After cleaning up the cuts with a file, I layed the two panels
together and drew out the three holes.
Holes cut (I got the pilot holes right this time! )
Then I removed the front post.
Instead of just working with the existing floor, I opted to make a whole new one out of the old windowed side panel.
This provides me with a clean slate so I can make my access holes wherever I need them. Using the old one as a template,
I marked out the side panel. Had just enough material in the middle.
Cut, complete with mounting tabs and notches on the ends for the side panels.
Test fit. Gotta make a few adjustments...
Now it fits! I won't rivet it in just yet. Gotta first make all the holes I need for cabling, tubing, etc..., and paint.
Next up will be the back panel, psu mount, and bottom radiator mounting brackets.
__________________
www.bods-mods.com
Old 4th Jan 2009, 01:35   #36
Mankz
dat steak
Mankz's Avatar
oooh exciting!!! I love that side panel!
Old 4th Jan 2009, 01:37   #37
jhanlon303
jhanlon303's Avatar
Me too! and the wrap around window corner is way new to me. Never seen another one.
Very nice Bod.
john
__________________
Old 4th Jan 2009, 03:12   #38
The boy 4rm oz
Project: Elegant-Li
Coming together very nicely mate. The new divider looks very good. At least you can make the pass through holes where you want now.
__________________
Old 4th Jan 2009, 04:00   #39
at0y_co
What's a Dremel?
at0y_co has yet to learn the way of the Dremel
subscbd...
at0y_co is offline   Reply With Quote
Old 4th Jan 2009, 04:10   #40
Colossous
Supermodder
Colossous's Avatar
Colossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the DremelColossous has yet to learn the way of the Dremel
Looking way cool there duder - you have an eye for the unusual approach
Colossous is offline   Reply With Quote
Reply
Tags
boddaker, bods-mods, bods-mods.com, trident, typhoon
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
