Reply
Thread Tools View Mode
Old 10th Feb 2009, 14:46   #81
sortableturnip
Minimodder
sortableturnip has yet to learn the way of the Dremel
All of the work you have done so far is fantastic!
One question though: Would it be more feasible to put the radiators above the mineral oil chamber? That way, the weight is at the bottom, which would put less stress on the brackets and make it more stable (less top heavy). Also, since the hotter mineral oil would rise to the top, make it easier to cool?
sortableturnip is offline   Reply With Quote
Old 10th Feb 2009, 15:06   #82
Odin Eidolon
Mad rockclimber
Odin Eidolon has yet to learn the way of the Dremel
seems like a good idea to me.
this one is gonna be one of the most heavy case of the world
Odin Eidolon is offline   Reply With Quote
Old 10th Feb 2009, 16:33   #83
legoman666
Beat to fit, paint to match.
legoman666's Avatar
legoman666 has yet to learn the way of the Dremellegoman666 has yet to learn the way of the Dremel
Yes, that would be the ideal design. I struggled when I designed the general layout. The problem is that the cables coming from the motherboard have to go in the top of the case. My intent is to make the motherboard tray semi-removable like this:
Using a drawer slide similar to this. The top aluminum portion is going to be on hinges so I can pull the slide out. I wouldn't be able to do this if the radiators were on top.
legoman666 is offline   Reply With Quote
Old 10th Feb 2009, 17:47   #84
sortableturnip
Minimodder
what about an opening in the back a la the SilverStone Raven RV01:
You could make the tubing from the radiators to the mineral oil chamber have QDC's (Quick disconnect connectors)
Old 10th Feb 2009, 18:01   #85
legoman666
legoman666's Avatar
Yes, that is the plan. However, the cables all still come out of the "top" of the motherboard.
Old 10th Feb 2009, 18:35   #86
sortableturnip
Minimodder
Having it on the bottom has its advantages as well...keeps the build simple. The only way I can see keeping the radiators up top and making the motherboard semi-removable would be to either have the radiators on the side/back and have the input/output at the top or put the radiators on top and have the enclosure on top removable or hinged so that you can access the mobo easily. Might be more trouble than its worth to build it that way.
Man, I wish I was good at using CAD programs, could show you pics of what I mean...
Old 11th Feb 2009, 16:18   #87
legoman666
legoman666's Avatar
Someone needs to make a mineral oil cooled computer similar to how a transformer is designed.
Like this. Transformers use natural convection to keep the oil cool. This particular transformer is made for 100% passive operation.
I got a shot of the stuff we (the utility I work for) use in transformers. Here's some data I looked up on it, thought other folks might find it interesting:
MSDS Sheet: http://www.equivashellmsds.com/Displ....asp?ID=202481
Specifications: http://www.nttworldwide.com/docs/diala-ax.pdf
The highly refined mineral oil contains <3% (w/w) DMSO-extract, according to IP346.
Highly refined mineral oils and additives.
I need to get myself a drum of it.
Edit: Sweet, I asked the dude if I could buy 10 gallons of this stuff: http://cgi.ebay.com/Shell-Diala-HFX-...QQcmdZViewItem That would be awesome.
Old 11th Feb 2009, 18:29   #88
AFX
"Bling" Silver Mountain 2
AFX's Avatar
AFX has yet to learn the way of the Dremel
subscribed!
__________________
P5B Deluxe|q8300|HR-01 Plus|2GB OCZ+2GB Corsair|ATI HD4850 512MB|Antec Trio 650W|Audigy 2 Platinum ZS|WD250|WIN7+WINXPFTW
Flickr
AFX is offline   Reply With Quote
Old 11th Feb 2009, 20:17   #89
sortableturnip
Minimodder
That's cheaper than mineral oil by about $3/gal...didn't know mineral oil was that expensive!
Old 11th Feb 2009, 21:57   #90
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for presidentCheapskate should be considered for president
You could build your computer case like that transformer. You just need some copper pipe and an *ssload of 90 degree elbows and tees. You could probably solder the whole mess into a steel box easily.
