Go Back   bit-tech.net Forums > Misc > General
Reply
Thread Tools View Mode
Old 18th Mar 2009, 22:14   #1
philipd
What's a Dremel?
philipd has yet to learn the way of the Dremel
Clio immobiliser troubles
hi can someone tell me how too bypass my clio immobiliser the sensors have broken off so i can start it . it a 96 clio
philipd is offline   Reply With Quote
Old 18th Mar 2009, 23:00   #2
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.Krikkit is definitely a rep cheat.
What do you mean the sensors have "broken off" ?
__________________
The Good, The Bad, The Ugly, The Zlad!, The Wut?!, The Kempness
Krikkit is offline   Reply With Quote
Old 18th Mar 2009, 23:36   #3
Brooxy
Like a boss (but not a boss)
Brooxy's Avatar
Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.Brooxy is definitely a rep cheat.
Without the sensor, the immobiliser cannot be bypassed unless you are a professional.
The roof sensor only receives the signal and passes it to the ECU. The ECU in the car is what actually decodes the signal.
if you hunt around on ebay, you should be able to find a new receiver eye for under 50. It just clips into the roof.
If you are dead set about getting it disabled, there is a firm in the midlands that you can mail your ECU to (they will provide instructions to remove it) and they will disable it for you - it costs about 100.
I don't have the address on me, but send me a PM if you need it and i'll find it on my work machine at somepoint this week.
Also can you provide pictures of snapped - i might be able to assist you in a makeshift repair guide...
Brooxy is offline   Reply With Quote
Old 19th Mar 2009, 11:38   #4
Atomic
Gerwaff
Atomic's Avatar
Atomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming SaiyanAtomic is a Super Spamming Saiyan
I love this post, signing up for a computer forum and asking how to hotwire a car!
__________________
:: All your PowerShell are belong to me ::
Atomic is offline   Reply With Quote
Old 19th Mar 2009, 12:13   #5
Brooxy
Brooxy's Avatar
It could be genuine - for that age it would be a MK1 Clio, which do have immobiliser issues - mainly through water ingress through the arial / sunroof.
I would know, bought an old one for 200 quid and spend a Saturday cleaning the IR receiver with WD40 and fixing the roof so it wouldn't happen again - two months on it's still ok so hopefully it'll stay that way - only problem I have is the range is a little bit short, but I can live with it....
Old 23rd Mar 2009, 21:22   #6
philipd
What's a Dremel?
immobiliser 96 clio
the sensors have broken off the ciruit board i want to sell the car on as i have got a new 1 but no-one wants a car that wont start
Old 23rd Mar 2009, 21:29   #7
Krikkit
Super Moderator
Moderator
Krikkit's Avatar
Grab a soldering iron and jam them back on?
Otherwise you'll have to go down a scrappy and change the ECU/immobilizer control.
__________________
Old 23rd Mar 2009, 23:47   #8
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming SaiyanUnicorn is a Super Spamming Saiyan
I used to drive a late 90's Citroen that had one of those type of immobys... hes talking about the circuit board sticking out of the extra key that has a socket next to the ignition... sorry mate but if you've broken that theres nothing you can do but get it replaced with another immobilizer assembly. And that's going to take a mechanic or at the very least an electronic engineer.
__________________
"For every stalwart bit-tech-worthy tech out there, another 2 cretinous arse-scratchers are out there pulling your patches and reconfiguring your ****." - Krikkit
Unicorn is offline   Reply With Quote
Old 24th Mar 2009, 09:23   #9
Brooxy
Brooxy's Avatar
Nope with a MK1 Clio there are 3 infrared receviers on a circuit board just in front of the sunroof - the connection on them is a tad flimsy. My bet is he's lost those.
All you need to do is get a new receiver eye, and clip it in - you need to remove the plastic surround/ light assembly which is easy enough, unplug the old one and plug the new one in
Have you got any pics of the damage?
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
