Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 4th Mar 2009, 12:23   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
SilverStone Sugo SG03
http://www.bit-tech.net/hardware/cas...ne-sugo-sg03/1
Opting for small form factor cases often involves demoting style to the subs bench. We take a look at SilverStone's Mini-ATX Sugo SG03 which is breaking all the rules and setting new standards for pint-sized PCs.
Tim S is offline   Reply With Quote
Old 4th Mar 2009, 12:47   #2
Bauul
Sir Bongaminge
Bauul's Avatar
Bauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run CrysisBauul can run Crysis
That's all very well, but does it pass the Martin Test?
__________________
Intel Core i5-2500K | 8Gb Corsair Vengeance DDR3 1,600 Mhz
Gigabyte Geforce 460 GTX OC 1Gb | 1Tb + 1.5Tb Samsung Spinpoint F3 | Asrock Z68 Extreme4
Ibanez RG 470 Japanese Edition | 1991 Japanese Lo-TRS Tremolo | V7 S1 Custom V8 HSH Pickups
Bauul is offline   Reply With Quote
Old 4th Mar 2009, 13:01   #3
tank_rider
Ultramodder
tank_rider's Avatar
tank_rider has yet to learn the way of the Dremel
Could you do a testing run with a second 120mm fan installed (as you recommended on the first page) to see if that makes a reasonable difference?
__________________
Main - e5200 @ 3.5GHz (akasa 965) || GA-EP31-DS3L || 2X2GB Crucial Ballistix || xfx GTX 260 || 500GB Seagate 7200.10 sata + 250GB Samsung sata + 160GB Samsung ide || NEC DVDRW || Enermax Liberty 400W || Antec P180 || 22" Fujitsu Siemems TFT
Media - X2 4400 @ 2.4GHz || Epox 9NDA3+ || 2GB RAM || 6800gs || 80GB Maxtor Diamond Plus 9 || LG DVD RAM || Iiyama Vision Master Pro 454
tank_rider is offline   Reply With Quote
Old 4th Mar 2009, 13:15   #4
docodine
killed a guy once
docodine's Avatar
docodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for presidentdocodine should be considered for president
Last page, through not trough.
This case isn't cute at all! It looks clunky and bulky and ew..
docodine is offline   Reply With Quote
Old 4th Mar 2009, 13:32   #5
ChaosDefinesOrder
Vapourmodder
ChaosDefinesOrder's Avatar
ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.ChaosDefinesOrder is definitely a rep cheat.
hmm interesting, I actually had the idea of trying that kind of layout (PSU "on top" of the motherboard) and even modelled it in Sketchup! Didn't do anything with it, as I have neither the tools or the money to make a completely scratch-built case!
ChaosDefinesOrder is offline   Reply With Quote
Old 4th Mar 2009, 13:36   #6
Cutter McJ1b
Home-cut jibs at discount Prices
Cutter McJ1b's Avatar
Cutter McJ1b has yet to learn the way of the Dremel
Corrected, thanks decodine.
Cutter McJ1b is offline   Reply With Quote
Old 4th Mar 2009, 14:00   #7
Nicb
Let's discuss among ourselves
Nicb's Avatar
Nicb has yet to learn the way of the Dremel
I would have liked to have seen the PSU flipped and behind the motherboard instead of in front. So you can show off the MB and expensive NV280. But with it covering up the entire side grill like that I would not give much attention to cable management,...... no one can see anything.
Nicb is offline   Reply With Quote
Old 4th Mar 2009, 14:45   #8
Redbeaver
The Other Red Meat
Redbeaver's Avatar
Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!Redbeaver - it's over 9000!!!!!!!!1!1!1!!!
if this thing allowed me to fit my Therlmaright Ultra-120e, i would pick it up in a split second. awwww... so cute.
__________________
Ophelia
ASUS P5Q Pro Turbo - Q6600 - 4GB DDR2 - NVIDIA 8800GTS 640 - WD Black 2x320Gb RAID-0 - Silverstone TJ-06 [Modded]
Perseus
ASUS Z97i-Plus - i5 4670K - Corsair H110i GTX - 8GB DDR3 - Zotac GTX 970 - RAID-0 Crucial MX100 2x256GB - Phanteks Enthoo ITX Red
Redbeaver is offline   Reply With Quote
Old 4th Mar 2009, 14:48   #9
Cutter McJ1b
I would give it considerable attention as cable management is as much for maximising airflow as making things look good.
Old 4th Mar 2009, 15:00   #10
Nicb
Nicb's Avatar
I understand what your saying. I'm talking like tie wraps and not anything nice and groovy. Hence the words "not give much attention" So not like this serious but more like this serious about cable management.
I'm just perturbed. I always wanted a Case with the PSU behind the motherboard sucking air from out side and spitting it out the back and also I could "spider like" the cables around the board to the front. I just think that would be great.
Wish I had all the tools to do it myself.
Edit: By the way welcome.
Old 4th Mar 2009, 15:12   #11
phuzz
This is a title
phuzz's Avatar
phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.phuzz is the Cheesecake. Relix smiles down upon them.
