#141 |
Mad rockclimber
really nice work, especially with the cristalfontz
#142 | ||
Beat to fit, paint to match.
Filing those little holes to the correct size took an entire morning. I'll try to come up with some ideas for the copper.
#144 | |
(and won't be seen anyway)edit: Wow holy crap. I wish I had that much money to spend! |
#145 |
Handcrafted
Although I'd never submerge my own PC, this is still a sick build! Nice design and great execution. Looking forward to see this in action.
A thought though, sure the pumps will handle oil? |
#146 | |
#147 |
E22.BIZ
Nice to see someone doing a oil scratch build and not just using an old fish tank and so far id say its the best oil PC build out there so far.. keep up the good work dude
#148 | |
Working hard at work, or am I hardly working? Anyway, here's an idea I came up with for the front of the case: ![]() The two circles on the top section are the power and reset bulgin switches. The slit is a slim slot loading dvd burner. The black square is a 8" LCD screen I just got hooked up. The detail is all copper. And of course, the LCD at the bottom is the Crystalfontz screen. I'm not 100% set on any of this, but I particularly don't like the curvy thing I drew in between the two screens. ![]() Here's a crappy pic of the 8" LCD panel I have. Nifty little thing is 640x480, has VGA, composite and s-video input. EDIT: ![]() Or maybe this better. Power button on the bottom, reset on top. The power button I bought has a black housing which will match the color of the grills and screws. The reset switch still isn't decided yet. Last edited by legoman666; 24th Feb 2009 at 16:01. |
#149 |
Minimodder
#150 |
Each rad will have its 3 fans tied together and connected to a single channel on the Crystalfontz SCAB pwm controller. I will take the RPM monitoring from one of the fans The wires will obviously be tucked out of the way so the fans don't eat them.
#151 |
Mad rockclimber
did you see the new MCR stackable rad series? i bet you could fit 4 or 5 of those there
#152 |
Ganzerli Mino
From your two drawings, I preffer the first one for the copper curves, and the second one for the pwr/reset switch position.
Just a question... how do you plan to isolate the rear portion of the lcd? Keep up the good works!
__________________
ItaliaModding.it Staff - Italia Modding Club Member
My project ::: Project AralT3 - Project UltraViolet - Impossible Modding |
#153 |
Weekday Night Modding
This is an aggregate of the work I've done in the past few days. I don't get home early enough to get any serious modding done during the week.
![]() Specs of the MicroATX PSU that I'm considering using to power the lower compartment. It's left over from another mod (peltier drink cooler). ![]() It won't fit with the casing on, so off it goes. ![]() Barely has any clearance. I don't think I'll use it. I already have to run a few cables from the upper compartment to the lower compartment; USB, 2 temp sensors, and Reset. The PSU eliminates the need for 3.3v, 5v, 12v, and GND. But it also adds the complication of 1 more point of failure and the need for another relay. ![]() So I cooked this up real quick as a solution. I'll place a few of these down the back of the case to guide the wires nice and straight. 1 on the bottom aluminum section made out of alu, 2 on the plexi section made out of plexi, and 1 more on the top section. ![]() All nice and done. The wires will all be sleeved the same color so they look uniform and neat. ![]() I cut some of the remaining aluminum sheet metal to 18.5" width so I can rip the pieces for the upper section from it. ![]() The two long sides. ![]() And the rest. ![]() The top section will be removable. It's still up in the air whether it'll be hinged or not though. I want to hinge it, but I can't think of an obvious place to attach the hinges on the lower section. I'll take a look at the different kinds of hinges the next time I go to the hardware store. ![]() The top section will simply sit on top of these pieces of 1/2" angle aluminum. The pencil mark is how far down the aluminum goes. The ~1/4" of overlap is intentional. ![]() ![]() And here it is all together. The top section is simply taped for now. What do you think? |
#154 |
Use your teeth not a Dremel
FANTASTIC work so far!
Not that I doubted you but this is turning out much better than I thought possible. Great job!
#155 |
Raspberry Pi owner
looking really good, makes me wanna do a oil computer
![]() would avoid using an extra psu if possible adds complications. |
#156 |
I'm Squidward
Have you hooked up and used the SCAB yet? I was wondering how many fans it can control. Also can you use it to control other things like turning your pump or case lights on and off?
I can't wait to see this finished. It's really amazing.
__________________
"...clearly poop is not nutritious and it tastes bad." -Bindibadgi "Get off... my... property!" -Clint Eastman, in Grand Tornado |
#157 |
Mad rockclimber
i like the first design you posted more than the second.
why dont you etch on the front the name of the project? |
#158 | ||||||
Yeah, those were my thoughts. I would do it if I didn't have to run any other cables down there. But running 3 bunches instead of 2 isn't that big of a deal.Quote:
As for controlling lights, pumps and such, I see no reason why not. I won't be able to use it for my pump since it's 120v AC, but it should be able to drive a DC pump as long as you don't exceed the maximum current rating for the SCAB. The SCAB is rated for 1.5A per fan header with the total of the 4 headers not to exceed 4A. So that's 18w per channel, not to exceed 48w total. The popular MCP655 uses 24w, so it doesn't look like you could control it unless you did some sort of fancy parallel connection over 2 headers. Quote:
I bet any existing rad could be modified for use in a stack. You would have to drill a hole in the tank for a new barb opposite the existing barb, but it could be done!Quote:
Thanks for the comments everyone! Last edited by legoman666; 26th Feb 2009 at 12:34. |
#159 |
Minimodder
Now you're cooking with oil (figuratively)
One question...where are the hard drives going to go? |
#160 |
| Thread Tools | |
| View Mode | |
