RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 20th Apr 2009, 19:42   #1
Macros_the_Black
Yup.. I'm a f-ing reptile
Macros_the_Black's Avatar
Macros_the_Black will become famous soon enough
Tools Picture Dictionary / Visual Tools Guide
About a year ago (9th Apr 2008), in the "please stop using the Dremel as a saw... " thread, Oclocker had the idea of creating a "pictorial guide" of tools . I thought this was a great idea but was too lazy at the time to make one. I do realize this is going to take a lot of time, but I'd really like to see such a guide / dictionary here on the forums, so here goes:
[DISCLAIMER]
I'm not a tools guru of any kind so feel free to improve on or correct any mistakes in the text. To make this dictionary a reality I will need your help!
[/DISCLAIMER]
Feel free to suggest changes in the layout/structure!
As of now, the tags are: "tools" and "dictionary". More suggestions are welcome!
I would also greatly appreciate any submissions of suitable tool images, texts, names and links!! (It takes a lot of time hunting down good images and links )
My sincere gratitude goes out to all of you who has contributed to this dictionary so far!!!!! With no further ado I give you..
The Wall of Honour! (The nicks are presented in order of appearance)
Code:
            Cheapskate         Dark~3nergy          Langer         notatoad
            Bindibadgi       overdosedelusion      The_Beast      jhanlon303
             Delphium           [OODBALL]          ModMinded
Q: Ok, I would like to submit images to the dictionary, what do I do?
A: Post a reply containing the following:
1) A link to the original full size image, and the name of the tool. Remember, the tool in the picture must be easily recognizable as you scroll down the thread! (Try finding a tool in this dictionary only by looking at the pics.) Preferably, the pic should have single color background and a easy to read silhouette. Also, it's good if the original pic is large enough to make it "zoom-able".
2) [Optional] A 150 pixel tall thumbnail. <--- [Yes please, saves some time 'photoshopping'.]
3) [Optional] A short text describing the tool.
4) [Optional] One or more useful links.
5) [Optional] Accurate names of the tool in other languages.
Planned future additions: (need to find images n stuff for these)
(3d printer)
Bending press
Blow torch
Calipers
Drill bits
Lasercutter (CNC)
Laser level
Oven
Paint station
Pliers
Plotter
(Powder coating)
Rotary sander
Random orbital sander
Sanding drum
Smelter
Storage cabinet
Time-serts
Water jet cutter (CNC)
Welding + brazing equipment
Wrenches
... feel free to suggest more!
Clamps and Vises
C-clamp
Clamps stuff. Usually smaller than their F-clamp siblings.
Corner clamp
Holds pieces at an angle to each other. 90 degree and adjustable types depicted.
Drill press clamp
Clamps your pieces to the drill press / mill table while you drill.
F-clamp
Clamps stuff. Usually larger than their C-clamp siblings.
Quick grip clamp
Great for clamping stuff together when you only have one hand free. If you need the stuff really tightly clamped, add F-clamps after the quick clamps (some (all?) quick clamps can't tighten their grip in small enough increments).
Spring (grip) clamp
Quick and easy clamping. ^_^
Vise (bench vise)
Skruvstycke
Holds or clamps a work piece while you work on it. Is usually bolted to a work bench.
Vise (drill press vise)
Borrskruvstycke
Holds or clamps a work piece while you drill into it. Is usually bolted/clamped to the table of a drill press.
Vise (machine vise)
Maskinskruvstycke
You usually find this kind of vises on mills (CNC). Holds or clamps a work piece while the machine works on it.
Vise grip (standard)
Holds stuff together. Used when welding for example.
Vise grip (C style)
Vise grip (sheetmetal)
Measuring
Square
Vinkelhake
Squares are very useful when drawing/scribing lines or aligning work pieces at 90° angles. Also useful for checking the perpendicularity of your cuts/work. The combination square (pic #2) also has a fixed 45° angle and the option of protractor (adjustable angle thingy in the middle) for any odd angle you need or want to measure. It also has the option of a centre square which helps you find the centre of any square or round object.
Steel ruler
Stållinjal
Use it to measure, draw/scribe straight lines or as a guide when cutting with a hobby knife. Tip: If the ruler doesn't have cork on the flip side to prevent it from sliding, you can put some electricians adhesive tape on it to create a rubber surface with higher friction.
Miscellaneous
Air compressor
Kompressor
Drives pneumatic tools like air-brushes, grinders, sanders, hack saws, etc. Great for blowing away dust. Just make sure the air supplied is oil free, this goes for air brushing as well!
Angle grinder
Úhlová bruska, Winkelschleifer, Disqueuse, Smerigliatrice angolare, Haakse slijper, Vinkelsliper, Szlifierka kątowa, Rebarbadora, Kulmahiomakone, Vinkelslip
Use with a cutting disk (aka zip disk) to cut through thick metal quickly or with a grinding disk to grind through thick metal. very rough tool, gives really messy edges, but easy to use and quick.
