#1 |
How many wifi's does it have?
[Tweak tool] NV GPU Pro for Nvidia graphic card
The following post has been updated to reflect the latest version
Hello all, I am exited to present to you my new simple tool that I have made for Nvidia Geforce and Quadro series graphic cards for laptop and desktop computers, named Nv GPU Pro. Nv GPU Pro, allows you to change several Nvidia video card settings that are not normally available to the end user, such as Enable/Disable: Temperature control GPU clock, GPU core/memory clock slow down, change the Nvidia PoweMizer behavior, and more. All of this, in a an easy to use interface, and help documentation. Now supports systems with multiple GPU's, and 197 drivers series of Nvidia and much more... Screen shots (click to enlarge)
About This tool will automatically detect what your video card/driver supports and disable the unsupported option to prevent any problems. No installation required. 1 file package executable application, just run the exe... everything is in itself, including help documentation, with auto-clean up system when the application is closed. No MESS!What's new? View demo of Windows Experience Index (WEI) detail benchmark: here I hope you enjoy this software and find it useful as much I had great pleasure doing it for all of you guys, bit-tech community. I'll be hearing for feature requests, spelling/grammar mistakes and bugs that needs to be fix. Download
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB Last edited by GoodBytes; 16th May 2010 at 02:52. |
#2 |
I've got a feeling I am being ignored because people think it's spam.
__________________
Nv GPU Pro - Automate your graphic card overclock base on what you run, reduce power and noise. Designed for Laptops and Desktops. Filled with features. Core i7 930 2.8GHz | G.Skill Pi 6GB 1600MHz 7-5-7-24 1.5V | Gigabyte GA-X58A-UD5 | GeForce GTX 260 | W.D Caviar Black 1TB | Corsair AX750 | Noctua NH-U12P | Xonar Essence STX | Win8 Pro 64-bit | Dell U2410 - 1920x1200 | OCZ Vertex 4 250GB |
#3 |
Dremedial
so with this software i'll be able to stop my GTX280 clocking down for 2d mode? this would be really handy as i have rivatuner profiles set to keys for power saving and when i have only one screen attached the driver and rivatuner have an argument
__________________
| Main Rig | TJ07B-W | 2600k @ 4.7Ghz | Sabertooth Z77 | 8GB Corsair Vengance | EVGA FTW 670 @ 1305Mhz | Samsung 830 128GB |1TB Samsung F3 | EK Supremacy CSQ | EK FC680 CSQ | Corsair HX650W | U2711 | Filco Majestouch 2 Tenkeyless | Xonar Essence STX | Beyerdynamic DT990 Pro 250ohm | | HTPC | Lian Li Q11-B | AMD A10 5800k | ASRock FM2A75M-ITX | 8GB XMS3 2000 | 1TB Seagate | SFX 350W | |
#4 |
Yes, that is what I did with my laptop when it's plug-in (I set PowerMizer to be disabled when plug-in). However, I on my desktop computer, PowerMizer was set as disabled by default. i never had the GPU slow down (GTX 260), so I am surprised that your does that. But you can have a look. Again, this application is safe and installation-free, it won't do anything until you press on the Apply button (your must restart the computer for the drivers to re-load and read the changes set, as it only read the settings once at startup)
__________________
#5 |
Dremedial
i think it may be a feature of the GTX280 but not the 260, in any case this looks very helpful, unfortunately im about 200 miles away from my pc at the moment *sob* but will try it when i get home
__________________
#6 |
The cheesecake is a lie
I'd have +rep'd you but it doesn't let me.
Says I've given too much rep to you.
#7 |
LOL!
![]() Another time perhaps. Thanks!
__________________
#8 |
Is the daddy!
is there anyway of the software to soft mod a geforce card into a Quadro to enable openGL in cad apps.
I know nvidia screwed us may years ago by hard locking the cards, just thinking you might know a loop hole.
__________________
Project log Mocha70 Workstation: Q6600, DFI P45-T2RS Plus, 8GB Reaper HPC, Quadro FX3450, 60Gb Vertex 2 Game: i7 930, GA-X58-USB3, 12GB Kingston, GTX280, 1Tb Seagate, WC
#9 |
Elitist
This may just be ideal for a friend of mine who's having some trouble with her laptop GPU.
I'll post here if it helps.
__________________
Main: CM Cosmos II <-> Core i7 920 @ 4GHz <-> EVGA GTX 580 <-> GA-EX58-UD5 <-> 6GB DDR3 <-> Samsung 840 Pro <-> Crucial M4 <-> Xonar D1 <-> Dell U2410 <-> HP ZR24w Laptop: Core i7 2670QM<-> GTX 570M <-> 8GB DDR3 <-> Crucial M4 <-> XMG P511
#10 | |
For example on my laptop I have a a Quadro NVS 160M, which is actually G92 chip. I installed the Geforce drivers, and I got a nice increase in performance in games. I had to pay a visit to laptopvideo2go.com, to download a modded ini file to make the setup think that my video card is supported and install the drivers. Moded ini link: http://www.laptopvideo2go.com/infs/1...64/nv_disp.inf
__________________
#11 |
still wants Homeworld 3
GTX260 slows down when in 2D mode..... at least it should.
