RSS
Go Back   bit-tech.net Forums > Modding > Modding
Reply
Thread Tools View Mode
Old 8th May 2009, 02:00   #1
cogitoergosum
Supermodder
cogitoergosum's Avatar
cogitoergosum is on a distinguished road
Oil cooled PC...with Fish! Just an idea...
So, I've seen a whole slew of submerged cases as of late and now I REALLY want one. But being me, I can't have just any old submerged case. Mine needs to have fish in it...
So here's my idea, take an acrylic box and encase it in a second box. The inner box would hold the PC, submerged in oil and be far taller then the inner box, which would hold water and some fish.
So, besides being an incredibly foolish idea (Lets mix H20 and electronics kids!) with a low tolerance for any sort of error..anyone see any huge problems with doing this? Think it would look cool?
__________________
If it only has one monitor, its not worth using. 3 Dell 2407WFPs and 2 19" CRT Studio monitors. 8960x1200 resolution
Proud user of OSX for X86. We don't need no stinkin' Macs
cogitoergosum is offline   Reply With Quote
Old 8th May 2009, 02:04   #2
Volund
I'm Freakin out..... man
Volund has a spectacular aura aboutVolund has a spectacular aura aboutVolund has a spectacular aura about
well, if you keep the two cases seperate (no common sides), you should be fine, and it would look pretty good imo.
__________________
Current System- XFX 780i SLI Mobo, MSI 8800GTS, Q6600, 4GB OCZ RAM, 250GB Seagate HDD + 2x 160GB Seagate HDD's, Corsair 850HX, Lancool PC-K62, Running W7 Ultimate x64
Volund is offline   Reply With Quote
Old 8th May 2009, 02:05   #3
coster_sos
What's a Dremel?
coster_sos's Avatar
coster_sos is on a distinguished road
i actually bought a excellent PVC Clear Box worth around $20 last summer for this project, all the parts lying around. but I never had time to begin it... any way...dude..lol just dont put real live fish in it... serious man
coster_sos is offline   Reply With Quote
Old 8th May 2009, 02:14   #4
cogitoergosum
Supermodder
Thats the point though, to have live fish in it. The plan is to have oil in a center box, surrounded in water with live fish in it.
__________________
Old 8th May 2009, 19:35   #5
Macros_the_Black
Yup.. I'm a f-ing reptile
Macros_the_Black's Avatar
Macros_the_Black will become famous soon enough
I agree with Volund, no common sides. The fish might need to have a certain temperature range in the water at all times, and having the computer heating the water on and off (heat transfer through the glass/plexi) might be bad for the fish.
Other than that, I think it sounds like a cool idea! I'm picturing a Mini-ITX / mATX system (to keep the overall size down) with white aquarium lighting. I don't know how sensitive fish are to coloured lights, you might want to research this before you throw any unnatural lights in there. <=)
I would probably build the aquarium part with glass as it will probably be easier to keep clean and scratch free (you will have to remove algae build-up from time to time). Acrylic for the inner box should be fine. Just remember to leave a gap between the glass and acrylic panels, so you don't 'cook' ;P the fish.
Hehe, that reminds me of my first reaction when reading the thread name... "Oh great! Just add fries, vinegar and a newspaper"
Good luck with the project!
__________________
Tools Picture Dictionary / Visual Tools Guide <----------- I could use some help with this one, plz!
Macros_the_Black is offline   Reply With Quote
Old 10th May 2009, 19:20   #6
PureSilver
Doesn't know his RSS from his elbow
PureSilver's Avatar
PureSilver is a glorious beacon of lightPureSilver is a glorious beacon of lightPureSilver is a glorious beacon of lightPureSilver is a glorious beacon of lightPureSilver is a glorious beacon of light
The best possible combination is using the refractive index to mess with people's heads:
http://gr5.org/index_of_refraction/babywess.jpg
Imagine that - a computer, apparently just dunked in a fishtank, with no glass or anything visible! If you do a bit of calculating you can certainly make it work, but you're going to need to insulate one from the other very carefully. The fish should be fine, as long as you wire a heater to keep the water at a constant temperature.
