Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 29th May 2009, 22:32   #41
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
Originally Posted by loner1994 View Post
go highly oc'ed e5200(3.9)
/snip/
Grats on that alone! And welcome!
Unicorn is offline   Reply With Quote
Old 31st May 2009, 03:38   #42
boiled_elephant
I actually like Doom 3.
boiled_elephant's Avatar
boiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for presidentboiled_elephant should be considered for president
I've just got one core of my E8400 going with a regular client, but I've also got the GPU client eating up my 4870 - do GPU clients factor into this list at all?
edit - oh, duh, there's a separate thread for GPUs
So, another 1 from me (I only run one core's worth of CPU client, rather than using both, because I run GPU client alongside it and that uses a good chunk of the CPU as well.)
487
__________________
Build: Lian Li Tu-200B
Forum Pet Projects: Bang-for-Buck Graphics Cards Analysis || Split-Screen Co-op Gaming List || Emerging Genres: The Sims & Heavy Rain
(there are too many quotes to fit into my sig now so I threw them all over here instead)
boiled_elephant is offline   Reply With Quote
Old 5th Jun 2009, 14:24   #43
PS3/LanDi
Give me the Mirror
PS3/LanDi's Avatar
PS3/LanDi has yet to learn the way of the Dremel
477
Added 10 more cpu clients (core 2 -2.8) 4gb ram
Also had a power failure on all main servers so half results yesterday and will take a while to get up to full speed, hope these help.
__________________
Folding stats
PS3/LanDi is offline   Reply With Quote
Old 6th Jun 2009, 21:36   #44
LatinSpirit
Multimodder
LatinSpirit's Avatar
LatinSpirit has yet to learn the way of the DremelLatinSpirit has yet to learn the way of the DremelLatinSpirit has yet to learn the way of the DremelLatinSpirit has yet to learn the way of the DremelLatinSpirit has yet to learn the way of the DremelLatinSpirit has yet to learn the way of the Dremel
Both cores of my OC'd e7200 run a standard client each.....does that count as 1 or 2?
LatinSpirit is offline   Reply With Quote
Old 6th Jun 2009, 21:56   #45
Unicorn
Unicorn's Avatar
2 as far as I know;
Originally Posted by Lizard View Post
In a spin-off of the highly successful countdown to 360 GPUs thread started in late 2008 we thought it would be a good idea to start a CPU countdown thread.
The target for this thread will be to add another 1,000 CPUs to the Custom PC folding team.
As rules are as follows:
1. Subtract one CPU from the countdown if you add a standard CPU client.
or
2. Subtract two CPUs from the countdown if you add an SMP CPU client.
When you add more CPU clients, subtract the number from the total and post the new total in size '7', colour 'red', in 'bold', at the bottom of your post.
Q6600 @3.0Ghz running 2 VMware SMP clients.
471
Old 6th Jun 2009, 22:03   #46
LatinSpirit
Multimodder
Ok, thanks......2 it is!
469
Old 6th Jun 2009, 23:53   #47
standinwave
Folding in memory of my mum
standinwave has yet to learn the way of the Dremel
I cracked the screen on my wurk laptop (but still use it and fold on it with SMP client) and got given a spare with dual core so I added two regular clients as I dont ave admin rights yet. The CPU fan is like a hairdryer tho!
467
Last edited by standinwave; 6th Jun 2009 at 23:55. Reason: forgot countdown! and bold!
standinwave is offline   Reply With Quote
Old 7th Jun 2009, 16:48   #48
PlasmaBomb
CPC Refugee
PlasmaBomb has yet to learn the way of the Dremel
Seems good Uni...
Sorry
PlasmaBomb is offline   Reply With Quote
Old 8th Jun 2009, 16:26   #49
Unicorn
Unicorn's Avatar
This got messed up really fast, so here's how it should be (AFAIK). Correct if wrong Plx.
Originally Posted by PS3/LanDi View Post
477
Start at 477.
Remove 2 for that, 475.
471
Each SMP client is 2, I'm running 2 SMP clients so that's 4. 471.
469
I already subtracted yours correctly in my post above, so it's still 471.