Bending brake
Plåtbock
Used for bending sheet metal.
Bench grinder
Bänkslip
Makes lots of pretty sparks ¤_¤
Channel lock
Polygrip
For gripping round things like pipes.
Circle cutter
Put it in a drill press to make perfect holes.
Compressed Air
Can be found here
Great for cleaning dust from fans / heat sinks / radiators / grills.
Dremel (multi-tool)
Great tool for those small jobs. Not the best tool for long straight cuts though.
Please stop using the Dremel as a saw... @ Bit-Tech forums
Langer's Dremel Cutting Process @ Bit-Tech forums
Drill
Bohrmaschine, Borrmaskin, Taladradora, Perceuse, Trapano, Boormachine, Wiertarka, Furadeira
Good for making holes and drilling out rivets with.
Drill press
Pelarborr
Great for making precision holes with.
File
Fil, Feile, Lima, Lime, Vijl, Pilnik
Always use a file to clean up your cuts!
Hammer
Hammare, Martillo, Vasara, Marteau, Hamar, Martello, Młotek, Martelo
The arch nemesis of your thumb. Not only a great tool for stress release, but it also *makes* things fit... (Cheapskate style)
Heat gun
Värmepistol
This tool can be used for shrinking heat shrink insulation/wrap/tubing or bending plastic (acrylic) sheets.
Hole saw
Hålsåg
Put in a drill press and use to cut perfect circles. buy one mandrel and multiple saws of different sizes.
Hot glue gun
Limpistol
Great for those quick jobs where the glue joint doesn't have to be super strong and wont be seen (hot glue can be messy).
Jointer
Rikthyvel
Squares the edge of a piece of rough lumber/board, prior to joining them edge-to-edge to produce wider boards for example.
How is a Jointer Used in Woodworking? @ WiseGeek.com
Lathe
Svarv
Is used to create objects which has symmetry about an axis of rotation. Like cylindrical/conical case feet for example.
Mill
Fräs
Can be used as a drill press, but also to cut out parts from metal chunks (water blocks). Is usually equipped with an X-Y-table.
Needle file
Nålfil
Smaller version of the file. Great for filing details (like text/logo cutouts).
Nibbler
Great for making small square holes in sheet material. Do not use for long cuts, they will get jagged and your under arm and hand will be sore from the effort!
Nibbler (electrical)
This is quite a different tool compared to the manual nibbler. This one is better for making long cuts in sheet metal.
Paint Gun (power coating)
Used to paint metals... unsure about plastics or glass.
Riveter + rivet
Popnitstång + popnit
Install pop rivets to securely and tightly fasten two flat surfaces.
Router
Handöverfräs, fräs
Woodworking tool that is used to hollow out an area or shape an edge.
Router table
Fräsbord
Table for the router.
Screw Driver Set
Assorted collection of different sized Philips (cross head) and Flat head screw drivers.
Soldering iron / station
Lödkolv
Handy tool for soldering electronic circuits, or just hooking up leds for you mod.
Mayhem's soldering tips and tools @ Bit-Tech.net
How and WHY to Solder Correctly @ YouTube <-- Recommended!
Last edited by Macros_the_Black; 2nd Jun 2009 at 20:01. Reason: 'Wall of Fame' added
Macros_the_Black is offline   Reply With Quote
Old 20th Apr 2009, 19:43   #2
Macros_the_Black
Step drill / Unibit drill
Stegborr
Excellent for making different sized holes in sheet metal, w/o having to change drill bit. It can also chamfer the edge of the hole a bit for you.
Thickness planer
Planhyvel
Trims a piece of wood to an even thickness.
Tin snips / Aviation snips
Plåtsax
For cutting sheet metal. There are three basic types; straight (usually yellow), left (usually red) and right (usually green) cutting. The left and right types does straight cuts as well.
Sanders
Belt sander (hand held)
Bandslip
Use it when you want to sand away a lot of material quickly.
Belt/Disc sander
Band/skivslip
Good for sanding pieces at precise angles or for shaping convex edges (disc).
Disc sander
Skivslip
Good for sanding pieces at precise angles or for shaping convex pieces.
Sander
Slipmaskin
Use it to sand your stuff. Random orbital and "mouse" type depicted.
Saws
Bandsaw
Bandsåg
Good for making straight cuts. There are both "wood / sheet" and "metal bar" cutting types.
Circular saw
Cirkelsåg
Great for cutting long straight cuts in board materials (like chipboard, mdf, ...)
Coping saw
Figursåg
Use it for cutting intricate external designs, and some not-too-hard-to-reach internal ones (this is a manual equivalent of the scroll saw).