__________________
Intel Core i7 920 @ 3Ghz, Noctua NH-U12P SE1366, Asus P6T Deluxe, Corsair TR3X6G1600C8D @ XMP, XFX GTX-280,
Samsung SpinPoint F1 640GB, Corsair TX850W, Lian-Li V1000B+ with 3x Noctua NF-P12 & NZXT Sentry LX
2.4Ghz 13" unibody MacBook, 4GB RAM & 128GB SSD
PureSilver is online now   Reply With Quote
Old 12th May 2009, 14:01   #7
dark_avenger
Too hot 2 fold :(
dark_avenger's Avatar
dark_avenger has a spectacular aura aboutdark_avenger has a spectacular aura about
i think i'd look really good.
get some tropical fish and just fold 24/7 keep an even temp :P
__________________
Speaker Box Project
Join the CPC/Bit-Tech FAH Team #35947
dark_avenger is offline   Reply With Quote
Old 12th May 2009, 14:05   #8
Fod
what is the cheesecake?
Fod's Avatar
Fod is a name known to allFod is a name known to allFod is a name known to allFod is a name known to allFod is a name known to allFod is a name known to all
it would be an incredibly foolish idea with a shockingly low tolerance for error, and shows a profound disregard for aquatic life
__________________
"Sesame Street is brought to you by the letters P, W, N, the number 3, and the letter D."
I'm a pretentious git with a camera.
ISPs want to spy on you. Join the fight against phorm
XBL/PSN/Steam ID: FodT
Fod is online now   Reply With Quote
Old 12th May 2009, 17:51   #9
Von Lazuli
I get by fine with a jig-saw.
Von Lazuli's Avatar
Von Lazuli will become famous soon enough
That is an awesome idea, but I am not sure if it can be made to work. The index of refraction of the oil will be much higher than the water, and the thickness of oil will be much greater, which means that you will need an incredibly low density container to surround the oil.
Have I got that right? Or is high school physics too far behind me?
__________________
Working on: Shattered Horizon (November MOTM Nominee)
Von Lazuli is offline   Reply With Quote
Old 13th May 2009, 02:45   #10
PureSilver
PureSilver's Avatar
Believe me, if I could/could be bothered to do the maths, I'd be trying it, not telling cogitoergosum to try it
__________________
Old 2nd Jul 2009, 01:29   #11
cogitoergosum
Supermodder
So, I have actually begun work on this. I am blatantly ignoring some advice above...because that is just how I roll.
The design has also been reworked. Instead of case within a case, I'm doing one big tank, separated by a center divider. After doing some math (which is likely quite shady so I'm not sharing it) I cooked up some dimensions of the tank for 18" x 12" x 24" (457.2 mm x 304.8mm x 609.6mm for our metric friends). Splitting the tank in half I come up with a volume of a little more than 5 gallons on each side (19ish liters). This is a perfect fishtank for a school of Neon Tetras (who are not very susceptible to temp fluctuation and are very cheap) and hopefully a good sized oil reserve to cool my machine.
So, while the design is being worked upon and messed about with in Sketchup and Solidworks, I have a question for the acrylic aficionados out there: How thick should I make the panels?
I'm thinking 3/4" (19mm) but I'm unsure. I'm set back by the prices of 3/4" acrylic so I am considering 1/2". Any opinions on that?
Anyone have a good online US supplier for acrylic/lexan that would cut me a deal?
__________________
Old 2nd Jul 2009, 01:34   #12
Volund
please for the sake of the fish use a thick divider and leak test before you fill them in... I don't like animals dying for experiments :P
try http://www.estreetplastics.com/ or http://www.tapplastics.com/, they have decent stock and are resionably priced. I know that tap plastics has sponsored mods in the past.
__________________
Old 2nd Jul 2009, 01:38   #13
cogitoergosum
Supermodder
Oh, there will be a LONG leak test done. Combining water and computers is usually a bad accident...and I'm doing it intentionally.
I'm also planning on tropical fish and regulating the water side with a thermometer to keep from killing them. I've kept fish for quite a while and tend to have the "magical touch" when it comes to keeping them alive. No animals will be harmed in the making of this mod.
Thanks much for the links.
__________________
Old 2nd Jul 2009, 01:41   #14
Devolve
Deadbeat
Devolve's Avatar
Devolve is on a distinguished road
Or use white mice, thats what they were invented for wasn't it?
