Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 6th Feb 2009, 16:55   #1
craigbru
Now... with more CNC!
craigbru's Avatar
craigbru has yet to learn the way of the Dremelcraigbru has yet to learn the way of the Dremel
New concept (OSIDIAS), The CNC arrives!
Hey guys, I'm throwing around ideas for another new case... one that will likely be built before Duality. I've been sketching up some ideas and wanted a little feedback. Keep in mind that what you are about to see, is unfinished, and missing some key details. However, I like the concept, but I want your opinions on how it all fits together.
Okay, here is the core of the case. It's SFF of course, and it's damn tiny due to efficient space usage. I'm planning a DFI X58, SLI, full size PSU, 4 full size hard drives, pico, and watercooled CPU in this little package. Due to it's design, it should also run fairly cool. As of now, I don't plan on deviating much from this except for details like adding mesh, or possibly windows.
I was then inspired by a RED camera cage I saw, and wanted to add a more industrial and sci-fi look to the case. The following is what I came up with. Of course it's subject to revision, but wasn't sure how it all fit together.
Opinions?
__________________
Originally Posted by disturbed13
'to cram everything in the box, you must think outside the box'
craigbru is offline   Reply With Quote
Old 6th Feb 2009, 17:32   #2
Cheapskate
↓ Don't trust that face!
Cheapskate's Avatar
Cheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming SaiyanCheapskate is a Super Spamming Saiyan
I like it. Have you got the insides finalized?
__________________
The Iron Turnip·BlooBalls·Hypnotoad·Plank·Reservoir-Things·NUC-Tooobular·C7Waterblocks·Crusty McBeanbags III·GlassGreen
Powered by: AMD·Gigabyte·Swiftech·Hardware Labs·Noctua·DangerDen
Cheapskate is offline   Reply With Quote
Old 6th Feb 2009, 17:40   #3
craigbru
craigbru's Avatar
Thank you. The inside is about 75% complete. Everything will be mounted to an expanded motherboard tray. Meaning that the entire assembly will slide out of the rear of the case. That includes the radiator and loop as well. The only thing still in the case would be the fans on the left side, and the hard drives.
__________________
Old 6th Feb 2009, 17:40   #4
murtoz
Busy procrastinating
murtoz has yet to learn the way of the Dremel
I like the concept a lot! The 'frame'/'handles' you added gives it that bit extra... Makes it look finished somehow. But it does seem that it's sticking out quite far on the sides making the whole thing quite wide - I'd prefer it a bit closer in. Otherwise you may as well build a full ATX case ;-)
murtoz is offline   Reply With Quote
Old 6th Feb 2009, 17:46   #5
craigbru
craigbru's Avatar
Sounds like we're on the same page. I had thought about narrowing the frame up a little. I guess it's hard to get a sense of scale here. The case as it is now, is only 37 cm (14.5") deep, and that's the largest dimension.
__________________
Old 6th Feb 2009, 19:01   #6
murtoz
The side handles currently bulge outward. How about if they would bulge inwards?
Front view:
Code:
(Don't you just love ASCII art?)
Old 6th Feb 2009, 20:51   #7
craigbru
craigbru's Avatar
The ASCII art is a very nice touch. I approve! It's a pretty simple step to invert the sides. I'll do that when I got home and post up.
__________________
Old 6th Feb 2009, 21:13   #8
slisgrinder
Supermodder
slisgrinder has yet to learn the way of the Dremel
Kewl modeling skillz, is it in Maya? of 3dsMax? or if I am stupid and I don't realize that is sketchup...
__________________
Have dremel, Will mod...
World Domination One Mod at a Time...
Mod On...
WIP: SE7ENTH COLUMN (AKA: World Community Grid project)
slisgrinder is offline   Reply With Quote
Old 6th Feb 2009, 21:20   #9
craigbru
craigbru's Avatar
Nah, it's none of the above. It's actually ViaCAD, and I'm man enough to admit that I love it...
__________________
Old 6th Feb 2009, 21:20   #10
slisgrinder
Supermodder
kewl...
__________________
Mod On...
Old 6th Feb 2009, 23:28   #11
Cheapskate
Cheapskate's Avatar
Inverting the handle curves would make it look more square, as would bringing them in. The way you have it now is much better. It breaks up the cube-iness.
