#41 |
Multimodder
The aluminium profiles are very helpful with that problem. Further, when all components are inside helps too. I will make an extra hole only if the temperature increases much more after intensive use.
#42 |
Multimodder
4th Update
Sata controller won't fit properly due to aluminium profile is blocking it, I cuted it to avoid this. ![]() ![]() ![]() ![]() ![]() ![]() ![]() The PSU wires are too short, they must be changed. ![]() ![]() Dust! ![]() More dust. ![]() ![]() ![]() ![]() The fan is temperature controlled using this circuit. ![]() Power cables are desoldered to work more comfortably ![]() ![]() Dusty! ![]() My desoldering "kit" ![]() Ground cables desoldered ![]() There are few to finish ![]() A drawer with a lot of wires. ![]() This is a died antec psu (yes, antec dies too), I want to reuse the mobo power cable ![]() The wires diameter are wide. ![]() And the mobo power cable too ![]() The modular connectors seems to be very interesting for an other project ![]() ![]() All wires desoldered ![]() ![]() ![]() ![]() Antec cadaver. ![]() I made a test to see if the cable fits well. ![]() ![]() ![]() ![]() Seems to fit good, but maybe it's a bit wide. This is the diameter of the original PSU cable. ![]() This one is from a generic psu ![]() And this is the antec cable ![]() Antec cable may be too wide, which would you use? a generic one or antec's? Last edited by cmd_; 19th Mar 2009 at 02:43. |
#43 |
Is a cackling Yuletide Belgian
I think if you sleeve the generic cable you might add a fair bit of thickness. But I'd roll with that one anyway :P
#44 |
ReliXmas time!
Really good work so far!
Just one question, why dont you use a pci riser with a 90 degree angle with the sata controller? Then you could close the box without problems. Keep up the good work! |
#45 |
following the footsteps of giants
this may be a dumb question, but what's the harm in just adding wire in the middle and splicing those together? Is that bad for the PSu?
And to be honest - man you have b@lls of steel as I would be dirtying my drawers if I was to attempt rewiring completely a PSU (me EL noob) |
#46 |
Please... Just call me Stu.
I got all nervous just by changing the fan on my PSU, you must have some real guts (or knowhow, both are good).
#47 | |
Busy procrastinating
Like someone else said, after sleeving the other cable you will be close tot he width of the antec cable anyways. Why not sortof flatten the cable - instead of having one round bunch of wires, have 2 or 3 flat rows of wires... I always find flat cables easier to route anyways. Still looking fantasic btw! |
#48 |
#49 | |
Is the daddy!
You daring enough to solder the power cable to the back of the motherboard, it would solve cable routing problems. And move you into the halls of legends! lol! Even if you solder a power connector so the board can be removed easily.
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#50 | |
The Audiophile
As you can see here, I decided to splice mine to avoid messing up the beautiful soldering work on the Seasonic PCB. They are absolute genuineness when it comes to a clean PCB and layout of a PSU. Also, it took my about 8 hours to sleeve everything in here. Here are some Pics: @cmd_ - BTW looking good on the NAS box bruh. I like the way you have been able to fit everything into that tiny box so far, very efficient and well thought out. Keep up the good work Peace Last edited by Htr-Labs; 24th Mar 2009 at 17:06. Reason: remove pics of sleeving.....see project log link at signature for pics |
#51 | |
Multimodder
5th Update
--- Htr-Labs Thanks for your explanation about psu stuff. --- Thank's all for the suggestions. Finally I decided to use a sleeved generic cable. I've replaced the psu connectors because the psu generic atx connector had 20pin and the motherboard has 24pin. ![]() With this tool the job was easy. ![]() ![]() ![]() This is the original 24pin atx connector rady to be rewired. ![]() 1st wire. ![]() One side completed. ![]() All fitted. ![]() Now the sleeving job. ![]() ![]() ![]() Using a cable tie to keep all the wires together. ![]() ![]() ![]() Danger! a hot-gun ![]() ![]() ![]() ~11mm ![]() Occupies less space than the antec cable. ![]() ![]() ![]() ![]() ![]() I use this modified gas compressor to blow air for cleaning purposes ![]() ![]() ![]() ![]() Finally there is no dust. ![]() ![]() Poor tiny cable, need to be replaced ![]() ![]() ![]() ![]() ![]() This sata connectors does not have +3.3v line ![]() An additional cable add +3.3v to the sata connectors ![]() Ready to be plugged, but not now. ![]() The other long cables. ![]() I decided to clean the psu case. ![]() ![]() ![]() ![]() And now, what all you were waiting for, the soldering process. ![]() ![]() Soldered all wires except the main lines. ![]() ![]() Only remains the ground line. ![]() ![]() All soldered, sata wires still not sleeved. ![]() ![]() ![]() ![]() Sata wires sleeved. ![]() ![]() ![]() ![]() ![]() First test ![]() ![]() ![]() ![]() Works! ![]() I will put sata connectors to the cables when I'll know the final position of the hard drives. |
#52 |
Wow.
Just, WOW!
![]() All that soldering and you get right straight off the bat. Amazing.
#53 |
Yeah, I won't be attempting anything like this any time soon.
#54 |
Omnipwntent
Excellently organised project log!!
__________________
Slash88: That kettle video just made me go death thanks. Fizzban: And it is being panda'd to..lame. |
#55 |
Is the daddy!
haha, nice to see the final death of the molex plug! YAY!
__________________
#56 |
↓ Don't trust that face!
Lovely work.
Just keeping the 24pin plug organized would drive me crazy. To solder the whole thing back on the PSU is wild!
__________________
#57 |
Supermodder
Whow, impressive! Really, i dont think i ever will do that, except for meshing psu's.
__________________
Intel Q6600 - Asus P5Q-VM - Corsair TwinX 4x1GB - 8600GT - 640GB storage space - OCZ ModXStream 400w - Modded P180 Mini |
#58 |
Terminally Lazy
WOW!!! Great work so far. Cant wait to see the rest of your work on this project.
#59 | |
The Audiophile
It's not really so bad considering you really only have 3 voltages (+/-) to worry about. Also the odd colored wires are mostly for report/ground. Soldering is the hardest part, since a lot of PCB's now use Lead free solder, you have to have an iron or mini torch that can melt that damn industrial strength crap they use. @cmd_- Very good job on keeping everything neat and getting it working again. No doubt, working on a PSU is not for the faint of heart.
#60 |
Yup.. I'm a f-ing reptile
Excellent workmanship, photography and logging! All together very well thought out and presented!! I like A LOT!!!
Five stars:
__________________
Tools Picture Dictionary / Visual Tools Guide <----------- I could use some help with this one, plz! |
| Tags |
| atom, linux, mini-itx, nas, server |
| Thread Tools | |
| View Mode | |
