Reply
Thread Tools View Mode
Old 31st Jan 2009, 21:29   #21
tominated
Supermodder
tominated's Avatar
tominated has yet to learn the way of the Dremel
as you may have just discovered. acrylic is best cut using the slow setting on power tools.
tominated is offline   Reply With Quote
Old 1st Feb 2009, 00:51   #22
The boy 4rm oz
Project: Elegant-Li
The boy 4rm oz's Avatar
The boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the DremelThe boy 4rm oz has yet to learn the way of the Dremel
Yeah slow and steady with acrylic. Drop the RPM down on the scroll saw and it will cut the plexi not melt it.
__________________
Project: Elegant-Li *NEW*
Project: Alpha FINISHED
Project: LEXA Revival FINISHED
Project: LEXA FINISHED MOTM Nominee October 08
The boy 4rm oz is offline   Reply With Quote
Old 1st Feb 2009, 02:10   #23
legoman666
Beat to fit, paint to match.
legoman666's Avatar
legoman666 has yet to learn the way of the Dremellegoman666 has yet to learn the way of the Dremel
It has 2 settings, high and low. It melted the plexi on both
legoman666 is offline   Reply With Quote
Old 1st Feb 2009, 02:15   #24
modsquad
Grease Monkey Undergraduate..
modsquad's Avatar
modsquad has yet to learn the way of the Dremel
You have a very-cool (unique) project underway..
modsquad is offline   Reply With Quote
Old 1st Feb 2009, 03:07   #25
The boy 4rm oz
Project: Elegant-Li
Then it looks like you may have to use a Dremel or a Jigsaw for the inside cuts.
__________________
Old 1st Feb 2009, 04:00   #26
talladega
I'm Squidward
talladega's Avatar
talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.talladega is a hoopy frood who really knows where their towel is.
What kind of blades are you using? Maybe try getting some specifically made for plastic. My scroll saw (Delta) worked great on plexi. But I used the wrong blades so the cuts were ugly.
__________________
"...clearly poop is not nutritious and it tastes bad." -Bindibadgi
"Get off... my... property!"
-Clint Eastman, in Grand Tornado
talladega is offline   Reply With Quote
Old 1st Feb 2009, 04:19   #27
legoman666
legoman666's Avatar
Thanks.
Yarrrgg
It was probably a blade designed for wood. I didn't even think about it. There a quite a few other blades I can try; there's a whole container full next to the saw.
I was bored today so I messed around in the shop trying to come up with a decent design for the case feet. Here's what I came up with.
It was a lot of work making those 2 pieces of 1/4" aluminum perfectly round... But I think it turned out pretty well. I won't use this particular foot on the final case as it's not quite up to scratch. However I will probably use the design. Thoughts?
Old 1st Feb 2009, 04:50   #28
talladega
I'm Squidward
talladega's Avatar
Very cool foot design! To reproduce them easier you could just buy aluminum round rod the right diameter and cut 1/4" slices off.
looks great!
__________________
Old 1st Feb 2009, 06:53   #29
tominated
Supermodder
tominated's Avatar
wow. i like that foot, especially the lighting effect
Old 1st Feb 2009, 09:03   #30
The boy 4rm oz
Project: Elegant-Li
Now they are cool case feet. I may need to ste...I mean borrow that design .
__________________
Old 1st Feb 2009, 16:49   #31
legoman666
legoman666's Avatar
Foot Making Process
Here's the process by which I make the feet. It's a lot of work.
First I made a template so I don't have 4 slightly different feet on my case.
I traced the outline onto a big piece of 1/4" thick aluminum.
I do the rough cuts with a band saw.
Then I drill a hole in the center so I can stick a bolt through it.
I made a little jig on the belt sander so I can easily do the rough sanding. I just stick the bolt with the rough cuts into the wood and slowly spin it to a circle.
It gets hot enough that I often have to dunk the aluminum into water. You can see the water boiling in this pic.
All done on the belt sander....
...Now onto the drill press. I moved the belts around to get around 2000 RPM. On the press I use various grits of sandpaper to get the edges nice and smooth.
Then I put the template back on and drill the remaining two holes.
And tap them.
I use a bigger drill bit to countersink the screws.
I repeat the process with the piece of plexiglass and then sandwich it between the two discs of aluminum.
All done and polished. (Or at least as smooth as I care to make it.) 1 foot took about 1.5 hours to make.
Final product.
Old 1st Feb 2009, 17:50   #32
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
Excellent work, but please mount the discs much closer to the chuck in the drill press. I know it's a 1/4" bolt, but if it goes off balance the results are deadly!
The plexi you were working with was likely extruded plexi. Yeah, it sucks... Cell cast stuff can be cut with a scroll saw. You can cut this stuff with one if you add a little water to the process. It's tricky and a little dangerous, and it slows the cutting down a lot. Just don't get the motor or switches wet.
Cheapskate is offline   Reply With Quote
Old 1st Feb 2009, 20:29   #33
Mino
Ganzerli Mino
Mino's Avatar
Mino has yet to learn the way of the Dremel
Interesting project, Ill follow your progress!
Anyway, for the sensor probe in the tubing, use a T junction, it's easy to work with!
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding
Mino is offline   Reply With Quote
Old 1st Feb 2009, 21:56   #34
Nolimited
Supermodder
Nolimited's Avatar
Nolimited has yet to learn the way of the Dremel
Nice foot and with the red light it give a good effect
__________________
Blue Flames - Case Finish Nominated for MoM - March 2009
Nolimited is offline   Reply With Quote
Old 1st Feb 2009, 23:05   #35
Loom
Supermodder
Loom has yet to learn the way of the Dremel
Looks good!
Loom is offline   Reply With Quote
Old 2nd Feb 2009, 12:10   #36
legoman666
legoman666's Avatar
Good advice, I hadn't thought about it becoming unbalanced while spinning at 2000RPM. I made another foot last night and I pushed the bolt as far into the chuck as I could.
The plexi I ordered for the tank is all cast, not extruded. Hopefully should be easier to work with.
That's the plan!
Originally Posted by Loom
Looks good!
Thanks!
Old 4th Feb 2009, 02:31   #37
legoman666
legoman666's Avatar
PS, I need a better name. Start the suggestions.
Old 4th Feb 2009, 02:40   #38
The boy 4rm oz
Project: Elegant-Li
Wet Tech? lol
__________________
Old 4th Feb 2009, 04:04   #39
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
Wet Tech
+1
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 4th Feb 2009, 12:03   #40
legoman666
legoman666's Avatar
Originally Posted by 500mph View Post
+1
Yes but is oil considered wet?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