Fret saw
Lövsåg
Use it for cutting intricate internal design (this is a manual equivalent of the scroll saw).
Hack saw
Bågfil
Use it to cut metal manually.
Jigsaw / Jig-saw
Sticksåg
A very good tool for cutting stuffs ... ;P
Jigsaw @ wikipedia.org
Getting Jiggy @ extremehowto.com
20 Helpful JIG SAW Tips PDF
Mitre saw
Geringssåg
Used when cutting relatively narrow stuffs at precise angles ...
Mitre saw @ wikipedia.org
Scroll saw / (fret saw)
Figursåg
Weapon of choice when cutting out intricate designs...
Operating the Scroll saw instructional videos
Tile saw
Kakelsåg
Useful tool for cutting any thickness of plexi/acrylic. Cheapskate recommends the table top kind (pic #3): "can cut whole sheets or do small cuts, and can't sag like the big saw."
More stuff Cheap said about cutting with a tile saw @ This thread
Table saw
Bordssåg
Threads
Tap and die set
Gängsats
Contains tools for cutting threads in different sized holes and on rods.
Die
Gängsnitt
Cuts threads on cylinders/rods. Can also sometimes help save a screw with damaged threads (if not to severe).
Die holder / Die stock
Gängkloppa
Holds the thread die when you cut threads on a rod/cylinder.
Helicoil thread insert
Great for repairing damaged threads in soft materials like aluminium or plastics. Can also be inserted from scratch to make the threads stronger. This is useful when the screws are screwed in and out many times.
Tap
Gängtapp
Cuts threads in holes.
Tap drill sizes @ CuriousInventor.com
Tap wrench holder
Svängjärn
Holds the thread tap while you tap a hole. I usually drill a straight pilot hole through a piece of wood to help me get the thread started straight with the holder, then I back up, remove the wood guide, screw the thread tap in with my fingers only, and last I use the holder to cut to full depth. /Macros
Tap wrench (ratcheting)
Gängtappshållare ?
Holds the thread tap while you tap a hole. Easier to use than the plain tap holder (above).
Tap wrench aligner
Holds the thread tap straight while you tap a hole. Perfect straight threads every time (if you believe the sales pitch).
Thread inserts
Great for making stronger threads in softer materials like plastics. Use in screw holes where the screws are going to be unscrewed many times (like on case side panels on an all plexi case).
__________________
Tools Picture Dictionary / Visual Tools Guide <----------- I could use some help with this one, plz!
Old 20th Apr 2009, 19:43   #3
Macros_the_Black
[ Reserved space #2 ]
__________________
Old 20th Apr 2009, 19:44   #4
Macros_the_Black
[Reserved space #3]
__________________
Old 20th Apr 2009, 20:26   #5
Cheapskate
V Don't trust that face!
Cheapskate's Avatar
Cheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud ofCheapskate has much to be proud of
Reserved space #4
Haw!
-No tile saw? For cutting ANY thickness of plexiglas.
Cheapskate is offline   Reply With Quote
Old 20th Apr 2009, 20:53   #6
Macros_the_Black
;P
*Adds tile saw to the future list* Cheap, if you have suggestions on pics or links, I would be very grateful! (no pressure)
__________________
Old 20th Apr 2009, 20:59   #7
Dark~3nergy
NI NI NI !!!!!!1!
Dark~3nergy's Avatar
Dark~3nergy will become famous soon enough
very nice idea ! +1
what about CNCs and lasercuters ?
__________________
PROJECT NEOPHYTE http://forums.bit-tech.net/showthread.php?t=149036
sponsorized by : www.pc-koolance.eu
Dark~3nergy is offline   Reply With Quote
Old 20th Apr 2009, 21:04   #8
Macros_the_Black
Thanx! ^_^ *bowing*
added to future list, water jet cutter as well.
Now, times for zleep =_=
__________________
Old 20th Apr 2009, 22:27   #9
Langer
Jesse Lang
Langer's Avatar
Langer will become famous soon enoughLanger will become famous soon enough
Not perfectly in tune with the spirit of things - but here's Langers Dremel Cutting Process
Langer is offline   Reply With Quote
Old 20th Apr 2009, 23:23   #10
notatoad
pretty fing wonderful
notatoad's Avatar
notatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to allnotatoad is a name known to all
you have to be a member to read that langer.
macros, great idea. this thread will be a useful tool for overcoming language barriers, thanks for putting in the work. +rep
here's my additions:
---removed for thread cleanliness---
__________________
the old: gigabyte P35, e4300@2.8GHz, 4GB DDR3-1333, 8800gts 512, win7
the new: DFI M3H5 Jr, phenom 810, 4GB DDR-1600, OCZ Vertex, debian
notatoad.net fdo eff
notatoad is offline   Reply With Quote
Old 21st Apr 2009, 11:53   #11
Macros_the_Black
@Langer: Thanx, will add the linky when I add Multi-tool/Dremel to the dictionary (with a "needs registration" tag at the end )
@Notatoad: Thanx, yeah I thought so to... I'm giving Ocloker +1 for hatching it. Oooh, sweet! Thanks a bunch for the superb pics and texts!!!! *straining my back bowing to much*
__________________
Old 21st Apr 2009, 11:57   #12
Bindibadgi
Richard Swinburne
bit-tech Staff
Bindibadgi's Avatar
Bindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to beholdBindibadgi is a splendid one to behold
Thread Stuck.