nice tool, only nVidia are supported? edit: i didn't know i've got an ATI gtx260 card......... ![]() probably the new 185.66 drivers
__________________
i7 2700k \ 16GB \ gtx580 \ D2X \ z68x-UD5 \ m4 128GB +2TB \ Ax850 \ FT02-RW \ G15+G5+G51 \ U2711 27"
5D mkII \ 24-105 L \ 17-40 L \ 85/1.8 \ 35/2 \ 70-300 Di \ 270ExII \ 430ExII \ 3LT Adrian \ Hadley Pro -- Photostreamr Last edited by wuyanxu; 9th Apr 2009 at 21:43. |
#12 | |
I'll have a fix soon, which I'll PM you with a development build for you to test. I might need a segment of your registry, but I'll PM you with all the info, if I need it. Also, I don't support any modded drivers, yet.
__________________
#13 |
Ok, little announcement here.
My application, other tools which disable/modify PowerMizer, and manual hacks all fails with the 185 (BETA) series drivers. I'll have to dig in more deeply.
__________________
#14 |
Ok... well just to say to all.
PowerMizer is supported in driver 185 series. I installed the same drivers 185.66 on both my laptop and desktop computer. On my laptop my tool still works (yes, I clean my registry to make sure there is no left overs), but on my desktop, which only had PowerMizer setting on or off, now are gone, and force to be on. However, adding the missing keys fixed the problem. Stay tune for the update.
__________________
#15 |
New version released!
This version has a lot of changes, making it increase from version 1.0 to 1.1. What's New? (version: 1.1 build 64)
Check out the first post for the new version. Enjoy!
__________________
#16 | |
What's a Dremel?
#17 | |
In reality, on Nvidia page you can pick any drivers fomr any video card, they are all the same, as Nvidia uses one driver for all video cards. The Quadro NVS 160M is on the G92 chip so Geforce 9000 series. Without any overclock, it's gaming performance is a Geforce 9300M if your GPU has GDDR2 RAM and faster if it has GDDR3. (you porbbaly have DDR3 on your graphic card liek most people with the E6500. Lat E6400 user, like myself, have DDR2 graphic memory sadly) With overclock, the DDR2 model you can reach (especially with the Latitude E series, thanks to it's metal use used as a heatsink) to a almost Geforce 9500M. In your case you should be able to go aliitle further as your have an independent heatsink for the GPU and faster memory. (Geforce 9600M GS, maybe?) In any case my software should support DOX optimized and the latest Nvidia build drivers.
__________________
#18 |
What's a Dremel?
Thanks. Though that driver is for vista x64. I'm running xp x86. Might go with xp x64, though. Just noticed the xp drivers on the right hand side. Dox says install older physx drivers, then the new ones. Not sure why. I'm up to physx 9.09 and my geforce driver is 182.05. Not sure if I should go higher. What do you think?
I am trying to sell this laptop so that I can build a gaming computer, or at least trade it for one. Best I can find for gaming is: SPARKLE SXS2501024D3-NM GeForce GTS 250 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card and AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core on newegg. Heard people were overclocking up to 4Ghz! Not sure what motherboard should go with it. Specs on newegg are sometimes confusing. |
#19 | ||||
__________________
#20 | |||
What's a Dremel?
![]() If I can run Crysis on Ultra High, then it would make sense to keep the laptop. I have to know it can tackle the games that are now coming out. Can I put an even better graphics card in this laptop?? This is a replacement system for my D830 and I was amazed at what Dell did for me. Still have 17 months left on the replacement warranty, though Dell has yet to transfer the warranty to my new system. My CPU is the T9800 and the GPU is definitely 256 ddr3 turbochaced to 512, whatever that means. The only problem of significance (and it's a biggie to me) is the Esata port fails if data goes both ways. If I'm copying data or playing a video from an external Sata drive while downloading to the same drive, the drive glitches out and I have to restart it. I was so looking forward to a true sata connection because the speed beats the crap out of a usb connection. I also I need the sata connection to flash my xbox 360 (which I have yet to play save on time since I bought it around Christmas). This can only be done using a real sata connection. And I have been getting erros on the main hard drive and I think it was caused from being in AHCI mode. I presume Dell installed xp AFTER turning on the AHCI mode, otherwise, I wouldn't be able to get into windows. Since I've been in ATA mode I seem to be error-free, but I need AHCI mode to take advantage of my External drive speed. And this system has the fastest drive access I've ever seen, in spite of the fact my last one was a 7200 also! Quote:
![]() Quote:
Note: just checked CPUBenchmark.net and the Phenom performs at 3799 and ranks 25 vs the T9800 at 2295 ranking at number 61 on the list. On second thought I like this one http://www.newegg.com/Product/Produc...82E16814130398 Bottom line, I could sell this for a grand and build a desktop with literally everything I could want and still have money left over. Funny thing is I only paid $250 for the original laptop this replaced!!! Last edited by giggedyguy; 26th Apr 2009 at 20:07. |
| Tags |
| geforce, nv gpu pro, nvidia, powermizer, tool, tweak |
| Thread Tools | |
