Go Back   bit-tech.net Forums > bit-tech.net > Article Discussion
Reply
Thread Tools
Old 22nd Apr 2009, 09:10   #1
Tim S
I Mod, Therefore I Own
Tim S's Avatar
Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.Tim S is definitely a rep cheat.
Is iTunes the best for digital distribution?
http://www.bit-tech.net/blog/2009/04...-distribution/
Tim S is offline   Reply With Quote
Old 22nd Apr 2009, 09:22   #2
ch424
Design Warrior
ch424's Avatar
ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.ch424 is definitely a rep cheat.
I now have zero apple software on my computer, so I would agree, that steam is the best, yes. You could also have pointed out that steam doesn't download Safari and set it as the default browser without asking you (I know it doesn't do this any more, but it certainly used to) along with quicktime which eats your default file settings, and a few 'iPod helper' services.
And there's obviously the conspiracy nuts that'll rant about Valve being able to steal all your information and pillage your credit card and kill your mother purely by the power of interweb. Or is that overstating things?
I know this was a joke, but surely any online service with DRM (eg iTunes) could take your credit card or retract your rights to the data you bought?
ch424 is offline   Reply With Quote
Old 22nd Apr 2009, 09:35   #3
Spiny
Multimodder
Spiny has yet to learn the way of the Dremel
You store documents & games on C:? Hahahah
Seriously though. Move your documents folder to another partition (Right click, properties and go to the location tab)
Install games on another partition too.
I reinstalled Windows last week. All I had to do was download the steam client and install it to the same location. It picked up all my installed games and saves right away. Just had to re-enter the cd key for a couple of games like UT as I presume these are stored in the registry somewhere.
Spiny is offline   Reply With Quote
Old 22nd Apr 2009, 09:53   #4
Slaughter
Multimodder
Slaughter's Avatar
Slaughter has yet to learn the way of the Dremel
Well the only thing I see in this review is personal preference. I use iTunes as my default player since I bought my trusty little iPod (3 years ago) never actually did anything without asking (as some said) i just pressed no when it ask me if I want Safari to my system... (doh, that easy) Its doing to more than 3 sec to open and load on normal usage... IF i need the store well It will take a couple of seconds but thats it everything else is hella responsive...
However, Steam is quite fast too but have you ever pressed Store or Community it does the same time to open as Apple store does ? It also upgrades things on its own even it self, without asking that is... but it has a big variety of games in CHEAP prices, i dont know why you find them expensive.
Both of them are online shops but iTunes is not only that, its a media player and if you need it then you need the extension of quicktime which has never failed or messed my pc once... it opens when its needed. On the other hand steam is only an online shop, maybe an organizer of the games, it has flaws as itunes.
You cant compare iTunes with Steam maybe Apple Shop with Steam and then again both shops think and act differently as they are talking to deferent audiences .
Slaughter is offline   Reply With Quote
Old 22nd Apr 2009, 10:39   #5
proxess
Ultramodder
proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.proxess is definitely a rep cheat.
Definitely. Had iTunes, have Steam. I used gtkpod for my iPod. Much cleaner and done exactly what I told it to.
__________________
Clevo P150SM: i7 4930MX @4.2GHz; 4x 8GB Kingston HyperX Impact 1600MHz; Nvidia 980M 8GB +220MHz Core/+350MHz Memory; Samsung 840 EVO mSATA 250GB; Ubuntu 16.04 x64 and Windows 10 Pro.
Linux #429448
proxess is offline   Reply With Quote
Old 22nd Apr 2009, 11:59   #6
Skiddywinks
Hypermodder
Skiddywinks has yet to learn the way of the DremelSkiddywinks has yet to learn the way of the Dremel
I have to agree that Steam is simply superior. May have to give this gtkpod a go. ITunes does nothing but irritate me.
Skiddywinks is offline   Reply With Quote
Old 22nd Apr 2009, 13:28   #7
Blademrk
Why so serious?
Blademrk's Avatar
Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.Blademrk is the Cheesecake. Relix smiles down upon them.
the other thing that Steam does better than iTunes is that any purchases can be re-downloaded without re-purchasing.
I've previously lost a couple of itunes tracks that I hadn't had a chance to back-up after a drive started corrupting files.
I also bought a track recently on iTunes ("The Truth" by Lacuna coil after playing it on GH:WT and not being able to get it out of my head) which I'm 99% positive was corrupted on download as just before the end of the song the volume fades out and theres a couple of strange noises before the song fades back in.
If I could re-download purchases (like we can with Steam) this wouldn't be a problem.
__________________
刃mrk
My X-Box Live gamertag, PSN, Steam & Nintendo ID is BladeMrk
Blademrk is offline   Reply With Quote
Old 22nd Apr 2009, 13:40   #8
badders
Neuken in de Keuken
badders's Avatar
badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.badders is the Cheesecake. Relix smiles down upon them.
+1
This is my number one gripe with iTunes.
__________________
Originally Posted by Silver51 View Post
John Hanlon standing on an oil pipeline during a blizzard, punching an angry polar bear in the balls. I heard he really did that once.
badders is offline   Reply With Quote
Old 22nd Apr 2009, 15:30   #9
Skiddywinks
Hypermodder
Christ, I can't believe they get away with that. I have never used the store, but assumed they followed the same sort of guidelines as Steam in terms of redownloading.