Very useful!
__________________
Win lots of stuff with Bit-tech!
Seriously, click it! No, really, I am watching you read this..
Den of Geek!
Bindibadgi is online now   Reply With Quote
Old 21st Apr 2009, 13:39   #13
Macros_the_Black
@Bindibadgi: Goodie!
@ALL:
Got a new idea, what do you think?
What if we included names for the tools in other languages as well? Perhaps in smaller font under the english name. This way you can search the thread for the name of the tool in your native language, and if it's in the dictionary you save some time.
Something like this (though, with a bit more serious text and links):
Hammer
Hammare, Martillo, Vasara, Marteau, Hamar, Martello, Młotek, Martelo <--------------------- What do you think about this?
MC Hammer @ WikiPedia.org
Hammer tricks @ YouTube.com
__________________
Last edited by Macros_the_Black; 19th May 2009 at 17:40. Reason: changed the tool description + spelling
Old 21st Apr 2009, 15:39   #14
overdosedelusion
I mostly come at night, mostly..
overdosedelusion's Avatar
overdosedelusion is on a distinguished road
Taps, tap wrenches, helicoils/time-serts all fairly essential.
__________________
Lian-LI PCA71B | DFI DK X38-T2R | q6600 G0 | ATI 4870X2 | 4GB 800MHz | Enermax Galaxy | Samsung 40" 1080p | X-Fi Fatality Pro (Games) | M-Audio 24/96 |
Musical Fidelity V-Dac | Graham Slee Solo 2009 Headphone Amp | AKG K701/Audio Technica ATH-W1000 |
overdosedelusion is offline   Reply With Quote
Old 21st Apr 2009, 17:40   #15
Cheapskate
Cheapskate's Avatar
Updated hammer definition: *makes* things fit...
Tile saw, Have: 1 2
Recommend: * (can cut whole sheets or do small cuts, and can't sag like the big saw.
Old 21st Apr 2009, 19:21   #16
talladega
Don't Ban Me Bro!!!
talladega's Avatar
talladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond reputetalladega has a reputation beyond repute
I've heard that with tile saws it's good to use a dull blade for cutting acrylic. True?
__________________
THIS IS NOT PATRICK
How to Create Watercooling Tubing in Sketchup
Originally Posted by Krikkit View Post
Big cannons like that make me wet
talladega is offline   Reply With Quote
Old 21st Apr 2009, 19:23   #17
notatoad
notatoad's Avatar
if anybody would like to do a guide on how to properly tap a hole it would be much appreciated.
__________________
Old 21st Apr 2009, 19:39   #18
talladega
Don't Ban Me Bro!!!
talladega's Avatar
For thin aluminum(1/8") or any plastic I use a cordless drill if I can. For thicker aluminum/steel you really have to take your time doing half turn then 1/4 turn back etc.. With plenty of lubricant.
__________________
THIS IS NOT PATRICK
Old 21st Apr 2009, 22:33   #19
The_Beast
Do you expect me to talk?
The_Beast's Avatar
The_Beast is a glorious beacon of lightThe_Beast is a glorious beacon of lightThe_Beast is a glorious beacon of lightThe_Beast is a glorious beacon of lightThe_Beast is a glorious beacon of light
tables, clamps, vises, rotary sander, random orbital sander, good lights, storage cabinet, air compressor, paint gun, powder coating, oven, screw driver set, table saw, planer, jointer, wrenches, pliers, CNC mill, CNC lathe, smelter, 3d printer, plotter, squares, laser level, t square, scroll saw, paint station/station....
And the best tool in anyone's workshop: Duct tape
__________________
- Gigabyte DS3L P35 - C2Q Q6600 - Antec New Solution Series NSK4480B - Corsair XMS2 2Gb - Sapphire 2600 XT 256mb - Seagate 320 GB - 2 WD 750 GB - Dell UltraSharp U2410 - Logitech Z4 - Antec Earthwatt 430 watt - Windows XP Pro -
The_Beast is offline   Reply With Quote
Old 22nd Apr 2009, 08:56   #20
Langer
Jesse Lang
Langer's Avatar
Oops, sorry didn't realize you needed to sign up to view that.
I reposed here - for all parties interested.
Reply
Tags
dictionary, tools
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
