I've posted this project in a couple of other places and thought i'd post it here aswell,the build consists of a Lian Li G70,powder coated white outside,black inside with the roof cut out to house a PA120.3 and the floor cut out to house a PA120.2,window cut out and a few cable management holes.The hardware going inside will be: Asus P6T Deluxe Core i7 920 6Gb DDR3 Corsair Dominator 1600MHz GTX 280 Antec Quattro 1000W PSU 1TB Samsung Spinpoint F1 500Gb Samsung Spinpoint F1 Cooling: PA120.3 PA120.2 DDC-1T Pro/XSPC Top DDC-1T Ultra/XSPC Top 2 x Bitspower 5.25 White bay res's XSPC Delta V3 CPU Block MIPS Mosfet and dual N/B-S/B Block Danger Den White UV 3/8"IDx5/8"OD Hose White Enermax Cluster Fans Anyway here's the case Cutouts for the PA120.2 and cable management holes PA120.3 tapped for M4 bolts and test fitted More updates soon
Black and white themes do look awesome, which is the reason most people do them these days. It's lookin' great, subset7!
Thiose Enermax fans are really nice and not as expensive as I thought when I first saw them. I like the removable blade-design and the switch for the LEDs aswell And nice paintjob there mate
I got mine from Scan http://www.scan.co.uk/Products/120m...Speed-White-LED-(on-off)-inc-Rubber-A-V-Plugs
Fans and PA fixed to case top Top fitted back on case Fitted the fans and fittings to the PA going in the bottom Rad and fans fitted More updates tomorrow
Thanks for all the comments ,anyway here's the res's i'm using Got the tops on the pumps,braided and fitted And the Res's Need to tidy up the fan cables and test everything on air now before I start putting it together
Wow great looking case! The black and white theme will be great. Those fans are sick as well. Love the setup see far. Subd!
