RSS
Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 5th Jan 2009, 07:55   #1
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
Tim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of lightTim S is a glorious beacon of light
Viewsonic VX2260WM - 22" Full HD monitor
http://www.bit-tech.net/hardware/200...l-hd-monitor/1
Viewsonic is the second monitor manufacturer to jump on the 16:9 bandwagon after Iiyama. We check out the VX2260WM, a 22-inch 1,920 x 1,080 display with a decent array of connectivity options, to see how it stands up to what else is out there.
Tim S is offline   Reply With Quote
Old 5th Jan 2009, 08:13   #2
yakyb
CK is God!!!
yakyb's Avatar
yakyb is on a distinguished road
i noticed this monitor a couple of weeks ago and wondered what the quality would be like on a cheap 1080p thanks bit for doing the review looks okay ii think i might hang on till i can actually afford one tho
__________________
Gaming Box:: q6600 @3.0 :: 9800gtx :: Abit IP35 :: 4gb :: 1.4TB :: akasa eclipse :: Win7
Development:: PhenomII 955BE @3.2 :: 4200 :: asus M4A785 M Evo :: 1.25TB ::Win7
Media Centre :: q6600 @3.0 :: x1950pro :: asus p35 epu :: 8gb :: 320 GB :: Lc17B :: Win7
server:: I7 860 :: p55 gd65 :: 3450 :: 8 TB :: 8gb :: Rebel 12 :: server 2008 R2
yakyb is offline   Reply With Quote
Old 5th Jan 2009, 09:39   #3
RobertBruce
What's a Dremel?
RobertBruce is on a distinguished road
I'd love to see it compared to ASUS VH226H which is also a very small 1080p.
RobertBruce is offline   Reply With Quote
Old 5th Jan 2009, 10:40   #4
tanka12345
Minimodder
tanka12345's Avatar
tanka12345 is on a distinguished road
I'd love to see a review on the BenQ E2200HD, E2400HD, M2200HD, and M2400HD as they're part of BenQs new 16:9 range. Maybe Bit-tech could do a 16:9 monitor round-up, and investigate the debate:16:10 vs 16:9.
__________________
Intel Core i7 920 OCed to 3.2GHz | CoolerMaster V8 | Patriot Viper 3x2GB DDR3-1333MHz | MSI Eclipse X58 | LG W2261V 22" 16:9 | Western Digital Caviar Black 640GB | MSI ATI 4870 1GB | Enermax Revolution 85+ 1050W PSU | CoolerMaster HAF 932 | ASUS DRW-22B1LT | Creative SB X-Fi Xtreme | Logitech X-540 | Razer Carcharias | Razer Lachesis | Razer Destructor | OCZ Alchemy Elixir
tanka12345 is offline   Reply With Quote
Old 5th Jan 2009, 10:51   #5
Denis_iii
Hypermodder
Denis_iii's Avatar
Denis_iii will become famous soon enoughDenis_iii will become famous soon enough
+1 to 22" roundup
does the monitor passthrew HDMI audio to the built in speakers? audio out connector if there is one?
Denis_iii is offline   Reply With Quote
Old 5th Jan 2009, 11:15   #6
Moriarty
Evil Genius
Moriarty's Avatar
Moriarty is on a distinguished road
Well I was planning to get a BenQ G2400WD, now I can't decide If I really need those few extra pixels or should save myself a few quid.
Moriarty is offline   Reply With Quote
Old 5th Jan 2009, 12:49   #7
Jipa
Licenced idiot.
Jipa's Avatar
Jipa has a spectacular aura aboutJipa has a spectacular aura aboutJipa has a spectacular aura about
It's the low vertical resolution that's the issue with 19" and 20" wide screens and thus I don't really get the point of the 16:9 panel. 16:10 gives some extra space and unless your main concern is the aspect ratio of the screen when watching movies on it then I'd get a 1920x1200-screen instead.
This is, however, somewhat interesting review because the 16:9 22" screens are dirt cheap and I should get some of these to my sister...
__________________
Abit IP35 - E6750 - 8800GT 1024 MB - 2 GB 800 MHz - enough HDDs - 750 W Silverstone - CM Storm Sniper
Asus P5Q-VM - Q9450 - 4 GB - 400 W Silverstone - Fortress FT01
Jipa is offline   Reply With Quote
Old 5th Jan 2009, 13:36   #8
Tim S
Pewlius Caesar
bit-tech Staff
Tim S's Avatar
At 24-inches, the 16:9 panel is a step backwards because you're losing real-estate. With 22-inch displays though, you're gaining all round which is really where the benefit is for desktop usage. What does concern me though is that this is driving the minimum barrier of entry for gamers up if 1680x1050 displays are disbanded completely.
Old 5th Jan 2009, 15:35   #9
wuyanxu
quad fuelled, GTX200 powered
wuyanxu's Avatar
wuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura aboutwuyanxu has a spectacular aura about
agree, at 22 or 23inch, these 1080p monitors seems like a real deal. and it should have cheaper backlight than normal 16:10 monitors because it needs to shine less vertically.
are there really any noticeable performance difference between 1920x1080 vs 1920x1200? in FPS, the field of view is going to be the same with same horizontal width, so it should perform the same??
__________________
Death to consolification !!!
