Go Back   bit-tech.net Forums > Technology > Software
Reply
Thread Tools
Old 10th Jan 2009, 07:40   #1
mfaridi
Minimodder
mfaridi's Avatar
mfaridi has yet to learn the way of the Dremel
Best software for detect hardware problem
Can I find best software can detect hardware problem and show me
for example I see my Voltage of RAM or mainboard have problem . and give me many information about hardware ?
mfaridi is offline   Reply With Quote
Old 10th Jan 2009, 09:30   #2
ModMinded
Are you throwing that away?
ModMinded's Avatar
ModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the DremelModMinded has yet to learn the way of the Dremel
I liked everest when it was free. Now there's a fee.
Check out the sticky on must have software.
__________________
My First Mod Log (Nzxt Lexa) (Ongoing) - What was that about idle hands?
ModMinded is offline   Reply With Quote
Old 11th Jan 2009, 09:40   #3
K2V
What's a Dremel?
K2V has yet to learn the way of the Dremel
when first assemble a pc, recommended running memtest from http://www.memtest.org/
__________________
Antec 900, Asus P5K Deluxe, E6600 2.4GHz OC @ 3.6GHz 1.472V, OCZ DDR2 PC2-8500 Reaper HPC Edition - 2GB, GeForce 8800 GTS 320M, H2O Cool: External Homemade H2O case, 1 x PA120.3 with 3 x 14cm Aerocool fans, Swiftech MCP655, D-Tek Fuzion CPU, EK-FC8800, Gemstar Flowmeter RFO-2500P, Front Display: 2 x ThermalTake CL-W0033 and 1 x Matrix Orbital LK204-24-USB
K2V is offline   Reply With Quote
Old 11th Jan 2009, 10:27   #4
mm vr
The cheesecake is a lie
mm vr's Avatar
mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!mm vr - it's over 9000!!!!!!!!1!1!1!!!
In the past, there were three versions of Everest; Home, Corporate and Ultimate. Home was free and the others costed. Now, they have dropped support for Home, and the last version of it doesn't really support any new (>2006) hardware. Ultimate is still regularly updated, though.
mm vr is offline   Reply With Quote
Old 11th Jan 2009, 12:11   #5
ModMinded
ModMinded's Avatar
Yeah, I found that out when I tried to run an old install package of it on a newer pc.
Mfaridi, I gave you incorrect info... there is no sticky for must have software for pcs (don't know why, but there is one for macs.)
The overclocking guide lists some good system info programs (like cpuz and hwmonitor.)
__________________
Old 11th Jan 2009, 17:11   #6
cpemma
Ecky thump
cpemma's Avatar
cpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysiscpemma can run Crysis
Look in Tech Support where this thread rightfully belongs.
But never trust software for reliable board voltages.
__________________
Nobody's perfect.
But being a Yorkshireman is as close as you can get.
cpemma is offline   Reply With Quote
Old 12th Jan 2009, 06:09   #7
ModMinded
ModMinded's Avatar
*Snip*
Aha... I was pretty sure I hadn't imagined the existence of that sticky...
__________________
Old 12th Jan 2009, 13:51   #8
cpemma
Ecky thump
cpemma's Avatar
The free version 2.2 is still available from Major Geeks but is unsupported, pretty old now and may not recognise new hardware.
SiSoft Sandra Lite 2009 is more up-to-date and free for home use. HWMonitor free and small footprint but lacks full sensor coverage on my board. PCWizard (same site) is a poor man's Everest, bit buggy last time I tried it but it's in active development and free. Get CPU-Z while you're there.
__________________
Nobody's perfect.
Old 12th Jan 2009, 14:00   #9
Burnout21
Is the daddy!
Burnout21's Avatar
Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.Burnout21 is the Cheesecake. Relix smiles down upon them.
best software to find a hardware problem, windows BSOD, works pretty well at highlighting a problem! lol!
__________________
Project log Mocha70
i7 930, GA-X58-USB3, 12GB Kingston, GTX980, 240GB Cruical SSD, 1Tb Seagate, WC
Burnout21 is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
