Reply
Thread Tools View Mode
Old 4th Mar 2009, 15:46   #181
wgy
Supermodder
wgy's Avatar
wgy has yet to learn the way of the Dremelwgy has yet to learn the way of the Dremelwgy has yet to learn the way of the Dremel
great mod
wgy is offline   Reply With Quote
Old 4th Mar 2009, 16:47   #182
sortableturnip
Minimodder
sortableturnip has yet to learn the way of the Dremel
Originally Posted by legoman666 View Post
It will be enclosed but not sealed. What sort of vibrations are you envisioning? It would take some pretty powerful vibrations to splash the oil out. The case will be too heavy to move, so I don't think that will be a problem
My thought was that the hard drive(s) will vibrate when used, which could cause some ripples in the oil if they are attached to the back plate. Also, I'm assuming that the back plate will be partially submerged in order for the oil to flow completely over the PSU.
BTW, I'm no expert on mineral oil or doing a project like this...these are just thoughts I have
sortableturnip is offline   Reply With Quote
Old 4th Mar 2009, 17:03   #183
legoman666
Beat to fit, paint to match.
legoman666's Avatar
legoman666 has yet to learn the way of the Dremellegoman666 has yet to learn the way of the Dremel
I think you have more important problems if you're hard drives are vibrating The model is not up to date, the PSU will be a little lower in the oil than it shows in the pic. Keep the comments coming.
legoman666 is offline   Reply With Quote
Old 4th Mar 2009, 17:03   #184
dark4181
Ero-sennin-tebayo
dark4181's Avatar
dark4181 has yet to learn the way of the Dremel
Pretty nice scratch build so far. Have you been looking at Hardcore Computers' Reactor PC for inspiration? It has a lot of similarities to what you're doing here
__________________
Intel e6550, eVGA 680 A1 D00 revision (P32 BIOS, latest drivers) eVGA 7900gs, 2x1GB Corsair XMS2 800Mhz @ 1.85v, Corsair 620HX, Seagate Barracuda 500GB x2, Pioneer DVR-212D (SATA), CoolerMaster Cosmos S
dark4181 is offline   Reply With Quote
Old 4th Mar 2009, 17:21   #185
legoman666
legoman666's Avatar
Thanks I've seen that Reactor PC before, but I didn't deliberately try to copy any of it's features. I think a lot of the similarity between different mineral oil cooled computers is due to the fact that it's the most logical design. It'd be hard/impossible to seal the back ports on the motherboard, so the easy thing to do is point the motherboard upwards.
Old 4th Mar 2009, 17:25   #186
dark4181
Ero-sennin-tebayo
dark4181's Avatar
I hear you. I certainly didn't mean to imply anything negative, on the contrary, I think that yours is impressive, being a home project on a limited budget.
Still, the Reactor is freaking amazing O.O
__________________
Old 5th Mar 2009, 12:45   #187
Stormwulf
A mod to far?
Stormwulf's Avatar
Stormwulf has yet to learn the way of the Dremel
Been watching this with interest as i've been meaning to build one for appx 4 years lol but never seem to find the time ( even got the shed full of aluminium to be used ).
Looks great so far and am looking forward to watching it evolve further
p.s. must have really piqued my interest to make me join a forum
Stormwulf is offline   Reply With Quote
Old 5th Mar 2009, 13:11   #188
legoman666
legoman666's Avatar
Thanks. Just sit down one weekend and start drawing up plans! I started by drawing sketches while bored at work and it kind of snowballed from there. Being bored is expensive.
+cookie for using the correct "piqued" instead of "peaked"
Nothing negative was inferred It was more of a general observation.
Old 5th Mar 2009, 13:39   #189
Stormwulf
A mod to far?
Stormwulf's Avatar
The problem i have is more a case of an overactive mind and my constant struggle to keep up with ideas lol.
The aluminum ( american spelling to make it easier on everyone ) is bosch rexroth profile stuff for construction. I figured it would prove interesting as it already has a channel in it which would make for great fitment of the acrylic/perspex/polycarb sheets.
It has to be said that its not the cheapest in the world though once you add in the cost of the fittings.
Fortunately a previous employer was kind enough to allow me to take about 20 metres of the stuff + fittings for my own personal use which i have already cut to lengths ready to make a fairly large cube shaped ( coffee table? ) pc.
Was thinking of building it as something of a room centrepiece lit up and it did also cross my mind to make a double skinned one with the outer portion being a tropical fish tank but i figure that may be quite hard to regulate the temperature lol ( obviously using temperature of the oil to heat the fishtank portion ( who says oil and water can't mix :P ).
One other difficulty with this idea is might have to consider glass instead because of possible toxic implications of the plastics on the fish.
See, sometimes i have the craziest of ideas.
Thanks for the compliment on my spelling btw.