Core i7 860 @ 4Ghz Cooled by Corsair H50 // Asus P7P55D Deluxe // 8GB of Corsair Dominators @ 1528Mhz 8-8-8-24 //
BFG gtx260+ OC2 MaxCore 216SP 896MB // Samsung 64GB SSD // WD Raptor 74GB + Black 1TB + Green 1TB // Corsair Hx620w // Antec p182 // Samsung 24" T240
wuyanxu is offline   Reply With Quote
Old 5th Jan 2009, 16:34   #10
Drexial
Supermodder
Drexial is on a distinguished road
I honestly noticed no real difference between 1280x1024 to 1680x1050, so I doubt there would be a difference with those resolutions.
Drexial is offline   Reply With Quote
Old 5th Jan 2009, 19:37   #11
LanMare
What's a Dremel?
LanMare is on a distinguished road
The trend seems to be smaller monitors, smaller dot pitch with larger resolutions. There are now 23" monitors with a TN panel aswell and with 2048x1152 resolutions. These got me really interested....hope to soon see a review there too. Thanks
LanMare is offline   Reply With Quote
Old 5th Jan 2009, 19:51   #12
Jipa
Licenced idiot.
Jipa's Avatar
Ah my bad once again, I didn't realise that indeed in 22"-ers its a step to a larger resolution. I've just wondered why the hell would someone want to go from 1200 to 1080
__________________
Old 5th Jan 2009, 21:19   #13
Blassster
Minimodder
Blassster's Avatar
Blassster is on a distinguished road
Yeah a 22" 1080p roundup would be awesome.
Been holding off for a new monitor (have a 6 year old CRT). Always wanted a 22", but hate the strange res of 1680x1050... happy that 1080p is becoming less rare now!
Thanks for the review.
Blassster is offline   Reply With Quote
Old 6th Jan 2009, 06:43   #14
chrisb2e9
Dont do that...
chrisb2e9's Avatar
chrisb2e9 has a spectacular aura aboutchrisb2e9 has a spectacular aura about
I was looking at one of these in a store the other day. Nice looking monitor and not too pricy.
__________________
attack life, it's going to kill you anyway.
Long-term relationships are like urban tomatoes: they only grow under special conditions. - Prestidigitweeze
Don't hold on to the reigns once you've fallen off the horse, your just going to get dragged to death - SNiiPE_DoGG
chrisb2e9 is offline   Reply With Quote
Old 6th Jan 2009, 08:34   #15
Neogumbercules
Ultramodder
Neogumbercules's Avatar
Neogumbercules is on a distinguished road
This looks like a great monitor to use if you're looking to hook up a PS3 or 360 for cheap.
__________________
Abit AB9 Pro, Intel Core 2 Duo E6400 CPU, 2GB Corsair DDR2 6400, nVidia 8800GT, Seagate 160 GB HDD.
Neogumbercules is offline   Reply With Quote
Old 6th Jan 2009, 18:54   #16
Ab$olut
Supermodder
Ab$olut's Avatar
Ab$olut is on a distinguished road
Just bought one this will be my first Lcd after 10 years on crt I hope i'm not disappointed.
__________________
http://www.dameet.co.uk
3000+ 64 venice : XFX 6800gs 256mb : 2gb cosair value ram : 120Gb maxtor : 400w silver power psu
Ab$olut is offline   Reply With Quote
Old 19th Jan 2009, 19:54   #17
chrisb2e9
Dont do that...
chrisb2e9's Avatar
Anyone else buy one of these? I bought one and noticed last night when I was trying to sleep that it kept making noises. Sounded like a plastic bag blowing in the wind. Not a constant noise, just every now and then. Maybe it was just cooling down?
Old 21st Jan 2009, 12:14   #18
Delphium
You there computer man fix my pants
Delphium's Avatar
Delphium has a spectacular aura aboutDelphium has a spectacular aura aboutDelphium has a spectacular aura about
Originally Posted by Denis_iii View Post
+1 to 22" roundup
+2
Also Bit-tech, in the Iiyama ProLite E2208HDS review you claimed the panel was 6-bit, are you able to confirm if this Viewsonic panel is 6-bit or 8-bit please?
__________________
| Asus P5N32-E SLI | Q6600 G0 @3.0ghz Watercooled | 8GB Corsair Dominator PC8500 @1066mhz 5-5-5-15 2T | XFX GTX285 | BFG 8800GTS | XFX 9600GT | 1x 128GB Crucial M225 SSD | 5x 500GB Seagate SATA-II | BFG 800W SLI PSU | Logitech Z-5500 5.1ch speakers | 3x Dell S2209W 22"wide TFT's (5760x1080res) | 1x Panasonic 42"Plasma | All working on Win7 Ultimate x64 |
Delphium is offline   Reply With Quote
Old 17th Mar 2009, 11:54   #19
Russian boy
What's a Dremel?
Russian boy is on a distinguished road
All greetings! I from Russia. The monitor has worked for me 2 weeks then has broken. (http://www.youtube.com/watch? v=HXWgyOR7qM8) Apparently from video, the monitor itself is switched off and joins. And still very strongly smells as burnt plastic. In my service centre have reserved burnt down
Payment (Power Board) Which 3 months go... I have refused repair after two months of expectation and have demanded to replace the monitor on new, but now it is not known when to me it will bring because at us in Russia it simply anywhere is not present on sale. And the most important thing I not one such with precisely such breakages. At our forums many people complain of such defects of this monitor. Do conclusions more shortly, to buy or not to buy. =)
Russian boy is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
