Scratch Build – In Progress Project: Shazbom Waterworld (23rd Jan, 2009)
Discussion in 'Project Logs' started by Shazbom, 22 Jan 2009.
  1. Shazbom
    Shazbom What's a Dremel?
    18 Jan 2009
    Some final photos of my beast. hope you guys like it =)
    Custom Modded Lian Li Case with 2 x 360 TFC Radiator Internal and with Custom PSU Cables.
    PC full specifications are as follows:
    1) EVGA X58 3way SLI Classified motherboard
    2) Intel Core i7 920 D0 Rare Golden Chip ★4.5GHz+
    3) 2x BFG nvidia GTX 295 PCIe 1792mb Graphics Card
    4) Corsair 6GB (3x2GB) DDR3 1866MHz Dominator GT i7 Memory Kit with Airflow Fan CL7(7-8-7-20) 1.65V Unbuffered Non-ECC
    5) 2x Western Digital RE3 500GB (On Raid 0)
    6) LG Super Multi Blue - DVD±RW (±R DL) / DVD-RAM / BD-ROM / HD drive
    7) Asus Xonar D2X Sound Card
    8) Thermaltake 1500W PowerSupply
    9) MCP-655 D5 Pump + 2x TFC 360mm Radiator + 1 Single Bay Reservoir
    10) 6x 80mm ACryan Fans + 6x 120mm ACryan Fans
    More Photos Below:
    __________________
    "Shazbom Waterworld 2"
    - Intel Golden Chip Core I7 920 @4.5Ghz (24/7) - EVGA X58 Classfied (Fully Blocked) - Corsair Dominators 6GB DDR3 1866MHz @ 7-8-7-20 Timming - 2 x BFG 295 - 2 x 500GB Western Digital RE3 Raid 0 - 2 x TFC 360 Radiators - Thermaltake 1500W PSU - Asus Xonar D2X Sound Card & Lian Li PC-75
  2. spenc259
    spenc259 in the build stage!!!
    23 Oct 2008
    Nice system and lots of HDD space! nice!
    what progress have u made with the project?
    are you doing your loop at the mo?
  3. Shazbom
    18 Jan 2009
    Hi Spenc259. I've started working on it. I'll be posting photos soon. Below is the case i'm using.
  4. Shazbom
    18 Jan 2009
  5. Shazbom
    18 Jan 2009
  6. spenc259
    23 Oct 2008
    thats a nice case you have! i am fairly new to water cooling as well but when i was learning i just used google and you tube! lots of good vids out there!!!
    if u want to start yourself then you should have a think about your cooling loop! installing everything is fairly straight forward...
  7. Shazbom
    18 Jan 2009
    I even bought a D5 X top for my swiftech MCP-665 pump.
    My swiftech MCP-665 pump.
  8. Shazbom
    18 Jan 2009
  9. Shazbom
    18 Jan 2009
    Here is my Intel QX9650 CPU before Lapping.
    This is what it looks like after Lapping with 400/600/800 and then 1200 grit papers. It should be smoother but i couldn' t get any 1500/2000 papers on friday so i stopped here.
    I'll be buying the finer papers soon. I'll add another photo after lapping has been finished.
  10. Shazbom
    18 Jan 2009
    The right 1 is bones's Lian li case. He'll be adding a Radiator on the bottom of the case.
    The left 1 is mine and the radiator is going on top of the case.
    Bones sending my case for me while i'm taking a pic.
    After installing my TFC eXchanger 360 Radiator. Looks great.
    Bones trying on his old acetek 120.3 Radiator.
  11. TiTON
    TiTON IRONMODS
    23 Mar 2004
    Modding Indoor.. that is GANGSTA!!! :) Hope you got a good vacuum to get all those metals shards :)
    Great start.
    Ton
  12. Shazbom
    18 Jan 2009
    Yah Ton.. me and bones both feel very cold so we perfer do it indoor. everynight take us 1 hour to clean everything up. The Big Vacuum cleaner is in 1 of the photo too. :wallbash:
  13. Shazbom
    18 Jan 2009
    HELP HELP HELP!!!!!
    Hi All readers. Today i was trying to take all the heatsinks out and puting on my EK Blocks but i accidentally broke (pull out ) one of the leg of a inductor. I've been trying to look for it but dont know where i can find excet 1s. can anyone please help.
    This is the 1 i broke.
    Its Called 1r0 820 mha inductor
    by the way, my motherboard is Rampage Extreme Motherboard X48
  14. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    Can't you just add a bit of solder or super glue + solder paint to fix it?
  15. Shazbom
    18 Jan 2009
    i was trying to.. but cannot. because it is broken from right on top. i can see the outsite pin but nothing inside. it wont solder on. the best is to buy a same inductor. . does anyone knows where i can look for 1?>:waah:
  16. 985323
    985323 I am Jack's smirking revenge
    1 Oct 2008
    why dont you hit it with some super glue so it stay's on then get it rma'd
  17. alpaca
    alpaca llama eats dremel
    27 Jan 2009
    can you rma things with coolers ripped off?
  18. Guest-23315
    Guest-23315 Guest
    No, but you can put it back on and send it off.
  19. Shazbom
    18 Jan 2009
    I know but i dont wanna do that. feel bad. it was my fault breaking it anyways.
    I think i should just wait and see if anyone can help me find the same inductor so i can change it myself.
    Its not a very big damage but its just that you cant find this inductor anywhere. .
    Xtrafresh likes this.
  20. GavX
    GavX What's a Dremel?
    5 Apr 2008
    Might as well RMA it, oterwise you are £200 out of pocket, but if you really don't want to, get the soldering iron out boy! :D
