Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 5th Sep 2010, 02:47   #181
confusis
Kiwi-modder
confusis's Avatar
confusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysisconfusis can run Crysis
182
SMP on my opteron rig.. have SMP folding @ 75% of capacity (any higher and it will overheat with these oem heatsinks) and my GT240 folding GPU3
confusis is offline   Reply With Quote
Old 19th Sep 2010, 16:03   #182
Gothic-Yoshi
The Matrix has you!!!
Gothic-Yoshi has yet to learn the way of the Dremel
181[/size]
Core 2 Quad Q8300
__________________
Folding stats
I dont use windows because i like it, i use it because it has DirectX
Gothic-Yoshi is offline   Reply With Quote
Old 2nd Oct 2010, 16:08   #183
Yosip
What's a Dremel?
Yosip has yet to learn the way of the Dremel
180
AMD Athlon64 3800+
Yosip is offline   Reply With Quote
Old 3rd Oct 2010, 05:23   #184
One_Box
Folder of the month April 2012
One_Box has yet to learn the way of the Dremel
Phenom X 2 555 Black Edition (with 2 dormant cores unlocked) - still playing with the overclock at present.
179
__________________
Folding stats
Folding stats
One_Box is offline   Reply With Quote
Old 3rd Oct 2010, 10:06   #185
BJS
Minimodder
BJS has yet to learn the way of the Dremel
Two smp clients so,
175
BJS is offline   Reply With Quote
Old 4th Oct 2010, 17:50   #186
Fanatic
Monimidder
Fanatic's Avatar
Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!Fanatic - it's over 9000!!!!!!!!1!1!1!!!
3 x quad xeons, 1 quad i7 and 2 dual core mobiles - total of 10 new smp's = 20 off total
155
Fanatic is online now   Reply With Quote
Old 19th Oct 2010, 20:08   #187
raideralpha
Mastery takes time. Spend it wisely
raideralpha has yet to learn the way of the Dremel
153
Folding stats
raideralpha is offline   Reply With Quote
Old 25th Oct 2010, 12:38   #188
GeorgeStorm
Aggressive PC Builder
GeorgeStorm's Avatar
GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.GeorgeStorm is definitely a rep cheat.
Added my laptop running SMP (p8600)
152
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Splooshiba
My flickr - My blog it'sfilmnotmovie
GeorgeStorm is online now   Reply With Quote
Old 25th Oct 2010, 13:05   #189
Scruffy_Dog
Woof
Scruffy_Dog has yet to learn the way of the Dremel
Two smp one on an i5-750 and one on an i7-920. i5 will be part time but it will hopefully do 1 wu each day.
148
__________________
Folding stats
Scruffy_Dog is offline   Reply With Quote
Old 27th Oct 2010, 09:09   #190
scr1bles
What's a Dremel?
scr1bles has yet to learn the way of the Dremel
added my work PC,
147
scr1bles is offline   Reply With Quote
Old 30th Oct 2010, 17:05   #191
Synay
Supermodder
Synay's Avatar
Synay has yet to learn the way of the Dremel
Core i3 @ 4.2 GHz
146
Synay is offline   Reply With Quote
Old 30th Oct 2010, 17:34   #192
ydna666
Minimodder
ydna666's Avatar
ydna666 has yet to learn the way of the Dremel
145
Phenom 1090T @ 4ghz
__________________
Folding stats
ydna666 is offline   Reply With Quote
Old 7th Nov 2010, 09:24   #193
seacombe2379
Old Folder
seacombe2379's Avatar
seacombe2379 has yet to learn the way of the Dremel
144
Intel Quad Q6600 @ 3.6ghz
am back again after a few years out lol
seacombe2379 is offline   Reply With Quote
Old 8th Nov 2010, 11:13   #194
holzj17
Multimodder
holzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysisholzj17 can run Crysis
my first post!!!
I7 920 @ 4Ghz
142
holzj17 is offline   Reply With Quote
Old 9th Nov 2010, 15:48   #195
Simnol
Minimodder
Simnol has yet to learn the way of the Dremel
139
Two Xeons and one i7980x
UKFast (Folding Name)
Twenty Cores.
Simnol is offline   Reply With Quote
Old 9th Nov 2010, 16:07   #196
chimeradog
Multimodder
chimeradog's Avatar
chimeradog has yet to learn the way of the Dremel
i5-750@stock
138
__________________
Just started to fold
chimeradog is offline   Reply With Quote
Old 15th Nov 2010, 15:38   #197
djzic
Bokehlicious!
djzic's Avatar
djzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremeldjzic has yet to learn the way of the Dremel
Athlon 64 4200+ @ 3GHz and i3 @ 4.5GHz
137
__________________
Check out my build: the Shuttle.
Q8300. 8gb XMS2. ATI 4650.
Thermalright AXP-140. Samsung SpinPoint 1TB.
1U 300w PSU. Shuttle Case. MDPC-X Sleeving.
djzic is offline   Reply With Quote
Old 15th Nov 2010, 16:24   #198
Synay
Supermodder
Synay's Avatar
Core it 860 (stock for now, overclocked by the end of the week)
136
Old 28th Nov 2010, 10:50   #199
BennieboyUK
CPC Folder of the Month Sep 2011
BennieboyUK's Avatar
BennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for presidentBennieboyUK should be considered for president
x5 Quad Xeons -SMP
x2 8 Core Xeons -SMP -BIGADV
Q6700 - STD
x1 Quad Xeon - Std
7 SMP CLients, 2 STD = 16 off.
120
BennieboyUK is offline   Reply With Quote
Old 9th Dec 2010, 09:00   #200
pyro1son
Linux User!
pyro1son's Avatar
pyro1son has yet to learn the way of the Dremelpyro1son has yet to learn the way of the Dremelpyro1son has yet to learn the way of the Dremel
119
__________________
Main Rig
Phenom II X4 | Dark Rock Pro | GA-880GA-UD3H | GTX 460 | 2x2Gb HyperX Blu & 2x4Gb XMS3 | 250GB 840 SSD | 1TB + 3TB HDD | CM 690 II Advanced
Laptop
i5 24320M | nVidia GT540M | 4Gb RAM | 500GB HDD
Steam, Origin, BFBC2, WoT: Pyr0660
pyro1son is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
