#81 |
Modder
Just started today, so learnin as i go along, but put the key in for more points...not sure what its all about, but more points sounds good.
1 question, while im folding, my gpu is going up to 89 degree's under full load, is this normal ? Movin to a new case soon with better cooling, so hopfully wont be this hot for long, but is that temp damaging to my gpu ?? |
#82 |
Multimodder
I have an i5-2500K running at 4.2GHz, with a HD Radeon 5850 GPU at stock speeds. Is there anything (bar heavy OC'ing) I can do to push out a higher PPD than around 6,500?
__________________
#83 |
Ultramodder
Is the 6500 PPD between both? As that is very low. The 2500k should net around 15k on its own, I would turn the 5850 off as it is likely draining its resources, using more power and overall providing lower points. AMD cards generally suck at folding.
#84 |
Multimodder
Will give that a try, thanks.
Will changing to a Nvidia GTX GPU net much better PPD then, say a 560ti 448 for example?
__________________
#85 |
Ultramodder
Any Nvidia GPU will net more points than an AMD GPU. They simply work better for what FAH is trying to do.
If you are going to spend cash specifically and solely on folding, CPU power is best if you can afford a new-ish CPU architecture. The higher end chips on socket 1155, 1136 and 2011 are beasts for folding and will churn out far more points for far lower electricity usage. Useful link to give you an idea of PPD/£: http://www.bit-tech.net/hardware/gra...-for-folding/4 |
#86 |
Multimodder
That's a really helpful link, thanks. Looks like an eBay scout around for a GTX 560 ti (448?) is in order.
Although, the newer AMD cards run differently now, has anyone got an average PPD for a new 7800 series card?
__________________
#87 |
What's a Dremel?
Very interesting topic.
I gonna check some things out
#88 | |
Folding in memory of my father
The usual advice is to buy the graphics card you want for other applications, and think of folding as a secondary consideration.
__________________
#89 |
Multimodder
Interesting info there. I will turn my clients to fold on 2 CPU cores, my AMD GPU and that should leave 1 core free for casual stuff.
Currently away from my computer and see that my signature says I have scored no points for 2 days... Not good... UPDATE 01-10-12: Setting my V7 client to the above has resulted in a new PPD of 18,000. Result.
__________________
#90 |
What's a Dremel?
Hi folks - was pondering turning off the ati gpu's (11k ppd) and setting the CPU back to 8 threads (I7-975EE with lots of headroom) and going for a Bigadv run, but...I can't see how to do that in V7 - can it still be done?
Cheers. |
#91 | |
Cheesecake Nom Nom
![]() tbh i dont think it makes any difference these days as i get so many different WU's with varying PPD you need to get rid of the ATi gpu's and get a Nvidia gpu ![]() my GTX560 none TI gets 12-17k ppd on its own
__________________
2x Xeon 5620 @ 3.8GHz under water ![]() 3770k @ 4.8GHz, Custom loop, 7970 OC'd |
#92 |
What's a Dremel?
hi - cheers but that doesn't go in depth enough - I have discovered this one though which is really helpful for all settings:
http://foldingforum.org/viewtopic.php?f=67&t=18187 Hope it helps a few ppl |
#93 | |
Cheesecake Nom Nom
beside its still the same guide. but the flags dont really work for me.... ive just got a intel duel core cpu that im testing OC'ing ready for adding a gpu to fold on, ive set the max-packet-size to small and it picked up a nice small 85 base point WU, but the second WU it picked up was 1800+ base point WU, which its going to take over 2 days to complete.... so setting that flag has done nothing
__________________
#94 |
What's a Dremel?
ah - it's helped me a bit - didn't know how to set the flags before - regarding the graphics cards - would be lovely to afford an Nvidia card but I've a daughter aged 5, another aged 2 and a 2 month old son....PC is low priority process stream just now
(I inherited the 975 free from a mate who's a CAD guy and was upgrading) I can't say as the flag itself will help, I'm running at 3.75Ghz on 8 threads and getting estimated 17k pts from a 2.2k work unit (24 hrs turnaround) - I will see if I get any interesting units after this one completes- all about trial and error and learning from everyone else
Last edited by Ptarmigan; 14th Oct 2012 at 19:56. Reason: added time to complete |
#95 | |
Ultramodder
Unless you were willing to do a Linux install and try and trick it, but even then I doubt this CPU is near fast enough. |
#96 |
Cheesecake Nom Nom
thats bigbeta isnt it?
__________________
#97 |
Ultramodder
#98 |
Multimodder
How much PPD would an Intel Xeon 5450 produce? Thinking of building a second system based around 2 of them.
http://www.ebay.co.uk/itm/Intel-Xeon...item3a7e4494ec
__________________
Last edited by mikemaher205; 11th Feb 2013 at 21:29. Reason: Change of thought... |
| Thread Tools | |
