News AMD releases first WHQL Windows 7 graphics driver
Discussion in 'Article Discussion' started by CardJoe, 7 May 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. adam_bagpuss
    24 Apr 2009
    cool looking forward to that nvidia driver as just building an i7 rig with a 260 in it with win 7
  3. p3n
    p3n What's a Dremel?
    31 Jan 2002
    nvidia driver should be in time for me to pull my finger out and install win 7 on the weekend :D
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    9.2 nor 9.3 worked for me. I had to roll back all the way to 8.12
  5. Gremlin
    Gremlin What's a Dremel?
    31 Aug 2008
    all worked for me, i just found the most reliable driver on win 7 that didnt cause me video playback issues on my 4830 was the 9.2 vista driver
    i'll have to try a clean install rather than an upgrade i did to test how well it worked (upgraded from 7077) but the WHQL driver was an utter bitch, making windows really slow to open and render etc so i had to roll back to 9.2, so im assuming a clean install will fix that so ill do that tonight
    but so far i havent liked the windows 7 drivers (except 8.12)
  6. Paradigm Shifter
    10 May 2006
    Can't remember what version I was running on my old Windows 7 install (I think it was 9.2...) but Cat 9.4 on my current install doesn't give me the correct WEI - for Gaming Graphics my 4850 scores... 2. Yep, 2. All the other scores are fine. It's just that one is whacked for some reason. Ah well, I need to install the Release Candidate today, so I'll give that a shot and see what happens.
  7. Goty
    Goty Minimodder
    13 Dec 2005
    Looks like I might need to install Windows 7 again, now....
  8. amacieli
    amacieli What's a Dremel?
    14 Feb 2008
    Yawn. My 260 works just great with 7100 and the beta nVid drivers. BTW, honest question, does anyone actually have GPGPU apps for the Radeon?
  9. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    I'll install the RC on my laptop once I'm back in England, Sunday it is then. Can't wait to upgrade from 7057 to 7100.
    And I might give it another go on my main PC even though the drivers were way to unstable for my [supposedly] dying 8800GTS which runs 100% under XP and Vista. :eyebrow:
    Downloaded the x64 in less than 2 hours from MS yesterday and the x86 in roughly 3 hours due to x64 being prioritized by 4:1 [450k vs 110k]. Cheers, MS! :thumb:
  10. azrael-
    azrael- I'm special...
    18 May 2008
    AMD itself doesn't seem to have quite the same confidence in its Windows 7 driver as Microsoft has.
    As it states here:
    Note: The Windows 7 driver is not final and is provided "as is." It is not supported by AMD, and may contain software bugs. It has not completed full AMD testing. Use of this software is at your own risk.
    I'm pretty sure it works fine, though. :)
Tags: Add Tags