Cheapskate is offline   Reply With Quote
Old 11th Feb 2009, 23:57   #91
legoman666
legoman666's Avatar
Little side project I'm working on
Dual P3 933Mhz, 256mb PC600 Rambus, Voodoo 5 5500 AGP with the intent of playing all of the old school games I missed ~2000. I have these games in the list:
Baldur's Gate II
Deus Ex
Gothic
Grim Fandango
Half Life
Icewind Dale
Max Payne
Myth
No One Lives Forever
Planescape: Torment
Quake 3
Red Alert
System Shock 2
Thief - The Dark Project
Tribes
Should be awesome! I just need a case for the beast... Weird thing, the bios on this ~10 year old board supports the mouse (USB no less) and has drop down menus. WTF.
Old 12th Feb 2009, 09:31   #92
NZ_mod_man
Multimodder
NZ_mod_man's Avatar
NZ_mod_man has yet to learn the way of the Dremel
Very, very, interesting. I'll have to keep an eye on this one.
Subscribed!
__________________
Gigabyte 945GCM-S2L / Intel E2160 1.8 @ 2.25GHz!!! / 2GB Kingston Ram / Seagate 80GB / Asus DVDR+/- with light scribe
Originally Posted by badders View Post
I know so many people like that...
Classic
NZ_mod_man is offline   Reply With Quote
Old 12th Feb 2009, 10:28   #93
tominated
Supermodder
tominated's Avatar
tominated has yet to learn the way of the Dremel
great idea with that transformer ol stuff. looking forward to see how this goes. let's hope it's a decent colour too
tominated is offline   Reply With Quote
Old 12th Feb 2009, 11:04   #94
Odin Eidolon
Mad rockclimber
some old games are still way better than new ones to me. nothing is better than Monkey Island
Old 13th Feb 2009, 02:16   #95
Loom
Supermodder
Loom has yet to learn the way of the Dremel
You fight like a dairy farmer.
Loom is offline   Reply With Quote
Old 13th Feb 2009, 03:50   #96
legoman666
legoman666's Avatar
Something I've been working on...
LED chaser lights! Weeeee. It took me forever to get that thing wired up. There are two potentiometers, one controls the brightness and the other controls the speed.
Yea, for some reason, the pinout for the 3rd LED doesn't work on the IC. Don't know what's up with that. I bought an extra one, so when I make the final design, I'll use the spare. The plan is to arrange the LEDs in a circle and use the circuit for the HDD activity light. I'll probably stick the LEDs behind some frosted plexiglass to help diffuse the light as well. Should be pretty cool.
Here's the circuit I used: http://www.electronics-lab.com/proje...003/index.html
Until next time...
Old 13th Feb 2009, 14:55   #97
Odin Eidolon
Mad rockclimber
oh crap, this wasnt in the Italian version
you beat me
Old 13th Feb 2009, 17:19   #98
Cheapskate
Cheapskate's Avatar
You will want an off switch on the chaser. They will bug the sh*t out of you after 2 minutes.
Old 13th Feb 2009, 19:01   #99
legoman666
legoman666's Avatar
Lol, probably.
Good news! I was talking to my boss at work and somehow we got to talking about this project. I explained what I was doing and why (lol, that's harder to explain than you might think) and the subject of mineral oil came up. I mentioned that I found an auction on eBay that was for the same type of stuff that we use but it would cost me ~$200 to get a hold of 10 gallons. Boss man took me to see the guy in charge of construction of new substations and told me to explain my project to him. The guy called someone up at the warehouse where we keep the oil and arranged for me to come pick up 10 gallons of the stuff for free some time next week!
Huzzah! Saves me $200. My only concern is that the stuff won't be clear. However, I've seen the inside of one of our freshly oil filled transformers and it was as clear as any other mineral oil I've seen, so I should be set.
Old 13th Feb 2009, 19:51   #100
Odin Eidolon
Mad rockclimber
Lol, probably.
yeeeh! lucky guy!
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
