Thread Tools |
#1 |
You Rebel scum
BenQ MP512-ST Short-Throw Projector
http://www.bit-tech.net/hardware/mon...ector-review/1
Fancing something a little bigger than your usual 24" or even 30" monitor? This BenQ short throw projector will display a 50" image at less than a meter from the wall! With a HDMI input and an attractive price - could it be the answer to big screen gaming and movies?
#2 | |
Neither Patrick nor Sparta
never heard of a libing room before
![]() Interesting projector though. However i can only see them for use in Movies theaters and Classrooms. Somehow the idea of watching TV over a projector just hasn't appealed to me.
__________________
#3 |
pretty fing wonderful
it seems pretty silly of them to include HDMI and not component. i'd think on a unit that couldn't do HD you'd be a lot more likely to want component inputs.
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian notatoad.net fdo eff |
#4 |
BSc... finally
No HD? Not interesting for me then. You can get 1080p projector for roughly double that price and to be honest, I think it's worth it.
__________________
"The most merciful thing in the world, I think, is the inability of the human mind to correlate all its contents. We live on a placid island of ignorance in the midst of black seas of infinity, and it was not meant that we should voyage far." Blame it on Cheaps! [now a social group]
#5 |
Supermodder
Funny enough a few days ago I was planing to start a thread and ask why you guys had not reviewed any projectors, since it seems a likely component of a home theatre setup (and then forgot to do it). Are you going to look at any true HD projectors?
Also I might have missed it but I didn't see any mention of how noisy the projector is, which I think is one of the major issues with projectors? also might be a good idea to include average bulb life and replacement price, since often the bulbs are bloody expensive to replace.
__________________
If it isn’t broken, fix it. If it is broken, mod it till it looks like it's meant to be broken. |
| Dr. Strangelove |
| View Public Profile |
| Find More Posts by Dr. Strangelove |
#6 |
Multimodder
Another who hasn't heard of a "libing room" - is this somewhere you have "libations" or simply ad lib?
I agree with Dr Strangelove here - what's the cooling fan noise level? Bulb life? Replacement cost? Details please! A friend of mine runs a full HD projector on a 96" screen and it's truly glorious, the prior incarnation was as limited as this one as far as resolution is concerned, it just didn't have any inputs other than component or VGA. What's the point of a projector that will accept an HDMI input if it simply can't display it? The current one is 720P (1080I signals accepted but downscaled, 1080P wasn't within his budget ) and a joy to use (especially if you're console gaming on split screen). Let's just say that a lot of LAN sessions get held at his gaff and leave it at that. As far as audio goes, why on earth would you want internal speakers? If you have the cash for a projector then you can usually afford halfway decent speakers so why not use them? Most would so why bother adding them in the first place? |
#7 |
Ultramodder
is there some part of this review missing because the first page really doesn't seem to flow onto the second page? if there isn't it seems lacking in a few details for a review, the first page is mostly about your projector, TV licensing and how people think projectors aren't HD, and then the second page goes on about how this isn't a HD projector.
__________________
"I do not agree with what you have to say, but I'll defend to the death your right to say it. " Voltaire. My Flickr
| whisperwolf |
| Find More Posts by whisperwolf |
#8 | |
Free from artificial flavourings
Most projector bulbs will last for somewhere around the 2,500-3000 hour mark - BenQ themselves quote 4000 hours, but it will start to deteriorate around 3-3500 hours in real world usage. The bulbs cost around £200 RRP to replace. The real problem with projectors sold as cheap home projectors tend to be repurposed office projectors, so they invariably have none of the resolution or colour gamut of a proper HD cinema projector. Save your pennies up for a real HD projector, the difference between something like this and a "proper" projector is worlds apart.
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse |
| Flibblebot |
| Find More Posts by Flibblebot |
#9 | |
Supermodder
So which one would you recommend as a cheap entry into HD?
__________________
SN25P A64 3700+ (San Diego) 2 GB DDR400 OCZ Platinum EL 2-3-2-5 1T X1800XT 512mb Sapphire 200GB Samsung SP2004C |
#10 | |
Made in Canada
__________________
[[Asus P6T | Intel Core i7 920 @ 2.67Ghz cooled by Noctua UH-P12 Push-Pull Config | 6GB DDR3-1600 Patriot Viper Xtreme XMP C8 | nVidia GeForce 280 GTX 1GB | Corsair HX620 620 Watt PSU | Antec P182 Case]] |
#11 | ||
Richard Swinburne
bit-tech Staff
![]() It has a surprisingly good colour gamut and white quality, but I won't pretend to know how it compares against real HTPC projectors. Projectors aren't really my field, but Benq asked us to take a look at it - and it's cheap, so we thought our readers might want to know. A lot of you will want TrueHD anyway, it's only of interest if you particularly need a short throw and MUST have a huge screen. |
#12 |
Internet Addict
Wait wait wait... I'm confused by something here.
You says it has HDMI port, but go on to say it isn't an HD projector? Doesn't an HDMI port automatically mean it supports HD content?
__________________
-- Faulken S. Wulf "Under the Willow, he sleeps and dreams, of Heaven." Attempting to post intelligently since the year 2000! |
#13 |
Richard Swinburne
bit-tech Staff
It does support HD content. Plug any HD devise into it like a PS3 and the PS3 will set itself to 1080p but the projector will downscale it to 800x600 (or appropriate 16:9). It looks fine - surprisingly so - it's just not "TrueHD"
#14 |
BSc... finally
Any chance of you taking a picture of the quality, Bindi?
__________________
#15 |
Richard Swinburne
bit-tech Staff
Benq had it taken back a few weeks ago: we literally had it for a couple of weeks. I finished the review last month.
I tried shooting it but they didn't turn out so well It's difficult because you can't appreciate the black level and colour is dependent on the camera CCD/grain-ISO factor.
#16 |
DUR HUR
I think you guys should definitely do more projector reviews
#17 |
BSc... finally
Agreed.
Shame about the quality-showing pictures.
__________________
#18 |
Internet Addict
Thanks for the explanation! I agree: More projectors!
__________________
#19 | |
Ultramodder
| Da_Rude_Baboon |
| Find More Posts by Da_Rude_Baboon |
#20 |
Help me , Help you.
5-50k televisions?
i've picked up a 50" for 700, and a 52 for a little over 9.
__________________
Guns don't kill people, kids who play videogames kill people.
| Thread Tools | |
