Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 25th Feb 2009, 08:41   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
Cooler Master Hyper N520 - New CPU cooler
http://www.bit-tech.net/blog/2009/02...er-hyper-n520/
Tim S is offline   Reply With Quote
Old 26th Feb 2009, 01:30   #2
Jojii
hardware freak
Jojii's Avatar
Jojii has yet to learn the way of the Dremel
That is a heatsink design where you look at it and say "neet idea, i should have thought of that."
Only problem i have is if it's a push-pull fan system, one side of heatpipe will not have air pushed into it.
I wonder if creating a cowl around the front and back would do anything.. hmm.
Jojii is offline   Reply With Quote
Old 1st Mar 2009, 17:20   #3
Horizon
Dremel Worthy
Horizon has yet to learn the way of the Dremel
it works better than the z600, i was skeptical at first, then holyshiz, how?
Horizon is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