Old 6th Mar 2009, 12:43   #190
legoman666
legoman666's Avatar
That sounds like a pretty neat idea. Do it and don't forget to post a project log here! Might have to get tropical fish or something to withstand the high water temps though.
Old 8th Mar 2009, 04:48   #191
legoman666
legoman666's Avatar
More Electrical Work
Today was a beautiful day. After a rather dreary beginning of the week with temps around 10F, it was a very pleasant 75F today. I went for a bike ride in the afternoon.
I decided I should probably test submerging some components in the oil. I'm mainly concerned with the oil eating away plastic, so I made sure to get 2 types of capacitors on my test subjects. My guinea pigs are a dead HD3870 and a 9200LE.
Then I got to some more serious work. Back shot of the wiring for the plugs and switches that the PSU and pump power cords will plug into.
And from the front. I think there is an LED in the switch, but I don't know how to wire it up.
I made sure to draw the template for drilling the holes on the back this time.
These actually aren't as much work to file as all of the buttons for the LCD were.
Still took a long time though.
And then with the two sets mounted and in place.
The wiring on the back.
Quick test to make sure it fits on the frame.
And now to wire up the internal outlets. I bought the conduit boxes, single outlet receptacles and the covers along with a few other goodies at Lowes today.
Then I bent a piece of aluminum for use as a mount.
And then did it again.
View from the top. 4 screws for each mount and a small 8-32 nut to hold it in place.
And what it looks like from the inside. I had to make sure to mount them out of the way so wires coming out of the motherboard wouldn't run into them. I almost mounted them in a position that would have made it impossible to plug stuff into the motherboard backpane.
The outlets wired up.
And all done.
That's where I stopped today. Since it was so nice, I went for a bike ride before dinner. Then after dinner I went and saw Watchmen, which was epic. Go watch it.
Old 8th Mar 2009, 06:31   #192
slisgrinder
Supermodder
slisgrinder has yet to learn the way of the Dremel
I just have a small question, why didn't you use a power bar/brick?
But great job though...you gave me a good idea about how to power my SE7ENTH COLUMN build...
__________________
Have dremel, Will mod...
World Domination One Mod at a Time...
Mod On...
WIP: SE7ENTH COLUMN (AKA: World Community Grid project)
slisgrinder is offline   Reply With Quote
Old 8th Mar 2009, 07:48   #193
.Fatality.
Multimodder
.Fatality.'s Avatar
.Fatality. has yet to learn the way of the Dremel
its amazing what all we moders can do with lidle alu and a dremel
.Fatality. is offline   Reply With Quote
Old 8th Mar 2009, 08:51   #194
Odin Eidolon
Mad rockclimber
Odin Eidolon has yet to learn the way of the Dremel
lol yeah it is.
awesome work so far
Odin Eidolon is offline   Reply With Quote
Old 8th Mar 2009, 15:48   #195
legoman666
legoman666's Avatar
Because I want to be able to control the two outlets separately. It would have been a lot easier with a power strip. Thanks for the question.
Thanks! Although I'll have you know that the dremel is one of my least favorite tools.
Originally Posted by Odin Eidolon View Post
lol yeah it is.
awesome work so far
Thank you.
Old 8th Mar 2009, 16:02   #196
aglaser
What's a Dremel?
aglaser has yet to learn the way of the Dremel
If I were you, I'd take the effort (considering what you've already put into this PC) to find the pinout for the switches, and see if there is an LED in them and how to wire it up if there is.
aglaser is offline   Reply With Quote
Old 8th Mar 2009, 21:33   #197
Mino
Ganzerli Mino
Mino's Avatar
Mino has yet to learn the way of the Dremel
Good work!
Unfortunately, I see Watchmen, with my wife... Not a good film for us, maybe tomorrow we will go to see Underworld :-)
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding
Mino is offline   Reply With Quote
Old 8th Mar 2009, 22:46   #198
legoman666
legoman666's Avatar
I looked at the spec sheet, but it didn't mention anything. To be honest, I'm not 100% certain there actually is an LED in there. It just looks like there is.
Originally Posted by Mino View Post
Good work!
What! I thought it was really good, but I suppose the copious amounts of over the top violence might not be everyone's cup of tea.
I wouldn't recommend Underworld. Just a sub-par action flick feeding off the success of the first Underworld movie. If The Reader is still showing at your local theatre, I'd recommend that. Or maybe Slumdog Millionaire if you haven't seen that yet.
Old 8th Mar 2009, 22:51   #199
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Nice work, great innovation.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 9th Mar 2009, 01:56   #200
Stormwulf
A mod to far?
Stormwulf's Avatar
Looking good.
Very good idea for power distribution, very neatly executed
Edit: BTW, quite a few of those type of switch don't actually have LED's in even though they look like they should.
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
