#21 |
Duty Target
Hi Guys and Girls,
Some what new to this game however I was wondering how to alter the FAH prog so it auto starts when the comp is turned on, since the good lady is unlikely to remember to do it. In addition how do I get the second core folding as well? Running windows XP on a core 2 45nm chip. Thanks in advance. |
#22 |
Infrastructure Specialist
To get it to autostart just place a shortcut in the startup folder
To use both cores you'll need either SMP or run 2 instances
__________________
If what I've said helps you please remember to hit the rep button on the left Missing the old meeting place? Find us here |
#23 |
Uniform November India
Where's babychunder these days? Do I remember him throwing in the towel a while ago?
__________________
#25 |
Thought so, I'd forgotten why but I remembered that he had finished folding for now.
__________________
#26 |
What's a Dremel?
Still here, lurking.
#27 |
Folding Chimp
__________________
P5Q Pro - E8400@3.6ghz - 4gbOCZ Gold - 2x XFX Alfadog 8800GT - Antec 300 - OCZ SteathXStream 600w Folding for my family. |
#28 |
Folding Millionaire
__________________
Folding Millionaire and Sleeping CPChimp until 2010 |
#29 |
What's a Dremel?
All well thanks. And how is everyone here, what's the gossip?
#30 |
What's a Dremel?
How to get the most Folding Points from your Hardware
Which version are you running?
Anyways to get on a sub-team you just have to change your folding username to Spider_Monkey and then youll be part of the monkey federation. If you want to act the part it is welcomed. |
#31 |
Two heads are better than one
Great article. Particularly for a new folder like myself. Thank you
#32 |
Minimodder
Im not sure what setup this site used for there ppd setup. my core 216/260 gets 8500 a day average 9200 on a 353 running 675/1560 even without over clcoking i get more than they say
#33 |
I'm getting 6648 from a GTX 280 running an 1888 point project & a -smp 8
__________________
#34 |
Minimodder
G0UDG 8800 GTX issues
when setting up the client's smp needs to be set to idle priority, gpu to low priority soo it can take the cpu cycles it wants. as for your gtx280 what shader speed do you run? find out at what shader speed it corups the client then back off about 50mhz. My gtx260, bfg maxcore55 from bestbuy folds 24/7 with the shader's set at 1560 but it will not play games at that speed. and my fans are set to 80% 51c doing 1888 61c doing a 353
#35 |
Minimodder
i have started a team called team_ubuntu. how to get along now? what to do next to get most points?
#36 |
First I'd start by ditching your team. Creating a username & joining this team
__________________
#38 |
1st mod - Done:)
there is some stuff if you type folding into the search bar i think it's there some where. lists on what hardware is best value/power consumption and things like that
#39 |
generic babble ->
This list needs updating, No mention of GPU 3.
For those of you who need to know: for fermi (gtx/s 400) you need gpu3. In a recent cpc/bit-tech article it was found that gpu2 should be used for gtx200 series as this provided much better ppd than gpu3. EDIT - Just saw the console client is the best gpu there is, Is this still true?? is there even a gpu3 console client?
__________________
800d, 920d0, 6GB Dominators , Asus P6Tv2, XFX 5870 X2, Intel X25-M 160GB,
Samsung F1, Corsair HX1000, Asus Xonar DX, Dell U2410, PC360's, 2XEK5870 waterblock, Swiftech XT, XSPC RX360, Feser Xchanger 240 |
#40 |
I *am* a Dremel
This list really does need updating badly!
__________________
| Thread Tools | |