Old 22nd Apr 2009, 18:33   #10
wuyanxu
still wants Homeworld 3
wuyanxu's Avatar
wuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyanwuyanxu is a Super Spamming Saiyan
although i totally agree Steam's system is the best known (to me at least) but wouldn't it be a better comparison to do iTunes vs Amazon? since after all, they both actually sells music.
__________________
i7 2700k \ 16GB \ GTX 970 \ D2x \ Z68x-UD5 \ m4 128GB +2TB \ S12G-550 \ FT02-RW \ G15+G5+G51 \ U2711
X100 \ X-E2 \ 10-24 \ 55-200 \ 18/2 \ 60/2.4 \ Yn560 \ X1.1a \ Hadley Pro -- Photostreamr
wuyanxu is offline   Reply With Quote
Old 22nd Apr 2009, 21:08   #11
Angleus
Hypermodder
Angleus's Avatar
Angleus has yet to learn the way of the Dremel
I love steam! But I only realised this after moving to Windows 7 and realising I didn't need any disc to reinstall my games, now its awesome and I tend to buy most of the weekend deals
Angleus is offline   Reply With Quote
Old 24th Apr 2009, 14:11   #12
pizan
that's n00b-tastic
pizan's Avatar
pizan has yet to learn the way of the Dremel
I <3 Steam for all the reasons stated above and also i like the way it evolved community wise. Friends works really well and i like that you can list 3rd party apps in friends so people know if I'm playing a non-Steam game. Also with Steam you can get all the SDKs and other stuff that i wouldn't have a clue where to get otherwise.
__________________
Hardware: Foxconn BloodRage - Core i7 920 - EVGA HydroCopper GTX 285 - Mushkin Redline 998691 - Antec Signature 850w - Intel X-25M G2 80GB - WD VelociRaptor 300GB - WD Cavier Black 1TB
Cooling: TFC X-Changer 480 Push/Pull - Laing D5 Vario - Swiftech Apogee GTZ - Swiftech MCRES v2 - North Bridge - VGA
pizan is offline   Reply With Quote
Old 25th Apr 2009, 17:15   #13
Spaceraver
Ultralurker
Spaceraver's Avatar
Spaceraver has yet to learn the way of the Dremel
For Digital distribution Steam is still king.. Tried Itunes and never liked it. I use Emusic.com instead for music.
For everything else there is the rest of the net.
Because I can't buy a lot of the things i want because they are not available here in europe.
__________________
"Faith: not *wanting* to know what is true." - Friedrich Nietzsche. "Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." - Seneca
Curiosity *may* have killed SchrŲdinger's cat.
Spaceraver is offline   Reply With Quote
Old 25th Apr 2009, 17:50   #14
Claave
You Rebel scum
Claave's Avatar
Claave has yet to learn the way of the DremelClaave has yet to learn the way of the DremelClaave has yet to learn the way of the Dremel
Yes, I guess it could. But the backlash for doing so would make such action unlikely.
Claave is offline   Reply With Quote
Old 25th Apr 2009, 17:56   #15
Claave
You Rebel scum
Claave's Avatar
Might want to back up your registry with regedit too then for a smooth transition. I did used to run separate partitions for Windows, docs and apps but got annoyed with it - too many programs would ignore Tweak UI and install to C: regardless. Or just refuse to work unless they were installed to C:, and then the C: drive would fill up too quickly. Maybe I'm just stingy and I should've got a bigger HDD!
Yep, blog=opinion piece, not a review. I was just making a point.
Oh, and multi-quote ftw!
Old 27th Apr 2009, 21:58   #16
ZERO <ibis>
Supermodder
ZERO <ibis>'s Avatar
ZERO <ibis> has yet to learn the way of the DremelZERO <ibis> has yet to learn the way of the Dremel
When I got my imod(yes imod not ipod) I removed every last apple thing from it by: 1) putting rockbox on it and 2) even getting rid of there boot and dock logos
I have no apple software on my computer and will not go near it. If something requires apple software to work I will either not use it or install it in a shell only so that I can have it gone forever when I delete it.
Steam has caused some headaches especially for me being a very early adopter. But it is way way better than any apple program I have used even when steam was at its worse.
__________________
965 @ 4.26GHz-P6T DELUXE-GTX 280@750&1307-DDR3 Triple Channel@1001 MHz-RAID 0 Cheta 15.6k SAS-All Water cooled
IBIS GAMING
ZERO <ibis> is offline   Reply With Quote
Old 29th Apr 2009, 21:44   #17
TrickSh0t
What's a Dremel?
TrickSh0t has yet to learn the way of the Dremel
Blademrk, the song you're referring to is "Our Truth", and the fade out with radio station changing noises and then baseline fade in is the way the track was meant to sound. In GH:WT (and Rock Band for that matter), its cut out ... which is a shame because I actually like that part of the song.
Cheers!
Oh, yes, iTunes can be terminally slow in Windows, but its actually a lot faster in OS X. Conspiracy? Maybe.
TrickSh0t is offline   Reply With Quote
Old 30th Apr 2009, 10:37   #18
Blademrk
Why so serious?
Blademrk's Avatar
Cheers, just thought it sounded odd. I tried listening to it through a few different streaming sites (youtube, lastfm, etc...) and didn't here the noises so I reported it through the iTunes link in the email reciept and they gave me a track credit.
__________________
刃mrk
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