I like the idea of a one-piece frame. I can tell you from experience to be careful about the cables. Plank has a special set of 'shoe horns' for assembly purposes. The more space you have between the walls and the frame, the better.
__________________
Old 7th Feb 2009, 02:33   #12
slisgrinder
Supermodder
I like the way the rad is sitting, gives it a more of an nuclear detonator kind of look...
GIVE US MORE!!!
__________________
Mod On...
Old 8th Feb 2009, 02:41   #13
craigbru
craigbru's Avatar
Front view:
Code:
Okay, I tried inverting the sides... and it's horrible. I'm not even going to bother posting the results. It simply doesn't fit the rest of the case at all. Lol, the ASCII art looks so much better.
Thanks Cheaps, I'll play a little more, but every time I try and deviate, the result looks much worse than what I have.
I'll be wary of the cables. Either that, or I'll use touch contacts like I did on the Rogue. No wires at all...
GIVE US MORE!!!
Thanks man. Just wait until you see it finished off. There's so many little things missing right now.
__________________
Old 8th Feb 2009, 16:55   #14
craigbru
craigbru's Avatar
I've been playing around... what do you think of holes? Or maybe some variation of this?
__________________
Old 8th Feb 2009, 21:04   #15
Javerh
Topiary Golem
Javerh's Avatar
Javerh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the DremelJaverh has yet to learn the way of the Dremel
Perhaps the holes should be more rectangular so they would fit with the look of those cooling ribs.
__________________
Project: Seawolf
Project: 1
Project: Flux (est 2012)
Modders make project logs. Project logs make mods. Mods make modders.
Javerh is offline   Reply With Quote
Old 8th Feb 2009, 21:34   #16
Editor22
E22 | Hex-Gear
Editor22's Avatar
Editor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming SaiyanEditor22 is a Super Spamming Saiyan
Cool compact design you got going there dude, What about adding some ally tubing in the front and rear of the case through those holes? would give some more protection and also another viable way to carry it :P could even sink some dials into the ends for fans etc.
__________________
Stores: E22 | HEX GEAR
Social: Youtube | Facebook
Projects: Evolution | K2 MK1 | 21
Editor22 is offline   Reply With Quote
Old 8th Feb 2009, 21:44   #17
tranc3
ADHD Modder
tranc3's Avatar
tranc3 has yet to learn the way of the Dremeltranc3 has yet to learn the way of the Dremel
Thats a sick design man. I personally think there should be somethign above the 2 fans in the last photo, something.still looks fantastic.
__________________
[AMD Kuma 7750 2.77 |Asus M3N78-EM|Mushkin 4x1GB DDR800 |WD Caviar 500GB|GeForce EVGA GTS 250 512MB|OCZ StealthXStream 600]
tranc3 is offline   Reply With Quote
Old 9th Feb 2009, 02:56   #18
craigbru
craigbru's Avatar
Interesting... I'll look into that.
Well, in order to add tubing, I'd have to bring the front and the rear, forward and rearward respectively. There isn't enough clearance to do that right now. Also, I'm going to trying to integrate a 7" touchscreen LCD to the front. However, just for fun, I did a quick and dirty preview of what you mentioned... It just didn't fit with the rest of the case...
Thank you. I'm looking to add something there. In fact, I'm working on something right now...
Okay, regarding the LCD I mentioned above... My last 3 mods have had one. In fact, I don't know if I could build a case for myself without one. Also, since this case will have another pico-itx on board, it's also needed for that. The question is, how the heck do I mount it so it doesn't look tacked on?
Here is the LCD in it's approximate position...
__________________
Old 9th Feb 2009, 04:10   #19
craigbru
craigbru's Avatar
Okay, one more here. I added vents to the side panels. What do you think... too many holes? They will have mesh behind them, with the exception of the most forward hole, that will have a window...
__________________
Old 9th Feb 2009, 08:39   #20
Editor22
E22 | Hex-Gear
Editor22's Avatar
Was bored while having my coffee this morning and thought id have a play on how you could mount that LCD didnt have much time but heres the idea I was thinking
__________________
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
