Go Back   bit-tech.net Forums > Technology > Custom PC and bit-tech Folding Team
Reply
Thread Tools
Old 23rd Apr 2009, 11:55   #1
Lizard
@ Scan R&D
Moderator
Lizard's Avatar
Lizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run CrysisLizard can run Crysis
How to insert folding stats in your forum signature
All credit for this thread should go to pomeroyip, as he set up the original thread on the old Custom PC forum - I'm simply recreating it here for continuity.
As this question gets asked so often, here is how to do it:
To add your stats to your sig enter the params surrounded by the [folding] tag into your forum profile sig box.
Example:
[folding]u=FAHUSERNUMBER&t=TEAMID[/folding]
You can get your folding username from the end of the URL on http://folding.extremeoverclocking.com
i.e. http://folding.extremeoverclocking.c...php?s=&u=83772
Lizard is offline   Reply With Quote
Old 23rd Apr 2009, 12:34   #2
Flibblebot
Gimp dog!
Flibblebot's Avatar
Flibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpitFlibblebot is almost as Godly as yodasarmpit
Except that the bit-tech forum doesn't allow images in sigs - unless it's possible to change that on a section-by-section basis?
__________________
My uber-system: 66Mhz 486DX2, 8Mb RAM, 20Mb hard drive, 256 colour VGA adaptor (goes all the way up to 800x600!), keyboard AND serial mouse
Flibblebot is offline   Reply With Quote
Old 23rd Apr 2009, 12:41   #3
Lizard
@ Scan R&D
Moderator
Lizard's Avatar
Good point - thanks for reminding me of that.
We'll do some behind the scenes work and see what can be done.
Old 23rd Apr 2009, 16:26   #4
kenco_uk
I unsuccessfully then tried again
kenco_uk's Avatar
kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.kenco_uk is the Cheesecake. Relix smiles down upon them.
I guess when you change team, you have to let it do a unit before new stats come up?
edit: yup
__________________
Mac:Macbook Pro 7,1 w/Samsung 830 256GB, ML
xbmc:Windows 8 x64, Fractal Design Node 304, MSI Z77IA-E53, G2120 fanless, 2x2GB, 3TB, Samsung 830 256GB
dazzypops:Win8Prox64, i5-2500k@4.3, 8GB, 4TB, Samsung 840 Pro 256GB, MSI GTX660 (+110core, +535mem), LG IPS 24", Z5400 5.1
Put my hands behind my head, crouch down and fall forwards - that's how I roll.
kenco_uk is offline   Reply With Quote
Old 23rd Apr 2009, 16:38   #5
Jamie
ex-Bit-Tech code junkie
Jamie's Avatar
Jamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the DremelJamie has yet to learn the way of the Dremel
Sigs now working in this forum. I've edited the first post to reflect what you need to do.
__________________
Discover books together at anobii
bit-tech hosted by Tsohost
Truly unlimited mobile data on GiffGaff
Use Quidco when shopping and get cashback
Jamie is offline   Reply With Quote
Old 23rd Apr 2009, 16:40   #6
JackOfAll
Linux Folding Grunt
JackOfAll's Avatar
JackOfAll has yet to learn the way of the Dremel
Jamie, is there something else I need to do, other than > 10 posts? I still can't see anywhere to add a sig in the CP.
JackOfAll is offline   Reply With Quote
Old 23rd Apr 2009, 16:42   #7
Jamie
Jamie's Avatar
The promotion is only run every hour at 45 minutes past the hour, you'll have to wait 3 more minutes.
__________________
Old 23rd Apr 2009, 16:44   #8
Sifter3000
I used to be somebody
Moderator
Sifter3000's Avatar
Sifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the DremelSifter3000 has yet to learn the way of the Dremel
AFAIK, yes. Plus the Folding stats only update every 3-5 hours.
__________________
The Rt Hon Alex Watson.
Dennis Publishing Emerging Platforms, bit and CPC alumni.
My weblog is The Wired Jester.
Photos on Flickr.
Sifter3000 is offline   Reply With Quote
Old 23rd Apr 2009, 16:52   #9
JackOfAll
Linux Folding Grunt
JackOfAll's Avatar
Testing sig ......
__________________
Folding on Linux: Fedora 10 & 11 x86_64 / nVidia 180.60 driver / CUDA 2.1
Folding stats
Folding stats
Old 23rd Apr 2009, 16:54   #10
Sifter3000
Moderator
Sifter3000's Avatar
Testing sig ......
You need to make sure there are *no* spaces in the code (i.e. the stuff in square brackets)
__________________
Photos on Flickr.
Old 23rd Apr 2009, 16:57   #11
JackOfAll
Linux Folding Grunt
JackOfAll's Avatar
Thank you!
__________________
Folding stats
Folding stats
Old 23rd Apr 2009, 19:02   #12
500mph
The Right man in the Wrong place
500mph's Avatar
500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel500mph has yet to learn the way of the Dremel
Testing.
Yay!
Why are there different colors?
__________________
Rocketfeesh Emergen-C!
[Web][Twitter][Steam]
500mph is offline   Reply With Quote
Old 23rd Apr 2009, 22:24   #13
Sifter3000
Moderator
Sifter3000's Avatar
Originally Posted by 500mph View Post
Testing.
Yay!
Where abouts? You can change the colours of the forum in your user CP, but that's just a preference...
__________________
Photos on Flickr.
Old 23rd Apr 2009, 22:46   #14
500mph
500mph's Avatar
The different colors of the folding stats
__________________
Old 24th Apr 2009, 08:33   #15
saspro
Infrastructure Specialist
saspro's Avatar
saspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpit
The colours change depending on how many points you produce
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is offline   Reply With Quote
Old 24th Apr 2009, 10:02   #16
kenco_uk
kenco_uk's Avatar
Originally Posted by Thaifood View Post
testing..
ok why is it so much more difficult to put folding stats on in here?
Go to User CP (on the blue bar under the thread heading), edit your signature and then add the folding tag into your sig.
__________________
Old 24th Apr 2009, 17:13   #17
Thaifood
Multimodder
Thaifood's Avatar
Thaifood has yet to learn the way of the DremelThaifood has yet to learn the way of the Dremel
nope i lied.. it shows me in my profile that it shows my sig..
http://folding.extremeoverclocking.c...d&t=35947/.gif
Thaifood is offline   Reply With Quote
Old 24th Apr 2009, 18:39   #18
Majik
Another CPC refugee
Majik's Avatar
Majik has yet to learn the way of the Dremel
It's good to be here and let's hope we have a great future together!
Majik is offline   Reply With Quote
Old 24th Apr 2009, 20:08   #19
denis6902
deathbox
denis6902's Avatar
denis6902 has yet to learn the way of the Dremel
testing sig, lucky you guys, just reinstalled vista and the newer 64bit ubuntu 9.04 and its all set for folding again! Lucky because i am going to contribute for this team!
I guess sig didnt work, now it does!
denis6902 is offline   Reply With Quote
Old 24th Apr 2009, 20:12   #20
denis6902
deathbox
denis6902's Avatar
btw, when are the lazy bones from standford going to make a gpu folding in linux? not even going to mention xbox360
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
