Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 24th Feb 2009, 09:19   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
Why the hard disk light needs to die
http://www.bit-tech.net/blog/2009/02...-needs-to-die/
Tim S is offline   Reply With Quote
Old 24th Feb 2009, 09:23   #2
Fod
what is the cheesecake?
Fod's Avatar
Fod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run CrysisFod can run Crysis
people still plug in their hdd leds?
if it annoys you so much, open the case and yank the mobo header connector. or, y'know, write a thousand-word column - hey, i don't presume to know which one took more time
__________________
"This face is left intentionally blank."
XBL/PSN/Steam ID: FodT
Fod is offline   Reply With Quote
Old 24th Feb 2009, 09:25   #3
DougEdey
I pwn all your storage
DougEdey's Avatar
DougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the DremelDougEdey has yet to learn the way of the Dremel
woah woah woah, the hard drive light is very useful, it tells you whether your computer has actually crashed or whether it's just thinking about crashing! Also, on most PCs I've found it's integrated into the reset switch as well. During installation of software - application or OS it lets you know if something is FUBAR or if there's an issue with the copy process.
On my laptop I barely see it do anything now because it's out of my eyeline.
I wouldn't say "kill it" I'd say disconnect it or allow it to be a user option in BIOS
__________________
Burnout: Paradise Stats!XBL: DougEdey Bindi
PSN ID: DougEdey
Twitter
DougEdey is offline   Reply With Quote
Old 24th Feb 2009, 09:28   #4
Fod
Fod's Avatar
you know, i've never relied on HDD activity to tell me whether a process had died or my system has hung. i usually use the numlock check to see if it's totally hung, and use process explorer to see if an activity needs to be turfed.
__________________
Old 24th Feb 2009, 09:31   #5
badders
Neuken in de Keuken
badders's Avatar
badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.
Well Fod And Doug have pretty much summed up all I was going to say.
^^^ What they said.
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Old 24th Feb 2009, 10:05   #6
GFC
Multimodder
GFC has yet to learn the way of the Dremel
I agree 100%. There's no longer any use from it.
BTW: I have my own turned off ages ago.
GFC is offline   Reply With Quote
Old 24th Feb 2009, 10:16   #7
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
power light also need to die, it's too bright and pointless. your screen will be on if the computer is turned on, your screen is off if the computer is turned off. simple as that.
personally, i think both lights are redundant. that's why i unplugged power light to my P182 because it lights up my room at night. the HDD light is behind the doors (Antec saw it 3 years ago) so no one can see it.
like Fod, i use Caps Lock or Num Lock to test whether the system has hang as a whole, when C+A+Del doesn't work.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 24th Feb 2009, 10:32   #8
Da_Rude_Baboon
What the?
Da_Rude_Baboon's Avatar
Da_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpitDa_Rude_Baboon is almost as Godly as yodasarmpit
The HDD light should stay as it lets me know my POS computer at work is actually doing something while i stare at a blue background and white cursor as it logs in.
Da_Rude_Baboon is offline   Reply With Quote
Old 24th Feb 2009, 10:32   #9
Fod
Fod's Avatar
shrug, power LED is useful to me. i often leave my machine turned on with monitor off, plus my desktop mobo flashes the LED to let me know it's asleep rather than just off. if the LED is too bright, go the ghetto route of colouring the bulb in with black marker, then putting it back into its housing - i've done this with all the gear in my living room. gives a glow subtle enough to see in dimmed lighting but not too strong to be distracting.
of course, having an LED is more important when you've built a silent system. it's probably somewhat less useful when your machine sounds like a jet engine when on.
__________________
Old 24th Feb 2009, 10:49   #10
steveo_mcg
steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.steveo_mcg is the Cheesecake. Relix smiles down upon them.
I find it very helpful on the wifes laptop it takes and age to start up and is pretty much unusable while the background proccess are loading ie while the hd light is flickering once it pretty much stops i start to load apps.
I wonder how there utility will change when we move fully to flash media since we will have no audible indication of drive use but will it matter?
As for power lights i would vote to keep them to the point when ever i have made a custom case i've added them they are very useful for boxes on standby or silent boxes to see when you've accidentally left them on.
__________________
ook
steveo_mcg is offline   Reply With Quote
Old 24th Feb 2009, 10:50   #11
digitaldave
Multimodder
digitaldave has yet to learn the way of the Dremel
I like my HDD light, this column made me realise just how much i like it, so today after work I will make a hdd light mod for my macbook
digitaldave is offline   Reply With Quote
Old 24th Feb 2009, 12:06   #12
Omertron
What's a Dremel?
Omertron has yet to learn the way of the Dremel
Really, a HDD light irritates you about a PC? I think it's slightly more deep rooted than that.
Perhaps you hate the fact that the PC mouse has at least double the number of buttons that your Mac Diety (SJ) dictates.
Perhaps there is also the issue that the case has screws and you can upgrade what's inside it? After all you're not allowed to upgrade the macbook.
Perhaps it's because, despite everything, the PC is a better machine?
If it's none of those, open the case and unplug the light. If, being a mac user you are scared of screw drivers, perhaps you could get a grown up to do it for you?
[/tongue in cheek]
Omertron is offline   Reply With Quote
Old 24th Feb 2009, 12:31   #13
Fod
Fod's Avatar
[/tongue in cheek]
.... wtf are you smoking
the macbook is a laptop. i'd like to see you upgrade more than the ram and hard drive in any dell without ripping it to pieces - which is precisely what the macbook has as upgradable parts. there's nothing about not being 'allowed' to upgrade - apple document dismantling the machines to replace parts that a consumer is able to.
there are many mac users who - gasp! - have windows machines too, and use, and like them both. leave your stereotypes at the door, please.
now leave this place, child.
disclaimer: i am aware you have a [/tongue in cheek] at the end of that, however there were so many layers of sarcasm in that post that it's difficult to identify just what bit you were referring to, so i'm assuming a worst case of just the last bit. otherwise, apologies.
__________________
Old 24th Feb 2009, 12:36   #14
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
Personally I quite like the HDD light. A perfect example of using it was playing the Empire:TW demo, if it was doing serious loading instead of just sitting around, there'd be more HDD activity instead of 30-45 seconds of nothing.
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 24th Feb 2009, 12:38   #15
Fod
Fod's Avatar
typically i rely on looking at the screen for that. there's normally something called a 'loading bar'.
i know, i'm such a luddite.
__________________
Old 24th Feb 2009, 12:57   #16
wuyanxu
wuyanxu's Avatar
even if the system is built as quiet as possible, you will still have other lights to indecate the ON status, eg, NumLock on keyboard, Mouse light.
__________________
Old 24th Feb 2009, 12:59   #17
Psytek
Multimodder
Psytek has yet to learn the way of the Dremel
I stopped paying attention to my HDD LED a long time ago. For one thing, I have 3 hard drives, and I have no way of knowing which one is being accessed when the HDD light blinks.
Psytek is offline   Reply With Quote
Old 24th Feb 2009, 12:59   #18
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
The only thing that's less reliable than a loading bar is a graph in the daily mail.
__________________
Old 24th Feb 2009, 13:07   #19
steveo_mcg
How about a release date from valve?
__________________
ook
Old 24th Feb 2009, 14:32   #20
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
As an IT geek I do find the dell laptops at work easier to work with than the apples, but partly that's what I'm used to.
Dells are easier to upgrade though, one big screw to open a hatch = direct access to memory vs remove battery, remove lots of screws, pry memory out etc...
just saying is all...
phuzz is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
