#81 | |
really joined on Dec 24th 2004.
Never mind, I found it eventually.
__________________
#82 |
My eyes! The goggles do nothing!
Amazing...i had never heard of this project until stumbling upon it here at bit-tech. I probably wont be a huge contributor (i cant afford to leave my rig running 24/7), but im folding as we speak!
#83 |
here
I'm folding on my gtx280's
under the name Mega_bite. hi btw.... :-)
__________________
The ever changing system.... I7 920 (stock atm) XFX X58, 3x 2GB Obsidian OCZ, 2x GTX 280 SLi, NorthQ 850watt Giantconnector, WD 640GB and 1TB, Antec1200. Cooling: laing ddc1+ xspc restop>Cupluex Di>XSPC 240 rad >dual EK GTX280 blocks with backplates> TFC 360rad (all internally mounted on the 1200) |
#84 |
Ultramodder
I just joined in too. Until I can get some juicier parts I think I too will not be contributing much to modern day science, or improving the bit-tech standings, but every little helps.
__________________
Intel i5 2500k * Corsair H50 * 2 x Gkill Ripjaw Z 4gb * Asus Maximus V Gene * Evga 560Ti * OCZ Vertex 3 * 1 TB Samsung F2 * Antec Truepower 650* Fractal R3 * Win 7 Home Premium 64bit * LG 27" w2753vc upgrade list:Blu-ray drive It doesn't matter if you make a mistake, it only matters if you don't learn from it
#85 |
CPC Folder of the Month Sep 2011
Hi, I am new to these forums and the team. I am a keen reader for CPC and I am hoping my folding will make a difference for both the team and the cause.
Only folding CPU's at this time, may consider GPU's sometime soon
#86 | |
Butt-kicking for goodness!
Looking at your setup,could you not run bigadv clients on all your quads?
__________________
Uni Box:i5 2500K@5GHz|EK Supreme LT+Coolstream XT 240|16GB HyperX DDR3@1866MHz(in blue)|EVGA GTX670SC 4GB+EK FC670|MSI P67A-GD55||M4 128GB|BeQuiet Dark Power Pro 750W|U3011|Raven RV-02E|KBT Pure+Sidewinder X5 + Intuos 4M Audio: PC->TosLink->TEAC UD-H01->Schiit Asgard-> Denon 5000|PFE232|Truth B2030A Monitors BT Feedback |
#87 |
@ Scan R&D
Moderator
Welcome to the forum and team BennieboyUK
#88 | |
Having just read the sticky about "how to get the most out of your HW" I will investigate using the Linux client for VMware - out of interest has anyone converted this client to VHD and tried running in Hyper-V? If not I will try this and report back on the performance. But as I had finally got around to doing FAH (Ive been bluffing myself for a year now that I will do it one day) I just wanted to get some points on the board. On a side note, how did you know I was folding for the team? I dont see my username appearing anywhere? Is there a site that shows team members progress? Any tips, tricks and links to information would be well recieved. I will stop there as I am already off topic - but thanks for the welcome ![]() Thanks! |
#89 |
Aggressive PC Builder
You got a lot of cpu power there, what's your current PPD?
__________________
"Anyone who just plays games for fun is a n3rd" - Jörge "I should be in prison for what I'm thinking right now" - Splooshiba My flickr - My blog it'sfilmnotmovie |
#90 | |
Folding Chimp
http://folding.extremeoverclocking.com/team_list.php?s=
__________________
P5Q Pro - E8400@3.6ghz - 4gbOCZ Gold - 2x XFX Alfadog 8800GT - Antec 300 - OCZ SteathXStream 600w Folding for my family. |
#91 |
Well hard to tell at the moment, I keep changing settings and starting and stopping the client(s), I did a 24h test last week, and I was only getting 49k ppd - I really dont have a base line of "whats is a good PPD" but naturally it depends on the HW being used.
So as you can tell - education curve is going to be steep for the next month or so! And no doubt ill end up
__________________
i7 980x @ 4.4Ghz|12GB Dominator GT 2133mhz|Rampage III|4gb GTX 680 Classified's SLI|830 256GB|Antec 1200w|PF1000|R3|U2711 Hyper-V 2012: Dell 1900 | Dual Xeon E5320 | 32GB DDR2 ECC | LSI @ Raid5 5.452tb WHS: 8gb HP N40L 10tb x8 WD 2tb RED's Raid 6+1 on SRCSASBB8I with BBU |
#92 |
49k??
Thats a pretty nice amount considering you've only just started
__________________
#93 | |
![]() 24h period as follows: 11.27.10 45,448 Once I have looked at this VMware client I will have a better idea of how I want to move forward. Just need to find the time... watch this space.
__________________
#94 |
What's a Dremel?
Thanks for the guide!
Officially now folding, my new rig will be finished in 2 weeks so will have a pc and laptop working away. Can't believe I never heard of this project before I started purchasing Custom PC zine. |
#95 |
What's a Dremel?
joining in progress
#96 |
@ Scan R&D
Moderator
Welcome to the team nxtgenlva
#97 |
What's a Dremel?
Thanks very much. Just out of interest, how does the ps3 do in folding? Is it worth getting a few broken ones with broken drives just for F@H??
#98 |
What's a Dremel?
Climbing onboard the folding wagon
Hi All,
Long time reader - decided to join up & do my bit for humanity ... |
#99 |
Folding in memory of my father
Welcome to the fold.
__________________
#100 | |
My Dremel's bigger than your Dremel
A PS3 gives 1000 PPD (Points Per Day) and uses around 190 Watts and costs ...... what ever you pay for it (£100?). An Intel Sandybridge chip in a reasonable system will cost more initially (5 times?) but will use hardly any more electric and (the 2600K) can ruturn more than 40 times as much PPD. As we have been told PPD relates directly to the quality of the science and electricity use equates to global warming (and overheated wallets) then I think it makes more sense to use the most efficient point-producing equipment we can. If you have the money for the initial outlay (£1000s) then the Intel hex-core chips produce the most efficient bang-per-buck at present at the expense of a little more electricity useage (~400W per system). The more the merrier too - dual chip motherboards help but the ultimate is a Blade Chassis stuffed full of dual or quad processor cards. 14 or 16 cards per chassis (dependant on manufacturer) uses about 3000 Watts (only about 215 Watts per system). Sorry - just dreaming - maybe one day if I win the lottery.
__________________
Folding since 20th August 2004. ![]() |
| Tags |
| howto |
| Thread Tools | |