__________________
PRAESIS UT PROSIS
Evolution is the myth. Look around you the world isn't
evolving...it's DEvolving.
Devolve is offline   Reply With Quote
Old 2nd Jul 2009, 01:46   #15
cogitoergosum
Supermodder
Tell you what, if you provide the white mice with gills...I will be more then willing to use them instead of fish. Otherwise, I think they would just be dying a senseless death by drowning.
Back on topic:
I am still quite shellshocked by the sticker on acrylic sheet, especially 3/4". To think at the outset I was thinking on using 1".
Any thoughts on the 3/4" vs 1/2" debate? I'm worried the 1/2" won't be strong enough...but the 3/4" is too expensive to get this project off the ground any time soon...
__________________
Old 2nd Jul 2009, 01:58   #16
Volund
1/2" acrylic is pretty damn strong, I use 1/4" for case windows, never had any thoughts of it breaking.
This build- http://forums.bit-tech.net/showthread.php?t=163649
uses 1/4" and 3/8" plexi (http://forums.bit-tech.net/showpost....94&postcount=4)
Cheers,
Volund
__________________
Old 2nd Jul 2009, 02:07   #17
cogitoergosum
Supermodder
Cheers,
Volund
Well wouldya look at that. In other words...3/4" would be overkill of a massive proportion. Dammit...now my "over-engineering" gene is demanding I make the entire thing out of 3/4" just to warp people's minds!
I'll do some heavy thinking and plotting overnight and will hopefully present some sketchup models in the morning.
Thanks for the help
__________________
Old 3rd Jul 2009, 19:54   #18
Matticus
_________________
Matticus's Avatar
Matticus is a glorious beacon of lightMatticus is a glorious beacon of lightMatticus is a glorious beacon of lightMatticus is a glorious beacon of lightMatticus is a glorious beacon of light
Sounds like a good idea.
Neon Tetras are going to be one of the few fish you can keep in there. Between 20 and 30 is pretty much fine for them with the top and bottom end are a bit iffy, but they do usually do best at about 24-26.
You will need to find out how much heat the system is going to dump into the oil tank, and then work out how much this will change the water temp in the fish tank.
One way of keeping the temps from changing too much would be to "double glaze" create 2 walls with a thin gap of air in the middle, sealed of course, otherwise condensation will be an issue.
I assume you have fish, so you will know this, a lot of water collects and condensates onto the roof of the tank, and then drips down the sides. So either seal the oil case which I guess you would. Or just make some sort of foam gasket around each bit so when the roof sits it seals each section off.
Oh and most, even the cheapest fishtank heaters will just heat up to whatever you set them as and then turn off until the temp drops. If you set it to the highest degrees the water will reach, hopefully below 26/27 and then it will keep the water as constant as possible.
__________________
|||E8200@3.4ghz|||GA-P35-DS3L|||4GB OCZ/Corsair DDR2 800|||8800GT 512mb|||VX450w|||Under Water|||
Matticus is offline   Reply With Quote
Old 3rd Jul 2009, 20:31   #19
IanW
I *am* a Dremel
IanW's Avatar
IanW is just really niceIanW is just really niceIanW is just really niceIanW is just really nice
Oil + fish generally leads to only one thing (if done just right)...
__________________
Q6600@3GHz / AC Freezer 7 Pro / Gigabyte EP35-DS3R / 8GB OCZ Platinum PC6400 / EVGA GTX260 SSC / LG DVDR / 9TB HDD /
OCZ Modstream 780W / CoolerMaster 590 case / Dell E248WFP / Saitek Eclipse II / Logitech G9 / Ubuntu 9.10-64
IanW is offline   Reply With Quote
Old 3rd Jul 2009, 20:43   #20
MrWillyWonka
Moderator
MrWillyWonka's Avatar
MrWillyWonka will become famous soon enough
One question, how are you going to get the cables from the computer in the oil past the water into the outside of the tanks?
__________________
Project Red - HL2 - PSOne LCD S-Video Guide
Main Rig: Asus Striker Extreme, Intel Core 2 Quad Q6600 G0 OC'd to 2.65GHz, 4GB Corsair XMS, 8800GTS in SLI, 36 & 74GB Raptors
MrWillyWonka is offline   Reply With Quote
Reply
Thread Tools
View Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
