#1 |
theorycrafting
Zotac GeForce 9300 ITX - How small can you do it?
Hello fellow bit-techers.
As the new Zotac GeForce 9300 ITX got tested recently and it being the first mini-ITX to sport a full PCI-E x16 2.0 slot, I was thinking of how small you can get a case with this board. Everything needs to be scrammed in the box... MoBo, gaming GFX, watercooling, HDD, PSU, DVD. Here's what I was able to come up with. The 120.2 radiator is a little bit outside the box, with the tubing going back inside from there. ![]() ![]() So how small would you be able to get this thing? Quick and dirty ideas. Nothing has to be fancy and clean for this one. SKP of the board can be found here >> http://www.robsinter.net/temp/zotac_gf9300itx_jrs77.skp <<
__________________
...and allways remember, that the world is an orange!
Define Mini Black [Gigabyte Z77MX-D3H | intel i5-3450 | Kingston HyperX DDR3-1600 8GB | Gigabyte GTX660OC Windforce2 | intel 330 120GB | WD AV GP 1TB] |
#2 |
Please... Just call me Stu.
Have you tried mounting the board sideways?
#3 |
theorycrafting
I did a three minute mock-up with standard-components, if that answers your question
__________________
#4 |
↓ Don't trust that face!
Let's see... You could lose the res top and just use a T-line, and that extra 120mm fan is overkill. Four 120 fans in such a tiny space?
Turn the radiator 90 degrees, move the HD in front of the mobo, and you might shave another inch off. (If the HD fits.) The two holes in the back made me think it would be cool if you could carry it like a 6-pack
__________________
#5 |
You could probably get away with only having the fans in the rad blowing air out of the case, with a few vents on the side which the exhaust fans would suck air in through. You could maybe try using a 2.5" laptop drive or an SSD to save a small amount of space, but drive capacity would suffer. Do you really need the optical drive? Sounds silly I know, but what do you really use it for? Installing games/software probably, but you could just an external enclosure for that. But if you truely need one in there, then a slim drive is as good as you can get. Try mounting that sideways. A wider box is better than a taller box I think.
#6 |
Officially demotivated
I tried this using a low-profile cooler and got it down to a 190mm cube (but that's using a full size PSU and DVD drive)
__________________
{Rolling on a 1990s Dawes Galaxy} {Nikon D80, 18-55 f/3.5-5.6G and 50mm f/1.8}{Lomo Smena 8M}{Olympus OM10, 50mm f/1.8, 28mm f/2 and 135mm f/3.5} |
#7 |
theorycrafting
Guys... I don't want to know, what I can do better. I can't afford to buy new hardware anyways... I'm eiger to know, what sort of setup you can come up with, that's even smaller then my approach. And watercooling is mandatory in this question.
smaller = less cubiq-cm/inch Mine is 16000 cm³ (a x b x c) @ bigsharn: How can you sqeeze a nVidia 260GTX in a 190mm cube?
__________________
#8 |
I wouldn't use a graphics card in the rig... being the pain in the arse that I am, I'd use it with a Q6600 (yes, I'm a fanboy) for CS4... and the 9300 chip would accelerate it enough
__________________
#9 |
Multimodder
lay the graphics card flat that's how i got a mine into a slim case
another one is server PSU? i'm trying to find a psu about 500W that is small. i was thinking of doing the same thing but in the next 32nm shrink already have enough computers around. |
#10 |
Grumpy Old Git
The only small PSU over 250W I've been able to find (in 5 minutes of Googling) is Shuttle's PC55
__________________
i5 2500K@3.3GHz / Corsair H50-1 / Asus P8P67-M PRO / 16GB Corsair Vengeance / MSI GTX670 / 240GB Samsung 840 /
1TB HDD / Silverstone 600W / Silverstone SG-09 / Dell U2713HM / CM Storm Quickfire TK / Logitech G9 / Win7-64 Ultimate / Ubuntu 13.04-64 |
#11 |
The Supprising Adventures
Personally, I would give up on watercooling and mount the powersupply over the motherboard Sugo style.
#12 |
Multimodder
probably a 450 is enough
i might look into it later i have a slim mATX with 9550 and 4850 + 1 HDD in a pretty slim case that runs fine with the 300W PSU that came with it, 450W should be good enough for what i have in mind next. good multicore cpu + mITX +good graphics card + 2 SSD in raid 0 |
#13 |
Is the daddy!
should this be the next themed case design comp, cases designed around this motherboard....
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#14 | |
theorycrafting
__________________
#15 |
Is the daddy!
i dont think people enter because of the prizes, its the fun of the design
__________________
#16 |
The Keeper of History
Who in their right mind would H2O cool a mini-ITX?
john
__________________
My deepest gratitude to this community.
#17 |
Is the daddy!
You senile old git! lol!
John your still a legend!
__________________
#18 |
It never hurts to help
You are just afraid of the competition
![]() I made a very fast mockup inside a 20cm tube for the MNPCTech case design compo. It's wasteful with space though, so you can probably do better. I think the biggest component you'll have to use for this rig is the PSU, so the design should be centered around that. The HX520 is 15x15x8,6 cm. Place that fan-down, use the back of the PSU as a mobo tray. Use a lexible PCIe x16 riser to fold the GPU to the side and tuck it under the 2cm that the mobo overhangs. A good GPU (4870) is about 20cm long. This means there's a space of around 5x15x8,6 cm to place a thin 2x80mm rad + fans. The pump can be placed above the motherboard in an unpopulated spot, and 2,5" (1,8"?) SSD should just fit between the GPU and PSU. Add a slimline DVD drive between the mobo and PSU, and i think the whole thing should be possible in a 15x17x20 cm space. That's 5100cm3 ![]() Ofcourse you'll need to add some extra space for cables and tubing, but without access to SKP at the moment i think this would be the best config...
__________________
Think of how stupid the average person is, and realize half of them are stupider than that.
- George Carlin |
#19 |
theorycrafting
The idea is to build a decent gaming-rig based on this Zotac-board in the smallest case possible.
decent = big CPU + big GFX-card If you go small however, you don't have place for big coolers, so you opt for watercooling ![]() Next try, ~ 12000cm³ ![]() I'm not happy with the idea of using a 9 cm flexible PCI-E riser, as some tests mentioned a noticable performance-loss using them. So I try and opt for attaching the GFX-card the usual way.
__________________
#20 |
Lleno de anguilas!
Here's just a quick layout that I mashed up when designing a gaming system based on the J&W MiniX motherboard...
![]() The basic measurements for the case are, 275x225x155 which makes a total of 9590 cc... ![]() The cpu is cooled with the Swiftech H20-120 Compact kit which saves some space and tubing...
__________________
MetkuMods Because you love your hardware. AllTheMods Modded your house, bike, computer?! Show-off it here. Eutanasia: Q6600 g0 @ 3,6Ghz, DFI Lanparty DK X48-T2RS, 4Gb G.Skill @ 912mhz 5-4-4-4, HD4870 CrossfireX, 200gb WD... Article: Metku.net Last edited by HaoKi; 25th Mar 2009 at 15:33. |
| Thread Tools | |
| View Mode | |
