Old 28th Jan 2009, 09:18   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
Scythe Fenris Wolf
http://www.bit-tech.net/hardware/200...-wolf-review/1
Usually a company more associated with heatsinks than chassis, Scythe has just released the ultra silent Fenris Wolf. With all aluminium construction and a whisper quiet cooling system, can the Fenris Wolf prove a worthy entry into the enthusiast case market? Read on to find out!
Tim S is offline   Reply With Quote
Old 28th Jan 2009, 09:25   #2
Jipa
Avoiding the "I guess.." since 2004
Jipa's Avatar
Jipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run CrysisJipa can run Crysis
Ahhah that side panel reminds me of some cheap-ass case I had... I figured it wasn't worth even selling and decided to dump it.
At this stage I found out that I could bare-handedly fold the side panels twice in half. Handy, fits in a normal dust bin.
Nice review, less nice case.
__________________
Half a dozen operational setups and truckloads of spare parts.
AllTheMods - MetkuMods - LedCalc - Flickr - BF:BC2
Jipa is offline   Reply With Quote
Old 28th Jan 2009, 10:02   #3
[USRF]Obiwan
I *am* a Dremel
[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.[USRF]Obiwan is the Cheesecake. Relix smiles down upon them.
I had such a case 21 years ago....
__________________
[USRF]Obiwan is offline   Reply With Quote
Old 28th Jan 2009, 10:15   #4
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Looks like a sturdy case despite its flaws. I like the drive bays lol.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 28th Jan 2009, 10:32   #5
azrael-
I'm special...
azrael-'s Avatar
azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!azrael- - it's over 9000!!!!!!!!1!1!1!!!
I can't seem to find the case dimensions stated anywhere in the review. Am I missing something?
Also, on page 4 (Testing and Results) "someone" was a bit too quick reusing the text from the Lian-Li PC888 review...
Shame about the case, by the way. I really need to replace my Lian-Li PC61 as I just can't get it to be quiet. The Antec P182 is my first choice at the moment, but the door opens to the wrong side, it's heavy and I already sense the loss of a removable motherboard tray (like the PC61 has).
__________________
It's not the end of the world ...but you can see it from here.
Xeon E3-1245 v2 3.4 GHz | ASUS P8C WS | 16GB Kingston ECC DDR3 | Samsung 830 256GB | eVGA GTX670 2GB | SB Audigy | Seasonic X-560 | Corsair Obsidian 550D | Dell 2209WA
azrael- is offline   Reply With Quote
Old 28th Jan 2009, 10:51   #6
djDEATH
Habari gani?
djDEATH's Avatar
djDEATH has yet to learn the way of the Dremel
FAIL
__________________
BEASTIE-II Asus N550LF CK-108H Core i7, GT745M B&O Speakers
djDEATH is offline   Reply With Quote
Old 28th Jan 2009, 11:12   #7
naokaji
whatever
naokaji's Avatar
naokaji has yet to learn the way of the Dremel
It does look good in my opinion, also it's a good thing to see they used quality fans and that it is quiet.
But, a 130£ case with the easy bend panels of a 40£ case? meh.. not my thing.
What worries me most though is the quality of the door hinges, those will be subject to a lot of abuse during regular useage, so why would any case manufacturer cut corners there? It just doesn't make sense, go save elsewhere please.
About the HDD mounting, they should have copied lian li, nothing beeats their easy to attach screws with rubber to silence the hdd then just slide it in.
I don't mind paying a lot for a case, but if I end up doing so I do expect a lot from it.
__________________
920 D0, EX58-UD5, 6GB OCZ 1333 @ 1600 7-6-6, 4870x2, 128 GB Samsung PB22-J SSD and 2 old 500GB WD's, Seasonic M12 700W, Cosmos S
Opportunity is like delivery by DHL, it does not come to you, you have to track it down and chase it
naokaji is offline   Reply With Quote
Old 28th Jan 2009, 11:21   #8
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
Tee hee, that made me giggle too.
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 28th Jan 2009, 11:50   #9
Baz
I work for Corsair
Baz's Avatar
Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.Baz is the Cheesecake. Relix smiles down upon them.
At least I know some people read every word!
Baz is offline   Reply With Quote
Old 28th Jan 2009, 16:15   #10
cjmUK
Old git.
cjmUK's Avatar
cjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run CrysiscjmUK can run Crysis
I've got a P180, but I'm always on the lookout for the next improvement. But I haven't seen a single case to beat it in terms or noise, space, build quality, cooling and cost (apart from the P182!).
I wondered if the Fenris Wolf was the spritual successor to my case, but no... another pretender to the throne falls by the wayside.
From a hobbyists point of view, it's a shame I've got nothing to aspire to; from the wife's point of view, it's reassuring that there is one less thing to blow some money on. For now, at least.
__________________
FD Define R4, i7 920 [with Thermalright HR-01+/Noctua NF-P12], Gigabyte EX58A-UD3R, 6GB Corsair XMS3 PC2-12800, MSI R9 280X
cjmUK is offline   Reply With Quote
Old 28th Jan 2009, 19:16   #11
Jipa
Jipa's Avatar
So far 19 cases tested and I've always returned back to my modified P180B at the end of the day :P Now the poor P180 is again under some modding to fit some new goodies.
__________________
Old 29th Jan 2009, 15:44   #12
Phil Rhodes
Hypernobber
Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.Phil Rhodes is a hoopy frood who really knows where their towel is.
Now I fully appreciate that there are horses for courses and cases for... er... computers, but it's the names that get me? "Scythe Fenris Wolf?" Sounds like an anime bad guy with Ming the Merciless eyebrows. It's a bloody BOX.
Phil Rhodes is offline   Reply With Quote
Old 29th Jan 2009, 23:25   #13
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
honestly overall it really isnt that bad of a case but just not something I would be interested in.
__________________
Current Rig: Project STEALTH
• DimasTech Test Bench • Black ICE Triple 120 Rad • Dual Bay Res/Pump • DD Fill Port & Res • D-Tek FuZion 2 CPU Block • ASUS M3A79-T Deluxe Mobo • AMD Phenom II 3ghz @ 4ghz • 8gb DDR2-1100 Memory • (2) AMD 6870 XFire • (2) WD Black 640gb Raid 0 • (2) 1.5TB SEAGATE • Blu-Ray/HD DVD Drive • ASUS XONAR DX2 • 30" DOUBLESIGHT LCD • (2) 23" ASUS LCD • ZALMAN 8 FAN CONTROLLER • (4) NOCTUA P12 • (2) NOCTUA P14 • 1000W ZALMAN PSU • WINDOWS 7 PRO 64 •
HourBeforeDawn is offline   Reply With Quote
Old 30th Jan 2009, 07:34   #14
[USRF]Obiwan
I *am* a Dremel
Not a bad case if it was 40 euro. Where it suppose to fit in the price range of the, for example, Coolermaster Centurion
__________________
Old 30th Jan 2009, 11:26   #15
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyankenco_uk is a Super Spamming Saiyan
I had a P180 but there's no way I'd be able to fit five hard drives and a GTX260 in it. The 8800GTX I had whilst I had a P180 was a tight enough fit!
The Coolermaster Cosmos that has replaced it is nearly as good. There's a lot more space, which is a major plus. It lacks a little of the internal refinement of the P180, but works just as well.
__________________
formaggio gβteau
kenco_uk is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
