| View Poll Results: What looks better with a 120mm at the front of the case? | |||
| 3 Screws |
2 | 6.90% |
| 4 Screws |
12 | 41.38% |
| No fan, no screws |
15 | 51.72% |
| Voters: 29. You may not vote on this poll | |||
Thread Tools | View Mode |
#61 |
I'm not Sparta :/
So you're done? Great!
__________________
Project PC3 - a PC in a PS3!
(While the old one is mothballed)We're people who have the patience and know the pain of sleeving. And love it Bit Tech is more than games and hardware - check out the mods too. Don't let modding die in Bit-Tech.net. |
| stonedsurd |
| View Public Profile |
| Find More Posts by stonedsurd |
#62 |
My right hand is a Dremel.
| monkey120101 |
| Find More Posts by monkey120101 |
#63 |
Final Update!
The fans finally arrived, and then I realized that the fans were 100mm.
They were labled 92/100 mm, and I assumed that meant they would fit, which they would if they were only being mounted using mounting holes Anyway, I realized that I don't need the special removable fan holder, so I simply epoxied the fans. I ran out midway, so I super glued the second fan. Pictures:![]() The box in all of its glory. ![]() ![]() ![]() ![]() ![]() ![]() ![]() Fans installed.... ![]() The G5 case, all done ![]() I'll probably not update for a while now, considering it's done. However, if something comes up, or I add water cooling, Bit-tech will be the first to know Thanks for reading!
| monkey120101 |
#64 |
Mother's Day update!
Finally, an update! I've been happily using my pc and one thing occurred to me; the ugly power supply sticker was seen every single time I looked directly at my case (which is a lot
). The G5 CPU cover was on the table, lying there unsold and un-used. I proceeded with the dremel ![]() ![]() There you can see the sticker. ![]() Sticker again. ![]() All marked up, ready to cut. ![]() About halfway done. ![]() Cut and sanded.....and you can see the dremel got away from me and slid No biggie, this won't be a well seen part of the case.
| monkey120101 |
#65 |
A continuation
![]() I also tore everything apart and reran the cables. ![]() Here you can see I eliminated the need for a usb card, freeing a pci slot. ![]() ![]() A closeup ![]() ![]() Can you say, well-hidden-internalized-usb readyboost drive? ![]() The new source of usb ports. I had earlier thought them to be in-accessible due to the fans jutting out....I was wrong (luckily )![]() Glue! ![]() Sleeved fans. ![]() A view from the front ![]() ![]() Fans inserted. ![]() Much more neater than the old wires! ![]() ![]() ![]() Much better ![]() Thanks for reading! |
| monkey120101 |
#66 |
Update 06/19/09
I'll let the pictures do the talking
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Now the Nehalem Apple is truly complete! Refreshes to the case MIGHT be updated in a year or so, but it is now OFFICIALLY complete Thank you very much for reading! P.S. The Nehalem Apple is now SSD, 2x30 GB OCZ Vertex's
| monkey120101 |
#67 |
I know what a fk'n Dremel is ok.:D
cool congrats on the finish
| Tags |
powermac g5 i7 mac ![]() |
| Thread Tools | |
| View Mode | |