This looks like the sort of case that would benefit from a horizontal CPU cooler, rather than a vertical one, unfortunately most of the mainstream ones use 120mm fans (eg Noctua NH-U12) and would be too tall. Perhaps it would be worth experimenting with just a bare heatsink and a shroud directing air from the front fans, that's the sort of design most servers use (and a 1U server has a lot more heat packed into less space than this case). Mind you, most servers aren't exactaly what you'd call quiet...
phuzz is offline   Reply With Quote
Old 4th Mar 2009, 16:18   #12
PrometheusCon
Multimodder
PrometheusCon's Avatar
PrometheusCon has yet to learn the way of the Dremel
I have this case and love it. Currently doing a mod on it. It's very well built, but the metal is a little flimsy
PrometheusCon is offline   Reply With Quote
Old 4th Mar 2009, 16:48   #13
SnowCat
What's a Dremel?
SnowCat has yet to learn the way of the Dremel
Silverstone should make custom PSUs for cases like this. Smaller and with shorter cables
By the way - wouldn't it be better to have a classic scheme with PSU along top or bottom edge of the motherboard?
SnowCat is offline   Reply With Quote
Old 4th Mar 2009, 16:51   #14
Sir Digby
The Supprising Adventures
Sir Digby's Avatar
Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.Sir Digby is the Cheesecake. Relix smiles down upon them.
Hmmmm, these are begging to get modded to fit a 1U or 2U powersupply so that a large heatsink can be used in it...
Sir Digby is offline   Reply With Quote
Old 4th Mar 2009, 17:14   #15
djDEATH
Habari gani?
djDEATH's Avatar
djDEATH has yet to learn the way of the Dremel
was just gonna suggest the same thing...
__________________
BEASTIE-II Asus N550LF CK-108H Core i7, GT745M B&O Speakers
djDEATH is offline   Reply With Quote
Old 4th Mar 2009, 17:46   #16
notatoad
pretty fing wonderful
notatoad's Avatar
notatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremelnotatoad has yet to learn the way of the Dremel
and this is clearly no exception. what were they thinking with that side window surround?
__________________
13" macbook air and a boxee box. minimalism ftw.
notatoad is offline   Reply With Quote
Old 4th Mar 2009, 20:18   #17
bogie170
Supermodder
bogie170 has yet to learn the way of the Dremel
I've had one of these for over 6 months now. Not a bad little case. The main problem I have found is that it needs a fan to exhaust hot air rather thanpulling cold air in. And the case is kind of flimsy, quite thin aluminium.
I managed to fit 2x 1Tb Spinpoints, a HD4870x2 and x-fi elite pro running off a coolermaster silent pro 700. Also got a good o/c on a q9450 to 3.2Ghz as well.
bogie170 is offline   Reply With Quote
Old 4th Mar 2009, 20:36   #18
darkmarc
What's a Dremel?
darkmarc has yet to learn the way of the Dremel
I've also been running one of these for about ten months. It's a great little case, have an Asus mobo, Q6600 @ 3Ghz with 8GB OCZ Reaper DDR2. Have two Noctua fans at the front, 2x 1TB Spinpoints and a 8800 GTS, I don't have any heating issues at all. Although I will say that this probably the hardest build I've done, having never built an SFF unit before.
I went down this route because Nehalem was just around the corner and I didn't want to make a massive investment on the eve of new tech coming. When I make the move to i7 this will make a nice little file server.
darkmarc is offline   Reply With Quote
Old 4th Mar 2009, 20:56   #19
shomann
Supermodder
shomann's Avatar
shomann has yet to learn the way of the Dremel
I did alot of research into the case recently but have never had my hands on one, so take what I am about to say with this in mind.
The SG03s I have seen have the PSU flipped so their much larger 120 or 140mm fan can exhaust the hot air from the CPU. Most guys run the Silverstone NT-06 series heatsink, which is made to sit right up against the bottom of the PSU.
One modder (on another forum) actually took a Noctua CP-12 and ground off the top 8mm of the heatsink so that it would fit under the PSU, providing even better cooling. I haven't seen anyone attempt it yet, but you could mod the case to accept an intake fan on the bottom floor of the unit, for better airflow to the graphics cards. Everyone that I have seen modded, uses 2 high-end 120mm fans on the front mesh to further help cooling.
I gave up on the idea of using this case because I want to go i7 for my next rig, though this case looks quite nice for those willing to compromise.
__________________
Project: Nomad
Notebook: Apple 15" MBP 2010 i5/128SSD/320 Optibay conversion
NAS: Jetway JNC62K | AMD 4850e 2.5 GHz AM2 | 2GB RAM | 2.7 TB RAID-5 - OFFLINE, EVALUATING
shomann is offline   Reply With Quote
Old 4th Mar 2009, 22:03   #20
HourBeforeDawn
a.k.a KazeModz
HourBeforeDawn has yet to learn the way of the DremelHourBeforeDawn has yet to learn the way of the Dremel
ehh the only time I plan to build an ITX system will be for my car, other then that the smallest I would be going is mATX.
__________________
Current Rig: Project STEALTH
DimasTech Test Bench Black ICE Triple 120 Rad Dual Bay Res/Pump DD Fill Port & Res D-Tek FuZion 2 CPU Block ASUS M3A79-T Deluxe Mobo AMD Phenom II 3ghz @ 4ghz 8gb DDR2-1100 Memory (2) AMD 6870 XFire (2) WD Black 640gb Raid 0 (2) 1.5TB SEAGATE Blu-Ray/HD DVD Drive ASUS XONAR DX2 30" DOUBLESIGHT LCD (2) 23" ASUS LCD ZALMAN 8 FAN CONTROLLER (4) NOCTUA P12 (2) NOCTUA P14 1000W ZALMAN PSU WINDOWS 7 PRO 64
HourBeforeDawn is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
