Old 23rd Apr 2009, 17:15   #1
Unicorn
Uniform November India
Unicorn's Avatar
Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.Unicorn is the Cheesecake. Relix smiles down upon them.
The great PPD thread [New]
Can I get a sticky?
Just upped the PPD of my dual 8800GTS and C2D E6400 rig today from ~7500-8000 to 9500-10000 by installing the VMware SMP client and removing the standard CPU client that I had running on it. W1n
Unicorn is offline   Reply With Quote
Old 25th Apr 2009, 16:54   #2
1Razor
Living life one day at a time....
1Razor's Avatar
1Razor has yet to learn the way of the Dremel
That's a tidy jump in points Uni. Congrats
__________________
Folding stats
Gaming: Silverstone TJ07, Asus P5Q Del, Q9550 @3.2, GTX285, 4Gb OCZ PC8500, 750GB Spinpoint F1, Corsair HX1000, Dell 2408WFP, WinXP SP3. Folding: Antec 300, Asus P5Q Del, Q9550 @3.2, 2*8800GT, 4GB Corsair PC6400, 750GB Spinpoint F1, Corsair HX620, Win7x64. Folding: Antec 300, Asus P6TD Del, i7 920 @3.8, 9800GTX+8800GT, 6GB Corsair PC12800, 1TB Spinpoint F1, Corsair HX1000, Win7x64.
1Razor is offline   Reply With Quote
Old 25th Apr 2009, 17:51   #3
saspro
Infrastructure Specialist
saspro's Avatar
saspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpitsaspro is almost as Godly as yodasarmpit
The Great PPD thread was about how to get the most points from your hardware.
You need to post what you did so it helps others.
__________________
If what I've said helps you please remember to hit the rep button on the left
Missing the old meeting place? Find us here
saspro is offline   Reply With Quote
Old 25th Apr 2009, 20:05   #4
Unicorn
Unicorn's Avatar
Originally Posted by Unicorn View Post
Just upped the PPD of my... rig today... by installing the VMware SMP client and removing the standard CPU client that I had running on it.
Don't make me quote myself m8 The guide I used to install said VMware SMP client is from Maximum PC and can be found here. Remember you need a CPU that supports VT (Virtualization Technology) to run it!
On another note, I got the overclock on that 8800 rig up higher this morning. That's probably because I have the aircon unit on it at present, which has been needed more and more lately. both GPU cores running stably at 710Mhz and the memory is in around 1010 on both also. Remember to keep them stable at that I have had to use Arctic Cooling Accelero Xtreme 8800 coolers with the fans set to 100% duty cycle in Rivatuner and have an air conditioning unit providing the intakes of the machine with < room temp air.
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