467
One SMP client = 2.
2 regular clients = 2.
2 + 2 = 4.
471 - 4 = 467.
The figure now stands at 467
Old 11th Jun 2009, 17:29   #50
Fisher.
partially impartial
Fisher.'s Avatar
Fisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run CrysisFisher. can run Crysis
I believe you are correct.
In re: to this post, I finally uploaded some pics:
Not all of them, but the rest are in my "other" office.
__________________
[Space reserved for something witty]
Fisher. is offline   Reply With Quote
Old 12th Jun 2009, 12:16   #51
PS3/LanDi
Give me the Mirror
PS3/LanDi's Avatar
452
added 15 more cpu clients. should be maxed out for now.
__________________
Folding stats
Old 23rd Jun 2009, 13:02   #52
Votick
CHMOD bit-tech 777
Votick's Avatar
Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.Votick is a hoopy frood who really knows where their towel is.
449
3 CPU Clients
__________________
Folding stats
| AMD FX 8350 @ 4.0GHZ | Gigabyte GA-990FXA-UD5 | 16GB Corsair Vengeance DDR3 1600mhz |
| Corsair Force 3 120GB SSD X 2 RAID0| Corsair H100 | Samsung F3 1TB HDD | MSI GeForce GTX 680 SLI |
| Silverstone 1200W | Corsair 650D | LG IPS225V X 2 |
Votick is offline   Reply With Quote
Old 23rd Jun 2009, 14:24   #53
Christopher N. Lew
Folding in memory of my father
Christopher N. Lew's Avatar
Christopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for presidentChristopher N. Lew should be considered for president
OK, that's scary. Not the PCs, but the clean, uncluttered work-surface.
__________________
Folding stats
Christopher N. Lew is offline   Reply With Quote
Old 24th Jun 2009, 15:51   #54
Fisher.
partially impartial
Fisher.'s Avatar
Yeah, that's mostly because I'm only in there to switch out machines
You should see pics of the office I'm in the rest of the time, it looks like there was an earthquake at a Fry's.
__________________
Old 24th Jun 2009, 16:52   #55
Unicorn
Unicorn's Avatar
Old 7th Jul 2009, 16:08   #56
MrWillyWonka
Chocolate computers galore!
Moderator
MrWillyWonka's Avatar
MrWillyWonka has yet to learn the way of the DremelMrWillyWonka has yet to learn the way of the DremelMrWillyWonka has yet to learn the way of the Dremel
Got 23 running for us now
Potentially another 32 more - possibly.
449 - 23 =
426
MrWillyWonka is offline   Reply With Quote
Old 11th Jul 2009, 22:55   #57
StreetSam
Multimodder
StreetSam's Avatar
StreetSam has yet to learn the way of the Dremel
Hi All,
2x Q6600
1x Q9550
and more to come
423
__________________
Folding stats
Current Folding@Home stats
StreetSam is offline   Reply With Quote
Old 12th Jul 2009, 08:35   #58
Panomama
's custom title is teh srs bizznizz
Panomama's Avatar
Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.Panomama is a hoopy frood who really knows where their towel is.
421
Panomama is offline   Reply With Quote
Old 13th Jul 2009, 07:31   #59
Bonzo45
Ex CPC
Bonzo45's Avatar
Bonzo45 has yet to learn the way of the Dremel
419
Q6600 @ 2.7GHz, may be higher in the future.
__________________
|| Q6600 @ 2.7GHz || HD4850 || 4GB (2x2GB) DDRII 800MHz || Crucial C300 64GB || Samsung F1 1TB & Samsung 500GB || Samsung Lightscribe drive || 500W Seagate PSU || GA-P31-DS3l mobo || Arctic cooling F7Pro || Samsung T220 22" || 7 Home Premium 64bit
Bonzo45 is offline   Reply With Quote
Old 15th Jul 2009, 08:14   #60
Aracos
Formerly called storm20200
Aracos's Avatar
Aracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run CrysisAracos can run Crysis
Dammit men! We need more CPU's! 1 1.67GHz Sempron for when I'm not gaming!
418
Aracos is offline   Reply With Quote
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
